    Various Ceiling Lights
    14 Posts 7 Posters 1.1k Views 7 Watching
    • panixiaP
      panixia
      Excellent. How did you do the faceted one in second image?
      I wold be curious to se a wireframe of it.
        Rich O Brien Moderator @panixia
        @panixia Its a normal map I made in Substance Designer that I then played with the UV scaling to get the look needed.
          The wires...
          Pretty basic stuff tbh. It was more the materials doing the heavy lifting and a nice studio HDR
          panixiaP 1 Reply Last reply
          • panixiaP
            panixia @Rich O Brien
            @Rich-O-Brien you used spherical UVs?
              @panixia the bump only needed to reside with this area so I did flat unwrap for this portion
              So the object had 2 glass materials
              Gus RG panixiaP 2 Replies Last reply
              • Gus RG
                Gus R @Rich O Brien
                @Rich-O-Brien Groovy, man. Nice. How did you make the tassels?
                www.instagram.com/gusrobatto/
                www.facebook.com/gusrobatto
                • panixiaP
                  @Rich-O-Brien Pretty straight forward..
                  I'd expected a more noticeable distortion.. so I was fancying about about geospheres or some other funny way to over-complicate life
                  • L
                    Rich, I enjoy seeing your work, wish you would do it more
                    Reply Quote 2
                      Rich O Brien Moderator @Gus R
                      @Gus-R said in Various Ceiling Lights:
                      I had a starter asset from the client but it was unworkable. So I took a portion and made section I could array along a curve in Blender.
                      I made a couple if variants so the stringy bits didn't look repetitive. I also found a Geonodes setup online that helped add that randomness.
                      SketchUp wasn't up to the task unless you like lots of spinning wheel cursors. These are Cycles renders using the AGX View Transform.
                        Magic.
