    Rayscaper New Releases
    rayscaperrender
    521 Posts 12 Posters 242.5k Views 13 Watching
    • pixelcruncherP
      pixelcruncher Extension Creator @ntxdave
      @ntxdave Sounds good!
      • KrassK
        Krass
        Rayscaper 0.9.71 renders / Photoshop / Nano Banana for the characters / Magnific Upscale
        Krass
        • KrassK
          Krass
          Compared to D5 Render Plus and D5 Render AI Enhancement, it's much better
          D5 is faster, but its path tracing is a sham
          https://jskup.fr/wp-content/uploads/2025/11/scene-6.FB_.jpg
          Krass
          • pixelcruncherP
            @Krass
            Compared to D5 Render Plus and D5 Render AI Enhancement, it's very mediocre!
            What exactly is mediocre, or what are you missing? That helps me improve the software. Now I can only guess at what's mediocre compared to D5 render.
            Cheers,
            Thomas
            • KrassK
              Krass
              Sorry Pixelcruncher, that's my faulty translation... I really want to highlight Rayscaper! I love the photorealistic quality of RS's path tracing. I meant the opposite in my post and I've corrected it.
              Krass
              1 Reply Last reply β™₯
              • pixelcruncherP
                Phew πŸ˜“ I'm happy you like it!
                • KrassK
                  Krass
                  I made a blunder, but my post has been corrected.
                  Krass
                    sashapepperspray
                    I just noticed a bug, Most files (I think it is if they were created before 2026, and I am opening them in 2026) that I open the rayscaper window in, all the faces are blue, and I have to reset every material to see the textures.
                    Also, One file (it is on the warehouse here https://3dwarehouse.sketchup.com/model/6e2af6cd-7fde-487b-99f4-919da24ecd11/the-original-second-temple) whenever I open rayscaper in it, sketchup just closes.
                    here si pictures of the first bug
                    pixelcruncherP S 2 Replies Last reply
                    • pixelcruncherP
                      pixelcruncher Extension Creator @sashapepperspray
                      @sashapepperspray
                      Thanks for the bug report.
                      Do you mind sending me a file where the first issue happens (i.e., the faces without materials)?
                      For the second issue, I can reproduce this with the temple model. I will have a look at it.
                      Regards,
                      Thomas
                      S 1 Reply Last reply
                        sashapepperspray @pixelcruncher
                        @pixelcruncher said in Rayscaper New Releases:
                        produce this wit
                        here is one with the bug, the stone texture does not work.
                        terrrain.skp
                        • pixelcruncherP
                          @sashapepperspray Thanks for the scene! I can reproduce it, so that will help me fix it.
                          • pixelcruncherP
                            Hey, Rayscaper users!
                            Rayscaper 0.9.77 Beta is available. You can get it via:
                            • The SketchUcation store.
                            • Direct download: link.
                            I recommend upgrading to the latest version.
                            What Changed?
                            • Add Bloom and Glare post-processing effects. Enhance your renders with cinematic quality.
                            • Add visual feedback for render failures. A red "RENDER FAILED" text now appears when rendering encounters errors,
                              making it immediately clear when something goes wrong.
                            • GUI enhancements: Improved sliders and tooltips. Sliders now have dedicated input boxes for more precise control.
                            • Fix texture environment image update. Loading a new HDRI would not restart the render.
                            • Bugfix: Fix grayscale image display in ImGui. Grayscale images were showing as red due to improper handling of
                              single-channel pixel formats.
                            • Add procedural sky environment support. You can now create realistic sky environments directly in Rayscaper without
                              needing HDRI images. Perfect for quick outdoor renders with physically-based sky and sun simulation.
                            • Add SketchUp environment tracking support (SketchUp 2025 or higher). Rayscaper can now automatically track and sync
                              with SketchUp's environment settings.
                            • Add PBR material support for SketchUp 2025. SketchUp 2025's new PBR materials are now supported and will
                              automatically convert to Rayscaper's material system with proper metallic, roughness, and normal map values. Note:
                              Rayscaper does not support power/scale multipliers on image textures, so if your SketchUp PBR material uses a
                              roughness or metallic texture with a scale value other than 1.0, that scaling will not be applied in Rayscaper.
                            • Bring back archive creation. You can now export your complete scene, including all assets, to a zip archive for easy
                              sharing and backup.
                            • Separate max depth settings by path type. Advanced users can now configure maximum ray bounce depths separately for
                              diffuse, glossy, and transmission paths for more control over render quality and performance.
                            • Bugfix: Fix FloatImageTexture color space handling. Float textures (like roughness and metallic maps) now correctly
                              use linear color space for accurate rendering.
                            • Bugfix: Fix noise texture deserialization. Noise textures saved in previous versions now load correctly and don't
                              crash Rayscaper. @sashapepperspray - This should fix the crash you saw opening your file.
                            • Bugfix: Avoid duplicate SketchUp shadow light. The sun/shadow light from SketchUp will no longer appear twice in the
                              scene.
                            The following screenshot shows the user interface enhancements:
                            Render by @Rich-O-Brien using bloom & glare for more realism:
                            Help Me Build the Community πŸ‘
                            If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities
                            to new users.
                            Follow me on https://x.com/rayscaper3d.
                            Happy Rendering!
                            Thomas
                            • KrassK
                              Krass
                              thanks, great !
                              Krass
                              Reply Quote 3
                                @pixelcruncher thank you so much!
                                • KrassK
                                  Krass
                                  I had to uninstall the extension store and I got an error message from Rayscaper.
                                  And now I'm having the same problem again after reinstalling Rayscaper 9.77.
                                  Krass
                                  • pixelcruncherP
                                    @Krass Can you post the error message from Rayscaper? Looking into this, sorry about that.
                                    • KrassK
                                      Krass
                                      No, I did get a window indicating a problem loading the Rayscaper extension, but it hasn't reappeared.
                                      Krass
                                      • KrassK
                                        Krass
                                        However, I had installed it correctly without any problems before.
                                        Krass
                                        • majidM
                                          majid
                                          I have a question regarding material libraries. I have prepared a Carpaint collection and am also going to prepare a water material pack. The question is that if the same name materials will be replaced? i.e. a car paint in my library is called 001red. Imagine there is another material in the Sketchup model by user and called 001red, I am wondering if RS will replace the same name with my material? To be more precise: How do material libraries in RS work?
                                            I must admit to being more than a little biased here, Majid's contributions in this department have been extremely helpful. Personally, I would like to see all the finish items from twilight included in Rayscaper, they would much improve the goal of simplicity with speed.
                                            Reply Quote 2
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 26
                                            • 27
                                            • 14 / 27
