    Rayscaper New Releases
    rayscaperrender
    743 Posts 14 Posters 312.6k Views 15 Watching
    • N
      nickchun @pixelcruncher
      @pixelcruncher Yes that was it, with the faces painted it works. ๐Ÿ‘
      • pixelcruncherP
        pixelcruncher Extension Creator @nickchun
        @nickchun Great! I plan to fix that bug soon.
        N 1 Reply Last reply
        • N
          @pixelcruncher Just found another strange one. Objects that are hidden or under non visible tags, are showing up in the render.
          • pixelcruncherP
            @nickchun
            Do you have an example scene, or can you send me a screen capture? I can't reproduce it here, but maybe you have a different setup:
            tags_bug.mp4
            Thanks for your help!
            Thomas
            • KrassK
              Krass @pixelcruncher
              @pixelcruncher thanks, do tyou have any tip to fix this lights name/numbe issue? (which I spoke about above)
              Krass
              • pixelcruncherP
                @Krass - The only way right now is to rename the light component in SketchUp itself. I will add the option to name the lights in Rayscaper. And have something to multi-edit the lights. @Rich-O-Brien complained about this as well.
                • KrassK
                  Krass
                  yes, but for now if I rename RS lights components, they all shut down
                  Krass
                  • pixelcruncherP
                    @Krass said in Rayscaper New Releases:
                    Sorry about that; I just noticed there's a bug here, and the renaming of lights is now broken. I already have a fix and will make a new release very soon.
                    Cheers,
                    Thomas
                    • KrassK
                      Krass
                      great! thanks
                      Krass
                      • N
                        @pixelcruncher I've been trying to recreate it in a simple scene but it keeps crashing. I actually think its largely down to to PC I'm using- I have to run SU2023 and Vray 6 instead ofc2025 and Vray7 because its under spec.
                        • pixelcruncherP
                          @nickchun, can you send me the log file immediately after it crashed? That would help me debug the issue. You can find the log file under C:\Users\YourUserName\AppData\Roaming\Rayscaper, the file is called SUEX_Rayscaper.log.
                          It should not crash because your PC is not beefy enough.
                          Thomas
                          [1] https://rayscaper.com/getting-help/report-a-bug/
                          • pixelcruncherP
                            pixelcruncher Extension Creator @pixelcruncher
                            @nickchun can you also mail me the file for which it keeps crashing? thomas@rayscaper.com.
                            • KrassK
                              Krass
                              I previously attached images of Rayscaper with a very satisfactory upscale and I am now adding a character: So, Rayscaper rendering, adding a character with Flux dev basic (via my ComfyUI installation for those who know), and upscale with Magnific via the Xfigura site which gives a few free credits per month.
                              Krass
                              Reply Quote 2
                              • pixelcruncherP
                                @Krass Very cool, I didn't know about ComfyUI; I'm going to try that out. Thanks for sharing the workflow!
                                • KrassK
                                  Krass
                                  Be careful, Comfy UI requires a large graphics card and lots of free disk space, and a lot of patience.
                                  Krass
                                  • pixelcruncherP
                                    Hey, Rayscaper users!
                                    Another release!
                                    Rayscaper 0.9.64 Beta is available in the SketchUcation store. As
                                    always, I recommend upgrading to the latest version.
                                    What Changed?
                                    • Fix weird artifacts in the interactive render viewport.
                                    • Fix the upside-down images when saving.
                                    • Add transmission support for the PBR material. This makes it possible to create glass or liquid materials with the PBR material.
                                    • Fix a regression when renaming light components. Rayscaper lights should now correctly use the name of their SketchUp
                                      light component again.
                                    • Fix glass rendering, when multiple glass surfaces overlapped, Rayscaper would render them too dark.
                                    • Fix the render timer in the viewport. It will stop counting when the render is paused or finished.
                                    Help Me Build the Community ๐Ÿ‘
                                    If you like Rayscaper, please share your renders (final or work-in-progress, it doesnโ€™t matter)! This is motivating
                                    and helps me showcase its capabilities to new users.
                                    Follow me on Twitter.
                                    Happy Rendering!
                                    • KrassK
                                      Krass
                                      thanks Pix, but no change for the lights component name with this version 9.64 If I rename the lights componant all lights go down
                                      Krass
                                      • pixelcruncherP
                                        @Krass, just as a sanity check, you are not changing the name right, and not the component definition name?
                                        • KrassK
                                          Krass
                                          ok, sorry, Indeed, I changed the component name and the instance name... thanks. Perfect, I'll test it.
                                          However, I don't understand. I set the HDR definition to 8k, and it seems that it doesn't take this definition into account. I'll redo the rendering after downloading the map from the site.
                                          Krass
                                          • KrassK
                                            Krass
                                            before/after: rayscaper project/Nano banana+Magnific upscale
                                            Krass
                                            Reply Quote 3
                                            • 37
                                            • 38
                                            • 8 / 38
