    Rayscaper New Releases
    rayscaperrender
    743 Posts 14 Posters 312.6k Views 15 Watching
    • pixelcruncherP
      @Krass said in Rayscaper New Releases:
      I did the same. I am now on 0.9.62 and no problem
      Not following @Krass - To which post was this a reply?
      Cheers,
      Thomas
      • N
        nickchun @pixelcruncher
        @pixelcruncher Yes that was it, with the faces painted it works. ๐Ÿ‘
        • pixelcruncherP
          pixelcruncher Extension Creator @nickchun
          @nickchun Great! I plan to fix that bug soon.
          N 1 Reply Last reply
          • N
            @pixelcruncher Just found another strange one. Objects that are hidden or under non visible tags, are showing up in the render.
            • pixelcruncherP
              @nickchun
              Do you have an example scene, or can you send me a screen capture? I can't reproduce it here, but maybe you have a different setup:
              tags_bug.mp4
              Thanks for your help!
              Thomas
              • KrassK
                Krass @pixelcruncher
                @pixelcruncher thanks, do tyou have any tip to fix this lights name/numbe issue? (which I spoke about above)
                Krass
                • pixelcruncherP
                  @Krass - The only way right now is to rename the light component in SketchUp itself. I will add the option to name the lights in Rayscaper. And have something to multi-edit the lights. @Rich-O-Brien complained about this as well.
                  • KrassK
                    Krass
                    yes, but for now if I rename RS lights components, they all shut down
                    Krass
                    • pixelcruncherP
                      Sorry about that; I just noticed there's a bug here, and the renaming of lights is now broken. I already have a fix and will make a new release very soon.
                      Cheers,
                      Thomas
                      • KrassK
                        Krass
                        great! thanks
                        Krass
                        • N
                          @pixelcruncher I've been trying to recreate it in a simple scene but it keeps crashing. I actually think its largely down to to PC I'm using- I have to run SU2023 and Vray 6 instead ofc2025 and Vray7 because its under spec.
                          • pixelcruncherP
                            @nickchun, can you send me the log file immediately after it crashed? That would help me debug the issue. You can find the log file under C:\Users\YourUserName\AppData\Roaming\Rayscaper, the file is called SUEX_Rayscaper.log.
                            It should not crash because your PC is not beefy enough.
                            Thomas
                            [1] https://rayscaper.com/getting-help/report-a-bug/
                            • pixelcruncherP
                              pixelcruncher Extension Creator @pixelcruncher
                              @nickchun can you also mail me the file for which it keeps crashing? thomas@rayscaper.com.
                              • KrassK
                                Krass
                                I previously attached images of Rayscaper with a very satisfactory upscale and I am now adding a character: So, Rayscaper rendering, adding a character with Flux dev basic (via my ComfyUI installation for those who know), and upscale with Magnific via the Xfigura site which gives a few free credits per month.
                                Krass
                                Reply Quote 2
                                • pixelcruncherP
                                  @Krass Very cool, I didn't know about ComfyUI; I'm going to try that out. Thanks for sharing the workflow!
                                  • KrassK
                                    Krass
                                    Be careful, Comfy UI requires a large graphics card and lots of free disk space, and a lot of patience.
                                    Krass
                                    • pixelcruncherP
                                      Hey, Rayscaper users!
                                      Another release!
                                      Rayscaper 0.9.64 Beta is available in the SketchUcation store. As
                                      always, I recommend upgrading to the latest version.
                                      What Changed?
                                      • Fix weird artifacts in the interactive render viewport.
                                      • Fix the upside-down images when saving.
                                      • Add transmission support for the PBR material. This makes it possible to create glass or liquid materials with the PBR material.
                                      • Fix a regression when renaming light components. Rayscaper lights should now correctly use the name of their SketchUp
                                        light component again.
                                      • Fix glass rendering, when multiple glass surfaces overlapped, Rayscaper would render them too dark.
                                      • Fix the render timer in the viewport. It will stop counting when the render is paused or finished.
                                      Help Me Build the Community ๐Ÿ‘
                                      If you like Rayscaper, please share your renders (final or work-in-progress, it doesnโ€™t matter)! This is motivating
                                      and helps me showcase its capabilities to new users.
                                      Follow me on Twitter.
                                      Happy Rendering!
                                      • KrassK
                                        Krass
                                        thanks Pix, but no change for the lights component name with this version 9.64 If I rename the lights componant all lights go down
                                        Krass
                                        • pixelcruncherP
                                          @Krass, just as a sanity check, you are not changing the name right, and not the component definition name?
                                          • KrassK
                                            Krass
                                            ok, sorry, Indeed, I changed the component name and the instance name... thanks. Perfect, I'll test it.
                                            However, I don't understand. I set the HDR definition to 8k, and it seems that it doesn't take this definition into account. I'll redo the rendering after downloading the map from the site.
                                            Krass
                                            • 37
                                            • 38
                                            • 8 / 38
