    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.3m Views 79 Watching
    • tuna1957T
      tuna1957
      @hornoxx said:
      ...prima Tuna1957 πŸ‘ not to forget this "rounded seam" (is there any term for this?) on the edges of the upholstery makes such a furniture model so much better πŸ‘
      Thanks HornOxx. I believe Your referring to the β€œwelts” around the cushions…. Welt is the only term I’ve ever used for these. I’m sure there may be other terms used in other parts of the world. What I found interesting in the reference picture I worked from there were no welts around the main body of the chair, just around the cushions. πŸ‘
      • Rich O BrienR Rich O Brien pinned this topic on
      • tuna1957T
        tuna1957
        Revisited my first sofa model from many years ago. Fixed a lot of my rookie SubD mistakes. Added a little more detail here and there. Didn’t want to do a total rebuild. 😎
        Reply Quote 6
          SUbD fun with furniture
          tuna1957T 1 Reply Last reply
          Reply Quote 6
          • tuna1957T
            tuna1957 @Rich O Brien
            @Rich-O-Brien Now that’s one sexy sofa πŸ‘
            Reply Quote 2
              It would be better with Kylie Minogue on it tho'.......
              HornOxxH 1 Reply Last reply
              • HornOxxH
                HornOxx @Mike Amos
                @Mike-Amos said in SubD examples and models:
                πŸ‘ πŸ˜€
                never trust a skinny cook
                  Reply Quote 4
                  • panixiaP
                    panixia
                    A few models I made recently for a manufacturer that makes custom sofas to fit on yachts.
                    Reply Quote 2
                      Those are great @panixia πŸ‘
                      panixiaP 1 Reply Last reply
                      • panixiaP
                        panixia
                        Another bunch of screenshots from the same series..
                        All modeled using QFT, VT2, SUbD and a bit of Curviloft, JPP and Artisan mixed in the process.
                        The UV mapping was done in Wrapr..
                        Reply Quote 2
                        • panixiaP
                          panixia @Rich O Brien
                          Thank you a lot @Rich-O-Brien
                          • tuna1957T
                            tuna1957 @panixia
                            @panixia Fantastic work πŸ‘
                            • panixiaP
                              panixia @tuna1957
                              @tuna1957 thank you ☺️
                              • alexpacio2013A
                                alexpacio2013
                                @panixia it's the nΒ°1
                                • alexpacio2013A
                                  alexpacio2013
                                  I'm not as skilled as my master @panixia, but I can still create some items with SubD.
                                  Reply Quote 5
                                  • panixiaP
                                    panixia @alexpacio2013
                                    @alexpacio2013 what are those balck dummyes around the tires and helmet?
                                    Maybe some Vray for Sketchup decals?
                                    alexpacio2013A 1 Reply Last reply
                                    • alexpacio2013A
                                      alexpacio2013 @panixia
                                      @panixia yes, vray decalsπŸ‘‹
                                      • tuna1957T
                                        tuna1957
                                        Not very spectacular but SubD can make even everyday objects a lot easier to model. Organic shaped mid century modern drawer pull. Pretty common back in the day. Designed to be partially inset into the drawer front. Made attempts to model one years back. No luck. Knocked one out with SubD the other night. No problem. πŸ‘ 😎
                                        Reply Quote 3
                                        • panixiaP
                                          panixia
                                          Had been a while since the last time i did a model just for fun. So I picked a super fun one and started working on it in my spare time. 😎
                                            Anticipation builds......πŸ₯
                                            • 79
                                            • 80
                                            • 81
                                            • 82
                                            • 83
                                            • 84
                                            • 81 / 84
