    2.2k Posts 487 Posters 931.0k Views 492 Watching
      janot10
      Same here!
        janot10
        Same here!
          I appears there's an issue with the server. Have patience. It'll be fixed as soon as possible.
            mavie
            Ditto to all the above. Ha. I only need to use 4 of Fredo's extensions this morning. 😞
            Hoping server error is fixed soon, good luck!!
              We're working on it. Sorry for inconvenience. 😳 😳 😳
              • E Offline
                estraulino
                Hi, I also having problems with the license, getting notifications of an expired trial, Wrong license ID, etcetera...
                But another weird thing that has been happening is that the UI of round corner is incomplete, the background appears, but no info or buttons or icons appears, and there is no way to change the values.
                I really hope the server is back up again soon, because I use this extensions everyday. I don't really get why would this extension need to phone home, just to end up broken.
                  So it looks like an increase in server load is causing the issue.
                  You can validate but at times it fails. So give it an hour to settle while we fine tune things
                    Looks to be resolved.
                      mavie
                      Yay!! Thanks, guys! 😄
                        Digdaman
                        Dear Fredo
                        I had a problem that my license seats filling because it's recognizede as a different PC when I restarted sketchup.
                        The problem seems to be resolved for now.
                        It was causede by sketchup floating license.
                        Once I checked out the sketchup floating license when validate Fredo6 license, even if I restart sketchup, the plugin worked correctly as the same PC.
                        So, Please release all my seats from all computers so I can start the process from scratch.
                          Gábor
                          Have you tried to release your seats at https://sketchucation.com/webshop/my-licences.php ? If you used the latest SketchUcation Tools for activation, you should be able to release them there.
                            Digdaman
                            Thank you for your reply.
                            But, there were only current releasable licenses.
                            I want to release a seat that cannot be released beccause it was recognizede as a different PC due to a problem when sketchup restarted.
                            releasable
                            not releasable
                            • fredo6F Offline
                              @digdaman
                              Could you indicate which seats (or HWID) would wish to release.
                              I noticed that you validated licenses on 3 different computers on 14-15 November for RoundCorner and JointPushPull.
                                banyj
                                Hello,
                                can I ask you (fredo6), if you could release license seats? I don´t know why, but there are seats, which I can´t release. License seats, whitch I use are HW ID: SJ1663681747.0A, other block me free spot to actifvate on another PC. I use latest versions of sketchucation and libfredo6.
                                Thanks for your help!
                                • fredo6F Offline
                                  I did release all seats, except those assigned to HWID = SJ1663681747.0A
                                    Digdaman
                                    @fredo6 said:
                                    @digdaman
                                    [attachment=0:2bm3spg0]<!-- ia0 -->digdaman licenses.png<!-- ia0 -->[/attachment:2bm3spg0]
                                    I want to release these licenses
                                    RoundCorner
                                    Seat ID: 64651; HW ID: FF1668415971.0P; Date of activation: 14/11/2022
                                    Seat ID: 64825; HW ID: GR1668487000.0A; Date of activation: 15/11/2022
                                    Seat ID: 64835; HW ID: RJ1668487704.0Y; Date of activation: 15/11/2022
                                    JointPushPull
                                    Seat ID: 64780; HW ID: FF1668415971.0P; Date of activation: 15/11/2022
                                    Seat ID: 64829; HW ID: GR1668487000.0A; Date of activation: 15/11/2022
                                    Seat ID: 64859; HW ID: IK1668491714.0Y; Date of activation: 15/11/2022
                                    These licenses became dysfunctional and notrelease when skecthup restarted.
                                    • fredo6F Offline
                                      @Digdaman
                                      Done
                                      • Z Offline
                                        ZoOZ85 Newcomers
                                        Bonjour,
                                        Je viens d'acheter la licence pour les différentes extensions de Frédo6 mais aucun plugin ne fonctionnent. J'ai vu qu'il y avait des soucis en ce moment avec les validations de licence mais pour ma part celle-ci s'est installer et validé correctement.
                                        Je précise que la dernière version du jeu d’outils SketchUcation et de LibFredo sont elles aussi bien installés. Je précise aussi que je suis sur la version d'essai de SketchUp pro 2022, mais j'ai le même problème sur SketchUp pro 2018.
                                        Je tourne sous Windows 11 si jamais !
                                        Quelqu'un aurait-il des problèmes similaires ??
                                        Merci pour votre aide !
                                          Bonjour,
                                          Hello,
                                          I just bought the license for the different Frédo6 extensions but no plugins work. I saw that there were problems at the moment with the license validations but for my part it was installed and validated correctly.
                                          I would point out that the latest version of the SketchUcation toolset and LibFredo are also installed. I also specify that I am on the trial version of SketchUp pro 2022, but I have the same problem on SketchUp pro 2018.
                                          I'm running Windows 11 if ever!
                                          Anyone having similar problems??
                                          Thanks for your help !
                                          Hopefully Fredo/Gábor will respond...
                                          Espérons que Fredo/Gábor répondra...
                                          • fredo6F Offline
                                            Pouvez-vous préciser ce qui ne fonctionne pas.
                                            Avant de lancer un plugin, pouvez-vous ouvrir la console Ruby pour d'éventuels messages d'erreur.
                                            Merci.
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 78
                                            • 109
                                            • 110
                                            • 76 / 110
