    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
      SUbD fun with furniture
      tuna1957T 1 Reply Last reply
      Reply Quote 6
      • tuna1957T
        tuna1957 @Rich O Brien
        @Rich-O-Brien Now thatโ€™s one sexy sofa ๐Ÿ‘
        Reply Quote 2
          It would be better with Kylie Minogue on it tho'.......
          HornOxxH 1 Reply Last reply
          • HornOxxH
            HornOxx @Mike Amos
            @Mike-Amos said in SubD examples and models:
            ๐Ÿ‘ ๐Ÿ˜€
            never trust a skinny cook
              Reply Quote 4
              • panixiaP
                panixia
                A few models I made recently for a manufacturer that makes custom sofas to fit on yachts.
                Reply Quote 2
                  Those are great @panixia ๐Ÿ‘
                  panixiaP 1 Reply Last reply
                  • panixiaP
                    panixia
                    Another bunch of screenshots from the same series..
                    All modeled using QFT, VT2, SUbD and a bit of Curviloft, JPP and Artisan mixed in the process.
                    The UV mapping was done in Wrapr..
                    Reply Quote 2
                    • panixiaP
                      panixia @Rich O Brien
                      Thank you a lot @Rich-O-Brien
                      • tuna1957T
                        tuna1957 @panixia
                        @panixia Fantastic work ๐Ÿ‘
                        • panixiaP
                          panixia @tuna1957
                          @tuna1957 thank you โ˜บ๏ธ
                          • alexpacio2013A
                            alexpacio2013
                            @panixia it's the nยฐ1
                            • alexpacio2013A
                              alexpacio2013
                              I'm not as skilled as my master @panixia, but I can still create some items with SubD.
                              Reply Quote 5
                              • panixiaP
                                panixia @alexpacio2013
                                @alexpacio2013 what are those balck dummyes around the tires and helmet?
                                Maybe some Vray for Sketchup decals?
                                alexpacio2013A 1 Reply Last reply
                                • alexpacio2013A
                                  alexpacio2013 @panixia
                                  @panixia yes, vray decals๐Ÿ‘‹
                                  • tuna1957T
                                    tuna1957
                                    Not very spectacular but SubD can make even everyday objects a lot easier to model. Organic shaped mid century modern drawer pull. Pretty common back in the day. Designed to be partially inset into the drawer front. Made attempts to model one years back. No luck. Knocked one out with SubD the other night. No problem. ๐Ÿ‘ ๐Ÿ˜Ž
                                    Reply Quote 3
                                    • panixiaP
                                      panixia
                                      Had been a while since the last time i did a model just for fun. So I picked a super fun one and started working on it in my spare time. ๐Ÿ˜Ž
                                        Anticipation builds......๐Ÿฅ
                                        • panixiaP
                                          panixia
                                          Bowl du Prado.
                                          The infamous Marseille Skatepark.
                                          I''ll do some minor tweaks and a bit of housekeeping (organizing layers, purging, renaming, setting scenes and styles and whatnot)
                                          Then I'll share this model (including the lowpoly cage, the pbr maps and a 3d printable version) for you guys to take a closer look at this workflow.
                                          I will probably do a separate post with the download link and a bunch of screenshots to explain the main steps of this workflow.
                                          Reply Quote 3
                                          • HornOxxH
                                            HornOxx
                                            ๐Ÿ˜ฎBoahhhhh !
                                            Respect Panixia - the project and your presentation here are impressive!
                                            • 79
                                            • 80
                                            • 81
                                            • 82
                                            • 83
                                            • 84
                                            • 81 / 84
