    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v14.7a - 09 Nov 24
      LibFredo6 14.7a is a major release. It includes changes related to:
      • ThruPaint v2.8a
      • New plugins
      • Future compatibility
      • Bug Fixing
      F 1 Reply Last reply Reply Quote 0
      • F Offline
        FlorinAp @fredo6
        @fredo6 This one has at least one bug - doesn't allow Lord of the Toolbars to add/remove icons, neither in the toolbars and neither in palettes.!
        Edit: For SU 2023.!
        fredo6F 1 Reply Last reply Reply Quote 0
        • fredo6F Offline
          fredo6 @FlorinAp
          @FlorinAp
          You are correct. I simply forgot to publish LOTT to adjust with necessary changes in LibFredo6.
          LOTT is now published as v2.8a.
            a4jp.com
            Can you make it so we can add time to the clock? I opened the clock on old projects but I want to add the time I have worked on those files before.
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v14.8a - 26 Nov 24
              LibFredo6 14.8a is a major release. It includes changes related to:
              • FredoBatch v1.1a
              • Bug Fixing
              I 1 Reply Last reply Reply Quote 0
                Rachel23
                I'm disappointed. I downloaded it and it said its expired. So i bought your extension for 15 dollars and then redownloaded it and it still says expired and I've relogged in many times.
                  Rich O Brien Moderator @Rachel23
                  @Rachel23 Licenses need to be activated per https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                  • N Offline
                    Nicolla
                    Hi guys.
                    I downloaded recent update but it messed something up with Joint Push Pull
                    I can't make shell and thicken the most simplest shapes, like the cube with 3 faces removed
                    Have you noticed this too and how can I solve it? Thanks πŸ™‚
                    TIGT 1 Reply Last reply Reply Quote 0
                      TIG Moderator @Nicolla
                      @Nicolla
                      If you try it with the Ruby Console [Extensions > Developer submenu] open do you see any error messages, or do you get any other error message dialogs when trying it ?
                      If you attach a simple SKP, with the problems you are experiencing, and a step by step of instructions, it would help us understand your problems...
                      • I Offline
                        ideas_arte @fredo6
                        @fredo6
                        Extension Errors Report
                        SketchUp: 24.0.484
                        OS: Windows 10
                        Ruby: 3.2.2
                        Extension: Fredo6 LibFredo6 (14.8a - 26 Nov 24)
                        Error: NoMethodError (undefined method split' for ["Animator"]:Array) c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in block in super_flatten'
                        c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in each' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:937:in super_flatten'
                        c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:860:in load_from_config' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins'
                        c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each' c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins'
                        c:/users/ivand/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup' C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process'
                        C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in <module:LibFredo6_Loader>' C:/Users/ivand/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                        • fredo6F Offline
                          fredo6 @ideas_arte
                          @ideas_arte
                          Can you check the version of Animator you have in your enviroment.
                          The best is to invoke the menu Window > LibFredo6 Settngs > Fredo6 Plugin information for Sketchucation Support.
                          • I Offline
                            ideas_arte @fredo6
                            @fredo6
                            Fredo6 Plugins Information on 2024-12-05 14:25:10 -0600
                            • Sketchup: 24.0.484
                            • LibFredo6: v14.8a
                            • LibFredo6 Binary loaded
                            • Sketchucation ExtensionStore: 4.4.1
                            • SCFLicense: v6.4a - 74
                            • Fredo6 Plugins
                              FredoTools v4.5c
                              ThruPaint v2.8a
                              TopoShaper v2.7a
                              Signature File: absent
                            • I Offline
                              ideas_arte @ideas_arte
                              @ideas_arte
                              I had to desable the Animator:
                              • fredo6F Offline
                                fredo6 @ideas_arte
                                @ideas_arte
                                Do you know what version of Animator you had. You may try with installing its latest version.
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v14.9a - 06 Dec 24
                                  LibFredo6 14.9a is a major release. It includes changes related to:
                                  • FredoBatch v1.2a
                                  • Bug Fixing
                                    Kevin Reza Arnanda Newcomers
                                    THANK YOU
                                    • fredo6F Offline
                                      NEW RELEASE: LibFredo6 v15.0a - 31 Dec 24
                                      LibFredo6 15.0a is a major release. It includes changes related to:
                                      • FredoBatch v1.3a
                                      • Bug Fixing
                                        kngpw
                                        I cannot install the latest libredo6 15.0a on my new computer.
                                        I have tried to reinstall the plugin + Sketchup many times. It keeps giving me the same results.
                                        SketchUp: 24.0.594
                                        OS: Windows 11
                                        Ruby: 3.2.2
                                        Extension: Fredo6 LibFredo6 (15.0a - 31 Dec 24)
                                        Error: ArgumentError (invalid byte sequence in UTF-8)
                                        c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in match' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:842:in block (2 levels) in load_from_config'
                                        c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in each' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:841:in block in load_from_config'
                                        c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in foreach' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:839:in load_from_config'
                                        c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in block in load_all_plugins' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in each'
                                        c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1256:in load_all_plugins' c:/users/user1/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:330:in startup'
                                        C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in process' C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:76:in module:LibFredo6_Loader'
                                        C:/Users/user1/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
                                        • fredo6F Offline
                                          Do you have a Windows computername with non-roman characters?
                                          K 1 Reply Last reply Reply Quote 0
                                            kngpw @fredo6
                                            @fredo6
                                            I do! I only change the real Windows computername posting here for privacy reason.
                                            • 108
                                            • 109
                                            • 7 / 109
