๐Ÿค‘ 30% Off | Artisan 2 on sale until April 30th Buy Now
Various Ceiling Lights
14 Posts 7 Posters 77 Views
    Some renders of lights I did...
    Download the free D'oh Book for SketchUp
    M T 2 Replies Last reply 3 Apr 2025, 12:08 Reply Quote 2
      massimo Moderator @Rich O Brien
      @Rich-O-Brien Well done! ๐Ÿ‘
        @massimo thank you my friend
          tuna1957 @Rich O Brien
          @Rich-O-Brien Interesting designs. ๐Ÿ‘
            panixia
            Excellent. How did you do the faceted one in second image?
            I wold be curious to se a wireframe of it.
            R 1 Reply Last reply 3 Apr 2025, 13:16 Reply Quote 0
              Rich O Brien Moderator @panixia
              @panixia Its a normal map I made in Substance Designer that I then played with the UV scaling to get the look needed.
                The wires...
                Pretty basic stuff tbh. It was more the materials doing the heavy lifting and a nice studio HDR
                P 1 Reply Last reply 3 Apr 2025, 17:30 Reply Quote 1
                  panixia @Rich O Brien
                  @Rich-O-Brien you used spherical UVs?
                    @panixia the bump only needed to reside with this area so I did flat unwrap for this portion
                    So the object had 2 glass materials
                    G P 2 Replies Last reply 3 Apr 2025, 19:52 Reply Quote 0
                      Gus R @Rich O Brien
                      @Rich-O-Brien Groovy, man. Nice. How did you make the tassels?
                      www.instagram.com/gusrobatto/
                      https://bsky.app/profile/gus-robatto.bsky.social
                      R 1 Reply Last reply 4 Apr 2025, 09:20 Reply Quote 1
                        @Rich-O-Brien Pretty straight forward..
                        I'd expected a more noticeable distortion.. so I was fancying about about geospheres or some other funny way to over-complicate life
                        • L Online
                          Rich, I enjoy seeing your work, wish you would do it more
                            Rich O Brien Moderator @Gus R
                            @Gus-R said in Various Ceiling Lights:
                            I had a starter asset from the client but it was unworkable. So I took a portion and made section I could array along a curve in Blender.
                            I made a couple if variants so the stringy bits didn't look repetitive. I also found a Geonodes setup online that helped add that randomness.
                            SketchUp wasn't up to the task unless you like lots of spinning wheel cursors. These are Cycles renders using the AGX View Transform.
                              Magic.
