    [Tutorial] Animator Quick Start
    renderpluginsextensions
    136 Posts 39 Posters 896.5k Views 40 Watching
      smai31
      Merci pour cet excellent conseil !
      Bien à toi
      Stéphane
      • fredo6F
        @frankoi said:
        I have installed the fredolib and the animator plugin on my macbookpro, on SUPRO2017, i can see the animator tool bar wtih four buttons, but when I click on the first, nothing happens, I can't see the time line and all the other panels!.
        What happens if you click on the first button of the toolbar.
        If nothing happens, the redo the same, but with the Ruby console opened, so that you can see if there are error messages.
          sketchnut
          Animator does not start when pressing the clip Icon.
          Using skethup 2020.
          • fredo6F
            Using skethup 2020.
            Can you open the Ruby console and check if there are error messages.
            • L
              lts9876 Newcomers
              I like the videos; they help a lot. I am not sure if this is the place to ask this question. I installed animator. I used it a couple days. Know when I click on the clip editor. It will not open. I am not sure what to do.
              • fredo6F
                Could you migrate to LibFredo6 v13.6a. It should solve the problem.
                • L
                  lts9876 Newcomers
                  Thank you that worked!
                  • SJS66S
                    SJS66
                    Hi all, I've been doing some Animator training, making a tip truck reverse, tip up then down, then drive away. I've managed to get it to reverse & tip up...although the hydraulic tipper ram doesn't extend right. I used a combination of rotate, follow path & layer visibility to make it extend.
                    I made a video of it so you can see the results so far.
                    Any suggestions on how to improve most welcome.
                    Cheers.
                    • SJS66S
                      SJS66
                      Well, I isolated the tip truck hydraulic ram to make things easier to see & replicated the movement for it as if emptying the truck's load (tipping) but I'd like to see if it could be made to extend whilst it is rotating instead of rotating then extending like I've got it to do.
                      Here's the latest video link.
                      • ntxdaveN
                        ntxdave
                        Did you make sure that the expanding and rotation are being done at the same time? Take the two clips an drag them so they are side by side in the timeline.
                        I cannot try it (my laptop died) but I seem to remember doing this before.
                        Press F1...thank me later
                        • fredo6F
                          Be careful that when you create a rotation, the pivot point can either be referenced by absolute position in the model or relative position by a given object (which can itself be moving).
                          • ntxdaveN
                            ntxdave
                            SjS66, I would recommend that you have 3 clips. One to rotate the truck bed, a second to rotate the hydraulic ram, and the third to expand the hydraulic ram. Now make sure that all three of them have the same starting time in the timeline which can be accomplished by dragging each of the clips to be parallel to each other in the time line. I would also recommend that each of the clips have the same duration.
                            Hope this helps. Perhaps you could share a screen capture of your Animator dialog/timeline for your animation.
                            • H
                              henrycook665 Newcomers
                              I really like these types of Video Animation Services because I am also doing this type of work just to attract the audience to my site which is a great technique too many animators are engaged to improve it but I don't need to do it because I am an expert.
                              • C
                                CHD123
                                Is there an option for animation on a track?
                                Does that mean that the camera travels on a certain line and passes between all the rooms?
                                • fredo6F
                                  Camera Along Track is not implemented yet.
                                  • C
                                    CHD123
                                    Any idea when it's going to be?
                                      If you create a object to follow a path then use Camera Tracking Object and position your view you get that 'tour' effect
                                      Just hide the tracking object for the export.
                                      • C
                                        CHD123
                                        ?איך עושים עקוב אחר המצלמה
                                          https://i.imgur.com/WseM7iU.png
                                          I use the Temp exit feature in Animator to then use the native Position Camera tool.
                                          Then return to the Animator timeline add a New Camera and set it with this...
                                          https://i.imgur.com/SrVV0kD.png
                                          It's a bit funky to do but it does work
                                            Migmat
                                            PDF ANIMATOR TUTORIAL
                                            . After discussing it with Fredo6, I'm now publishing it in this post, as it seems the most fitting choice.
                                            Here's the link to the explanatory video and tutorial (in the video's description) in their Spanish version, published in my video youtube channel.
                                            I'm currently working on the English version. This order is necessary due to layout considerations, as English tends to use fewer words. I hope it aids other designers in creating excellent animations with this superb plugin. I trust it will be helpful to you and that you'll share it with fellow users.
                                            TUTORIAL de ANIMATOR EN PDF
                                            ESPAÑOL:Finalmente he terminado el Tutorial de Animator y el video de explicacion y, tras consultarlo con Fredo6, procedo a publicarlo en este post, porque me parece el mas adecuado.
                                            Este es el enlace al video explicativo y al tutorial (en la descripcion del video) en su version en Español publicado en mi canal de Youtube.
                                            https://youtu.be/Ne5k4S_DZWw
                                            Estoy preparando la version en ingles. Debe hacerse en este orden debido a temas de maquetación, puesto que en ingles se usan menos palabras. Espero que ayude a otros diseñadores a hacer buenas animaciones con este magnifico plugin. Espero que os sea util y que lo difundais a otros usuarios
                                            • 7 / 7
