    Rayscaper New Releases
    rayscaperrender
    744 Posts 14 Posters 317.8k Views 15 Watching
    • pixelcruncherP
      Hey, Rayscaper users!
      Rayscaper 0.9.77 Beta is available. You can get it via:
      • The SketchUcation store.
      • Direct download: link.
      I recommend upgrading to the latest version.
      What Changed?
      • Add Bloom and Glare post-processing effects. Enhance your renders with cinematic quality.
      • Add visual feedback for render failures. A red "RENDER FAILED" text now appears when rendering encounters errors,
        making it immediately clear when something goes wrong.
      • GUI enhancements: Improved sliders and tooltips. Sliders now have dedicated input boxes for more precise control.
      • Fix texture environment image update. Loading a new HDRI would not restart the render.
      • Bugfix: Fix grayscale image display in ImGui. Grayscale images were showing as red due to improper handling of
        single-channel pixel formats.
      • Add procedural sky environment support. You can now create realistic sky environments directly in Rayscaper without
        needing HDRI images. Perfect for quick outdoor renders with physically-based sky and sun simulation.
      • Add SketchUp environment tracking support (SketchUp 2025 or higher). Rayscaper can now automatically track and sync
        with SketchUp's environment settings.
      • Add PBR material support for SketchUp 2025. SketchUp 2025's new PBR materials are now supported and will
        automatically convert to Rayscaper's material system with proper metallic, roughness, and normal map values. Note:
        Rayscaper does not support power/scale multipliers on image textures, so if your SketchUp PBR material uses a
        roughness or metallic texture with a scale value other than 1.0, that scaling will not be applied in Rayscaper.
      • Bring back archive creation. You can now export your complete scene, including all assets, to a zip archive for easy
        sharing and backup.
      • Separate max depth settings by path type. Advanced users can now configure maximum ray bounce depths separately for
        diffuse, glossy, and transmission paths for more control over render quality and performance.
      • Bugfix: Fix FloatImageTexture color space handling. Float textures (like roughness and metallic maps) now correctly
        use linear color space for accurate rendering.
      • Bugfix: Fix noise texture deserialization. Noise textures saved in previous versions now load correctly and don't
        crash Rayscaper. @sashapepperspray - This should fix the crash you saw opening your file.
      • Bugfix: Avoid duplicate SketchUp shadow light. The sun/shadow light from SketchUp will no longer appear twice in the
        scene.
      The following screenshot shows the user interface enhancements:
      Render by @Rich-O-Brien using bloom & glare for more realism:
      Help Me Build the Community 👍
      If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities
      to new users.
      Follow me on https://x.com/rayscaper3d.
      Happy Rendering!
      Thomas
      S 1 Reply Last reply
      • KrassK
        Krass
        thanks, great !
        Krass
        Reply Quote 3
          sashapepperspray @pixelcruncher
          @pixelcruncher thank you so much!
          • KrassK
            Krass
            I had to uninstall the extension store and I got an error message from Rayscaper.
            And now I'm having the same problem again after reinstalling Rayscaper 9.77.
            Krass
            • pixelcruncherP
              @Krass Can you post the error message from Rayscaper? Looking into this, sorry about that.
              • KrassK
                Krass
                No, I did get a window indicating a problem loading the Rayscaper extension, but it hasn't reappeared.
                Krass
                • KrassK
                  Krass
                  However, I had installed it correctly without any problems before.
                  Krass
                  • majidM
                    majid
                    I have a question regarding material libraries. I have prepared a Carpaint collection and am also going to prepare a water material pack. The question is that if the same name materials will be replaced? i.e. a car paint in my library is called 001red. Imagine there is another material in the Sketchup model by user and called 001red, I am wondering if RS will replace the same name with my material? To be more precise: How do material libraries in RS work?
                      I must admit to being more than a little biased here, Majid's contributions in this department have been extremely helpful. Personally, I would like to see all the finish items from twilight included in Rayscaper, they would much improve the goal of simplicity with speed.
                      Reply Quote 2
                      • pixelcruncherP
                        pixelcruncher Extension Creator @majid
                        @majid said in Rayscaper New Releases:
                        Nice, users will love those material packs!
                        No — naming your materials isn’t essential for Rayscaper. Names only matter for finding them in the material library. They are necessary for the user, not for the software.
                        Behind the scenes, Rayscaper stores each material as a material pack, which is simply a ZIP file. This pack includes a human-readable configuration file and all the texture images used by the material. I will add this format to my documentation. I hope that, in the age of AI vibe-coding, people can build tools to convert materials from other renderers into Rayscaper, and vice versa.
                        When you apply a material in Rayscaper to any material in your SketchUp model, Rayscaper doesn’t replace the SketchUp material. Instead, it configures the existing SketchUp material using the parameters it reads from the material pack.
                        You can view the material packs that Rayscaper saves in the %%AppData%%/AssetCache folder (the exact path escapes me, I'm not at my PC right now).
                        Cheers,
                        Thomas
                        • pixelcruncherP
                          pixelcruncher Extension Creator @Mike Amos
                          @Mike-Amos
                          I think my friend @majid requested that before as well 🙂 He has a keen eye for this.
                          Given that the Twilight website is offline, is there a source where I can find these things? Maybe I can actually provide tools for using Twilight materials in Rayscaper, or at least the same templates.
                          • pixelcruncherP
                            @Krass I will have a look soon to help you out here, stay tuned.
                            • KrassK
                              Krass
                              are you both talking about Twilight render ?
                              Krass
                              • pixelcruncherP
                                @Krass said in Rayscaper New Releases:
                                Yes, @majid and @Mike-Amos are talking about Twilight render. But I'm not too familiar with it myself. But it seems to have a couple of dearly missed features?
                                • KrassK
                                  Krass
                                  Twilight render was great, but Rayscaper is marvelous compared to it.
                                  I can give you the last version of Twilight
                                  Krass
                                    Yep, trying to get to grips with the actual process or getting them back into the wild.
                                      sashapepperspray @sashapepperspray
                                      I think I figured something out about the blue material bug, I can make it happen in any file if I use the "edit texture in external editor" in the sketchup material editor, It shows up as blue.
                                      (Another thing I noticed, is that If i edit a material in sketchup, it does not automatically update the material in rayscaper.)
                                      • pixelcruncherP
                                        That's a good clue. I think it also has to do with SketchUp's colorized textures only. But I haven't looked at that part in depth.
                                        This is by design; You should press the reload button in the Rayscaper material editor. I could add an "auto-sync" option to do this automatically. Rayscaper has a richer set of material capabilities than SketchUp. I assumed you want to edit the materials in Rayscaper, and that it would be counterproductive to override them from SketchUp repeatedly. Maybe that's not a reasonable workflow assumption.
                                          sashapepperspray
                                          okay, thanks (a feature request- maybe you can make a seperate reload button for the regular texture, for the metalness, roughness, and normal maps, so If I edit the regular texture in sketchup but want to keep the metallness changes in rayscaper I can do that.)
                                          • KrassK
                                            Krass
                                            when I display a SketchUp scene in RS, the hidden tags within that scene are still visible.
                                            And there's still this problem with certain groups containing other groups and components that don't display unless everything inside is exploded. And I can't always explode everything, as I have variations to make in subsequent steps.
                                            And i no graphic card
                                            Krass
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 37
                                            • 38
                                            • 14 / 38
