    Rayscaper, My trip down the road to adjumacation.
    176 Posts 8 Posters 1.0k Views 7 Watching
    • pixelcruncherP Offline
      pixelcruncher Extension Creator @Mike Amos
      @Mike-Amos sounds like a bug. Let's fix that.
      Do you mind sending me your most recent scene again?
      • What is the name of the light component or components that disappeared?
      • Is the skirting board modeled as geometry at the bottom of the wall? I will check that out as well once I have your model file.
      Cheers,
      Thomas
        Mike Amos @pixelcruncher
        @pixelcruncher
        The lights are directional lights, the skirting board is geometry that has been removed from Sketchup the model, pardon the pun.
        I am concerned that memory handling is an issue and will probably remain that way until the basic hardware is fixed, should go off for repair this week. Crossed fingers included.
          Mike Amos @Mike Amos
          @Mike-Amos
          OK, replaced the missing skirting board and put the lights back. Wotcha fink folks?
          • Bryan KB Offline
            Overall, really nice, but I would change the light temp (seems kinds of orange-ish yellow in this shot) and up the exposure just a but more.
            Just a little less orange in the light. Natural light is orange-ish yellow.
              Mike Amos @Bryan K
              @Bryan-K
              Ta mate, feedback always helpful. Building and rendering the scene can lead to missing/ignoring stuff.
              Rich O BrienR pixelcruncherP Bryan KB 3 Replies Last reply Reply Quote 0
              • Rich O BrienR Online
                @Mike-Amos If the sun coming in the window is a directional light you should raise the angle values slightly to soften the shadow.
                I sometime mix both HDRIs and Directional Lights to get the light the way I want it.
                HDRs are great but some might offer you the background you want but not the light direction or power. Adding a directional to give you more artistic controls is sometimes a good hack.
                Be mindful of power values and balance it.
                A directional light with zero angle results in crisp clean shadows...
                Increasing it to 2-3 will soften edges....
                massimoM 1 Reply Last reply Reply Quote 1
                • massimoM Offline
                  massimo Moderator @Rich O Brien
                  Rich's ones are good advices. Even if the best HDRIs, for example P.Guthrie's and CGSource's ones just to name two, don't need any extra sun because produce nice shadows, most of them need a bit of boost.
                  Does Rayscaper have something like this however?
                  I mean that you can move the sun in the physical sky until it will match the one in the HDRI. Because if not would be really difficult to align the two suns and this could lead to a fake result.
                    Rich O Brien Moderator @massimo
                    @massimo said in Rayscaper, My trip down the road to adjumacation.:
                    No, it's guesswork if you want to align HDR sun and a directional light.
                    massimoM Mike AmosM 2 Replies Last reply Reply Quote 1
                    • massimoM Offline
                      @Rich-O-Brien Ok, maybe a suggestion for the next release then.πŸ˜‰
                        Mike Amos @Rich O Brien
                        @Rich-O-Brien
                        On the subject of artificial lighting, is there a way to introduce a 'glow' to the light unit somehow? Something to essentially, mimic a lightbulb.
                        Mike AmosM Rich O BrienR pixelcruncherP 3 Replies Last reply Reply Quote 0
                            @Mike-Amos said in Rayscaper, My trip down the road to adjumacation.:
                            A couple of versions back there was a way. But at the moment it seems to me there's a bug with having both emissive materials and lights in a scene.
                            I need to test more to see if that is the case.
                            But to your bulb appearance query. I couldn't get any shader to respect how light should behave as it passes through a frosted glass. When I did get close the render times weren't worth the effort. It also crashed a few times during testing so that dampens my enthusiasm a tad.
                            I will try though. Thomas would benefit from seeing where shaders are not doing what is expected from a users point of reference.
                              @Rich-O-Brien
                              I was wondering if a different layer may help but going back to renditioner, which had a similar method, it may make no discernable difference.
                                @Mike-Amos
                                What I have so far, I placed a flat plain just behind the emitter light (Directional) and reduced the opacity a lot. there is some room for improvement with temp etc but a start.
                                  @Mike-Amos
                                  Here was a test I did yesterday. The bulb has a Glass shader with Roughness and Transparent Shadows.
                                  Inside I put a Sphere Light. Its not behaving right though. I still believe that lights and the values needed are off.
                                  pixelcruncherP 1 Reply Last reply Reply Quote 0
                                    @Mike-Amos The missing skirting board and lights, was that caused by a bug in Rayscaper?
                                      @Mike-Amos
                                      You can use fake emission. - This will give objects a glowy appearance, but they are not really lights, so they won't shine on the surrounding objects. Using the fake emission option will also reduce render times.
                                      In the below image, the left sphere has normal emission and the right sphere has fake emission.
                                        pixelcruncher Extension Creator @Rich O Brien
                                        @Rich-O-Brien This looks indeed buggy, thanks for the information and I will look into this problem.
                                        • Bryan KB Offline
                                          Bryan K @Mike Amos
                                          @Bryan-K
                                          I hear ya. Happens to me all the time. πŸ˜‰
                                          • Bryan KB Offline
                                            Oh that last one is damn good!
                                            • 4 / 9
