    Rayscaper, My trip down the road to adjumacation.
    176 Posts 8 Posters 38.7k Views 7 Watching
      Mike Amos @Mike Amos
      Trying the fake emitter thing on the exterior lights but not much of a result. I placed sphere lights in the same location as the wall lights but limited success so far.
      This is how it looks after 70 passes, it will take a couple of hours for the full render. Exposure reduced from 2.00 to 1.00.
      Mike AmosM pixelcruncherP 2 Replies Last reply
        @Mike-Amos
        My idea of a night/evening render. Courtesy of Affinity photo.
        • pixelcruncherP
          pixelcruncher Extension Creator @Mike Amos
          @Mike-Amos
          You would want to place the sphere lights (point lights) in the middle of the lanterns. If you place them inside the bulb, then add some transparency to the light bulb.
          I attached an example (mike_lantern_example.skp) of how to configure sphere lights. In the scene below, I have three lights with the following configuration:
          • Light temperature 3000K to get a warm color.
          • 50W power for each light.
          • Radius of 0.10m to make the shadows softer.
          I dimmed the environment to low strength to make the lights stand out.
          Light configuration in SketchUp:
          Light settings in Rayscaper:
          Result:
          That should help you tune the lights in your scene.
          Regards,
          Thomas
          Mike AmosM 1 Reply Last reply
            Mike Amos @pixelcruncher
            @pixelcruncher
            Thanks for that, how did you rename the lights tho'?
              Not a full 500 samples but getting there. I desaturated in Affinity photo.
              • pixelcruncherP
                @Mike-Amos
                It's getting there. I would pick a warmer light color and make that interior light less strong.
                Rayscaper takes the name of the light components. You can rename them in the outliner:
                The same for materials, Rayscaper takes the names of the SketchUp materials.
                Cheers,
                Thomas
                  @pixelcruncher
                  Gotcha, for some reason 'outliner' was missing from my default tray.
                  I completely missed the absence. Pun intended.
                    OK, moving on, in a continuous movement.
                    Getting smaller which seems to be a trend, however this theme still has all the basics such as a full bathroom and a study area.
                      Repeated via a GPU render, much faster and a lighter render from otherwise the same settings.
                      ntxdaveN 1 Reply Last reply
                      Reply Quote 2
                      • ntxdaveN
                        ntxdave @Mike Amos
                        @Mike-Amos like the last one better. πŸ‘πŸ‘πŸ‘πŸ‘
                        Press F1...thank me later
                          Mike Amos @ntxdave
                          @ntxdave
                          Ta mate, agreed. GPU works best. This is the ground floor level which is smaller in footprint. Also GPU.
                            Upper floor, poor scaling of the laptop and a 3.5' bed make it look toylike.
                            • pixelcruncherP
                              Great results, @Mike-Amos. Nice showcase of Rayscaper. πŸ™‚ The oven in the staircase is unique, but I guess you have to put it somewhere in tiny homes.
                              The different results between CPU and GPU lighting are an outstanding bug. The CPU uses a different, more sophisticated light selection algorithm that's harder to implement on the GPU. As a result, the light looks different in some situations. It's on my TODO list.
                              Cheers,
                              Thomas
                                @pixelcruncher
                                Thomas mate, the bugs are life in the raw, as natural as bathroom visits when we get older. Sometimes I swear my bladder has a gps, go NEAR the bathroom and........
                                The journey is a good one and enjoyable.
                                  Growing the scene somewhat.
                                  Still perplexed as to why some metals turn copper/brass without input and quite why the reflectance of shiny finishes shopuld be green.
                                  Also, the coffee image from the top of the 'liquid coffee' does not import into Rayscaper which is a nuisance but no doubt will improve when I work out what I got wrong.
                                  A higher vantage point definitely demonstrates the built model better when dealing with smaller properties.
                                    Another odd angle for some, I am finding that I have to restart sketchup sometimes, Rayscaper slows but a restart of Sketchup cures this and back to the 6 minutes ballpark.
                                    Some more odd scaling issues with boots.
                                    When I can get the blind texture to render properly, there will be a blind unit in the window.
                                    The raw Sketchup vioew will demonstrate what I mean when I mention textures not making it into Rayscaper.
                                    • pixelcruncherP
                                      The SketchUp viewport has four coat hangers; in the Rayscaper viewport, there are six. Were these screenshots captured at the same time?
                                      Which textures are you referring to? A user may configure a totally different look for a material in Rayscaper, so the one-to-one correspondence isn't always a given.
                                      Cheers,
                                      Thomas
                                        @pixelcruncher
                                        On the cooktop, the metal texture was set to aluminium, this often has a bronze look to it, colour changes for some reason I cannot get yet. Plastic finish gets a green reflectance.
                                        I am running into what I believe is 'texture bloat' which is going to take my changing things before I can fix that.
                                        For a while I am going back to making cars while I figure out how to build architecture realistically given certain constraints.
                                        As for the coat hooks, there are six and this may be something to do with the long running issues I have with this pc.
                                          OK, running into the faux illumination from png transparecny, not idea why so perhaps a glitch?
                                          Still having massive freeze events for a cause I cannot guess.
                                            I have updated the NVidia softwqare for the onboard graphics, funnily enough NOT selected in Rayscaper. Lost a texture or possibly more. Clueless in Settle INHO.
                                            • 8 / 9
