    Various Ceiling Lights
    14 Posts 7 Posters 1.0k Views 7 Watching
    • massimoM Offline
      massimo Moderator @Rich O Brien
      @Rich-O-Brien Well done! πŸ‘
      • Rich O BrienR Online
        @massimo thank you my friend
        • tuna1957T Offline
          tuna1957 @Rich O Brien
          @Rich-O-Brien Interesting designs. πŸ‘
          • panixiaP Offline
            panixia
            Excellent. How did you do the faceted one in second image?
            I wold be curious to se a wireframe of it.
              Rich O Brien Moderator @panixia
              @panixia Its a normal map I made in Substance Designer that I then played with the UV scaling to get the look needed.
                The wires...
                Pretty basic stuff tbh. It was more the materials doing the heavy lifting and a nice studio HDR
                panixiaP 1 Reply Last reply Reply Quote 1
                • panixiaP Offline
                  panixia @Rich O Brien
                  @Rich-O-Brien you used spherical UVs?
                    @panixia the bump only needed to reside with this area so I did flat unwrap for this portion
                    So the object had 2 glass materials
                    Gus RG panixiaP 2 Replies Last reply Reply Quote 0
                    • Gus RG Offline
                      Gus R @Rich O Brien
                      @Rich-O-Brien Groovy, man. Nice. How did you make the tassels?
                      www.instagram.com/gusrobatto/
                      www.facebook.com/gusrobatto
                      • panixiaP Offline
                        @Rich-O-Brien Pretty straight forward..
                        I'd expected a more noticeable distortion.. so I was fancying about about geospheres or some other funny way to over-complicate life
                          Rich, I enjoy seeing your work, wish you would do it more
                            Rich O Brien Moderator @Gus R
                            @Gus-R said in Various Ceiling Lights:
                            I had a starter asset from the client but it was unworkable. So I took a portion and made section I could array along a curve in Blender.
                            I made a couple if variants so the stringy bits didn't look repetitive. I also found a Geonodes setup online that helped add that randomness.
                            SketchUp wasn't up to the task unless you like lots of spinning wheel cursors. These are Cycles renders using the AGX View Transform.
                              Magic.
