    Rayscaper New Releases
    rayscaperrender
    462 Posts 12 Posters 171.1k Views 13 Watching
      pixelcruncher Extension Creator @ntxdave
      @ntxdave - In your test file, it had a ton of geometry generated in the model. If I tried to re-create your scene again, step-by-step I got this:
      Can you try to just generate the grass on the plane, a first step and see if that works?
      As a sanity check, you are using Rayscaper 0.9.72?
      • KrassK Offline
        Krass
        Great!
        Krass
        • ntxdaveN Offline
          ntxdave @pixelcruncher
          @pixelcruncher said in Rayscaper New Releases:
          Yes, I have updated to Rayscaper 0.9.72. I am having ongoing problems. I will let you know more when I can. I will try to create a very basic file and show what I am see both if I generate in model and with render only.
          It is probably going to be much later though. I want to get to the bottom of the problem(s) I am seeing.
          Press F1...thank me later
            @ntxdave Sounds good!
            • KrassK Offline
              Krass
              Rayscaper 0.9.71 renders / Photoshop / Nano Banana for the characters / Magnific Upscale
              Krass
              • KrassK Offline
                Krass
                Compared to D5 Render Plus and D5 Render AI Enhancement, it's much better
                D5 is faster, but its path tracing is a sham
                https://jskup.fr/wp-content/uploads/2025/11/scene-6.FB_.jpg
                Krass
                  @Krass
                  Compared to D5 Render Plus and D5 Render AI Enhancement, it's very mediocre!
                  What exactly is mediocre, or what are you missing? That helps me improve the software. Now I can only guess at what's mediocre compared to D5 render.
                  Cheers,
                  Thomas
                  • KrassK Offline
                    Krass
                    Sorry Pixelcruncher, that's my faulty translation... I really want to highlight Rayscaper! I love the photorealistic quality of RS's path tracing. I meant the opposite in my post and I've corrected it.
                    Krass
                    1 Reply Last reply β™₯ Reply Quote 0
                      Phew πŸ˜“ I'm happy you like it!
                      • KrassK Offline
                        Krass
                        I made a blunder, but my post has been corrected.
                        Krass
                          sashapepperspray
                          I just noticed a bug, Most files (I think it is if they were created before 2026, and I am opening them in 2026) that I open the rayscaper window in, all the faces are blue, and I have to reset every material to see the textures.
                          Also, One file (it is on the warehouse here https://3dwarehouse.sketchup.com/model/6e2af6cd-7fde-487b-99f4-919da24ecd11/the-original-second-temple) whenever I open rayscaper in it, sketchup just closes.
                          here si pictures of the first bug
                          P S 2 Replies Last reply Reply Quote 1
                            pixelcruncher Extension Creator @sashapepperspray
                            @sashapepperspray
                            Thanks for the bug report.
                            Do you mind sending me a file where the first issue happens (i.e., the faces without materials)?
                            For the second issue, I can reproduce this with the temple model. I will have a look at it.
                            Regards,
                            Thomas
                            S 1 Reply Last reply Reply Quote 0
                              sashapepperspray @pixelcruncher
                              produce this wit
                              here is one with the bug, the stone texture does not work.
                              terrrain.skp
                                @sashapepperspray Thanks for the scene! I can reproduce it, so that will help me fix it.
                                  Hey, Rayscaper users!
                                  Rayscaper 0.9.77 Beta is available. You can get it via:
                                  • The SketchUcation store.
                                  • Direct download: link.
                                  I recommend upgrading to the latest version.
                                  What Changed?
                                  • Add Bloom and Glare post-processing effects. Enhance your renders with cinematic quality.
                                  • Add visual feedback for render failures. A red "RENDER FAILED" text now appears when rendering encounters errors,
                                    making it immediately clear when something goes wrong.
                                  • GUI enhancements: Improved sliders and tooltips. Sliders now have dedicated input boxes for more precise control.
                                  • Fix texture environment image update. Loading a new HDRI would not restart the render.
                                  • Bugfix: Fix grayscale image display in ImGui. Grayscale images were showing as red due to improper handling of
                                    single-channel pixel formats.
                                  • Add procedural sky environment support. You can now create realistic sky environments directly in Rayscaper without
                                    needing HDRI images. Perfect for quick outdoor renders with physically-based sky and sun simulation.
                                  • Add SketchUp environment tracking support (SketchUp 2025 or higher). Rayscaper can now automatically track and sync
                                    with SketchUp's environment settings.
                                  • Add PBR material support for SketchUp 2025. SketchUp 2025's new PBR materials are now supported and will
                                    automatically convert to Rayscaper's material system with proper metallic, roughness, and normal map values. Note:
                                    Rayscaper does not support power/scale multipliers on image textures, so if your SketchUp PBR material uses a
                                    roughness or metallic texture with a scale value other than 1.0, that scaling will not be applied in Rayscaper.
                                  • Bring back archive creation. You can now export your complete scene, including all assets, to a zip archive for easy
                                    sharing and backup.
                                  • Separate max depth settings by path type. Advanced users can now configure maximum ray bounce depths separately for
                                    diffuse, glossy, and transmission paths for more control over render quality and performance.
                                  • Bugfix: Fix FloatImageTexture color space handling. Float textures (like roughness and metallic maps) now correctly
                                    use linear color space for accurate rendering.
                                  • Bugfix: Fix noise texture deserialization. Noise textures saved in previous versions now load correctly and don't
                                    crash Rayscaper. @sashapepperspray - This should fix the crash you saw opening your file.
                                  • Bugfix: Avoid duplicate SketchUp shadow light. The sun/shadow light from SketchUp will no longer appear twice in the
                                    scene.
                                  The following screenshot shows the user interface enhancements:
                                  Render by @Rich-O-Brien using bloom & glare for more realism:
                                  Help Me Build the Community πŸ‘
                                  If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities
                                  to new users.
                                  Follow me on https://x.com/rayscaper3d.
                                  Happy Rendering!
                                  Thomas
                                  • KrassK Offline
                                    Krass
                                    thanks, great !
                                    Krass
                                      @pixelcruncher thank you so much!
                                      • KrassK Offline
                                        Krass
                                        I had to uninstall the extension store and I got an error message from Rayscaper.
                                        And now I'm having the same problem again after reinstalling Rayscaper 9.77.
                                        Krass
                                          @Krass Can you post the error message from Rayscaper? Looking into this, sorry about that.
                                          • KrassK Offline
                                            Krass
                                            No, I did get a window indicating a problem loading the Rayscaper extension, but it hasn't reappeared.
                                            Krass
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 23
                                            • 24
                                            • 14 / 24
