    Rayscaper, My trip down the road to adjumacation.
    176 Posts 8 Posters 38.7k Views 7 Watching
      Mike Amos @pixelcruncher
      @pixelcruncher
      Gotcha, for some reason 'outliner' was missing from my default tray.
      I completely missed the absence. Pun intended.
      Mike AmosM 1 Reply Last reply
        Mike Amos @Mike Amos
        OK, moving on, in a continuous movement.
        Getting smaller which seems to be a trend, however this theme still has all the basics such as a full bathroom and a study area.
          Repeated via a GPU render, much faster and a lighter render from otherwise the same settings.
          ntxdaveN 1 Reply Last reply
          Reply Quote 2
          • ntxdaveN
            ntxdave @Mike Amos
            @Mike-Amos like the last one better. πŸ‘πŸ‘πŸ‘πŸ‘
            Press F1...thank me later
              Mike Amos @ntxdave
              @ntxdave
              Ta mate, agreed. GPU works best. This is the ground floor level which is smaller in footprint. Also GPU.
                Upper floor, poor scaling of the laptop and a 3.5' bed make it look toylike.
                • pixelcruncherP
                  Great results, @Mike-Amos. Nice showcase of Rayscaper. πŸ™‚ The oven in the staircase is unique, but I guess you have to put it somewhere in tiny homes.
                  The different results between CPU and GPU lighting are an outstanding bug. The CPU uses a different, more sophisticated light selection algorithm that's harder to implement on the GPU. As a result, the light looks different in some situations. It's on my TODO list.
                  Cheers,
                  Thomas
                    @pixelcruncher
                    Thomas mate, the bugs are life in the raw, as natural as bathroom visits when we get older. Sometimes I swear my bladder has a gps, go NEAR the bathroom and........
                    The journey is a good one and enjoyable.
                      Growing the scene somewhat.
                      Still perplexed as to why some metals turn copper/brass without input and quite why the reflectance of shiny finishes shopuld be green.
                      Also, the coffee image from the top of the 'liquid coffee' does not import into Rayscaper which is a nuisance but no doubt will improve when I work out what I got wrong.
                      A higher vantage point definitely demonstrates the built model better when dealing with smaller properties.
                        Another odd angle for some, I am finding that I have to restart sketchup sometimes, Rayscaper slows but a restart of Sketchup cures this and back to the 6 minutes ballpark.
                        Some more odd scaling issues with boots.
                        When I can get the blind texture to render properly, there will be a blind unit in the window.
                        The raw Sketchup vioew will demonstrate what I mean when I mention textures not making it into Rayscaper.
                        • pixelcruncherP
                          pixelcruncher Extension Creator @Mike Amos
                          The SketchUp viewport has four coat hangers; in the Rayscaper viewport, there are six. Were these screenshots captured at the same time?
                          Which textures are you referring to? A user may configure a totally different look for a material in Rayscaper, so the one-to-one correspondence isn't always a given.
                          Cheers,
                          Thomas
                            @pixelcruncher
                            On the cooktop, the metal texture was set to aluminium, this often has a bronze look to it, colour changes for some reason I cannot get yet. Plastic finish gets a green reflectance.
                            I am running into what I believe is 'texture bloat' which is going to take my changing things before I can fix that.
                            For a while I am going back to making cars while I figure out how to build architecture realistically given certain constraints.
                            As for the coat hooks, there are six and this may be something to do with the long running issues I have with this pc.
                              OK, running into the faux illumination from png transparecny, not idea why so perhaps a glitch?
                              Still having massive freeze events for a cause I cannot guess.
                                I have updated the NVidia softwqare for the onboard graphics, funnily enough NOT selected in Rayscaper. Lost a texture or possibly more. Clueless in Settle INHO.
                                    What’s up with the chair material? Is it emitting fake light?
                                      Not set up to emit a fake light value but, exactly the same as the Ford A hotrod I tried to render in Rayscaper, it acquires the value.
                                      I believe it is a bug connected with transparency png files.
                                      • pixelcruncherP
                                        @Mike-Amos That's a good pointer, it does seem to get light emitting properties when using transparent PNGs. Will look into this.
                                          @pixelcruncher
                                          Well, randomness is a fact of so it does not surprise me that items saved in a model vanish.
                                          Mostly lights but now, huge chunks of geometry.
                                            Rebooted Sketchup, lost items returned.....
                                            Reply Quote 3
                                            • 9 / 9
