    [Tutorial] Animator Quick Start
    renderpluginsextensions
    136 Posts 39 Posters 896.5k Views 40 Watching
    • F
      Frankoi
      I have installed the fredolib and the animator plugin on my macbookpro, on SUPRO2017, i can see the animator tool bar wtih four buttons, but when I click on the first, nothing happens, I can't see the time line and all the other panels!.
      Could someone help me?
      • F
        Frankoi
        Bonjour,
        Je reposte le message en fançais si besoin, suite à l'installation de fredolib et de animator sur mon mac avec sketchuppro 2017, je ne vois que la toolbar avec 4 boutons, mais pas tout l'environnement de travail.
        Quelqu'un peux-t-il me répondre sur ce sujets?
        Merci bcp
          smai31
          Merci pour cet excellent conseil !
          Bien à toi
          Stéphane
          • fredo6F
            What happens if you click on the first button of the toolbar.
            If nothing happens, the redo the same, but with the Ruby console opened, so that you can see if there are error messages.
              sketchnut
              Animator does not start when pressing the clip Icon.
              Using skethup 2020.
              • fredo6F
                Using skethup 2020.
                Can you open the Ruby console and check if there are error messages.
                • L
                  lts9876 Newcomers
                  I like the videos; they help a lot. I am not sure if this is the place to ask this question. I installed animator. I used it a couple days. Know when I click on the clip editor. It will not open. I am not sure what to do.
                  • fredo6F
                    Could you migrate to LibFredo6 v13.6a. It should solve the problem.
                    • L
                      lts9876 Newcomers
                      Thank you that worked!
                      • SJS66S
                        SJS66
                        Hi all, I've been doing some Animator training, making a tip truck reverse, tip up then down, then drive away. I've managed to get it to reverse & tip up...although the hydraulic tipper ram doesn't extend right. I used a combination of rotate, follow path & layer visibility to make it extend.
                        I made a video of it so you can see the results so far.
                        Any suggestions on how to improve most welcome.
                        Cheers.
                        • SJS66S
                          SJS66
                          Well, I isolated the tip truck hydraulic ram to make things easier to see & replicated the movement for it as if emptying the truck's load (tipping) but I'd like to see if it could be made to extend whilst it is rotating instead of rotating then extending like I've got it to do.
                          Here's the latest video link.
                          • ntxdaveN
                            ntxdave
                            Did you make sure that the expanding and rotation are being done at the same time? Take the two clips an drag them so they are side by side in the timeline.
                            I cannot try it (my laptop died) but I seem to remember doing this before.
                            Press F1...thank me later
                            • fredo6F
                              Be careful that when you create a rotation, the pivot point can either be referenced by absolute position in the model or relative position by a given object (which can itself be moving).
                              • ntxdaveN
                                ntxdave
                                SjS66, I would recommend that you have 3 clips. One to rotate the truck bed, a second to rotate the hydraulic ram, and the third to expand the hydraulic ram. Now make sure that all three of them have the same starting time in the timeline which can be accomplished by dragging each of the clips to be parallel to each other in the time line. I would also recommend that each of the clips have the same duration.
                                Hope this helps. Perhaps you could share a screen capture of your Animator dialog/timeline for your animation.
                                • H
                                  henrycook665 Newcomers
                                  I really like these types of Video Animation Services because I am also doing this type of work just to attract the audience to my site which is a great technique too many animators are engaged to improve it but I don't need to do it because I am an expert.
                                  • C
                                    CHD123
                                    Is there an option for animation on a track?
                                    Does that mean that the camera travels on a certain line and passes between all the rooms?
                                    • fredo6F
                                      Camera Along Track is not implemented yet.
                                      • C
                                        CHD123
                                        Any idea when it's going to be?
                                          If you create a object to follow a path then use Camera Tracking Object and position your view you get that 'tour' effect
                                          Just hide the tracking object for the export.
                                          • C
                                            CHD123
                                            ?איך עושים עקוב אחר המצלמה
                                            • 6 / 7
