    2.2k Posts 487 Posters 929.6k Views 492 Watching
      I appears there's an issue with the server. Have patience. It'll be fixed as soon as possible.
        mavie
        Ditto to all the above. Ha. I only need to use 4 of Fredo's extensions this morning. 😞
        Hoping server error is fixed soon, good luck!!
          We're working on it. Sorry for inconvenience. 😳 😳 😳
          • E Offline
            estraulino
            Hi, I also having problems with the license, getting notifications of an expired trial, Wrong license ID, etcetera...
            But another weird thing that has been happening is that the UI of round corner is incomplete, the background appears, but no info or buttons or icons appears, and there is no way to change the values.
            I really hope the server is back up again soon, because I use this extensions everyday. I don't really get why would this extension need to phone home, just to end up broken.
              So it looks like an increase in server load is causing the issue.
              You can validate but at times it fails. So give it an hour to settle while we fine tune things
                Looks to be resolved.
                  mavie
                  Yay!! Thanks, guys! 😄
                    Digdaman
                    Dear Fredo
                    I had a problem that my license seats filling because it's recognizede as a different PC when I restarted sketchup.
                    The problem seems to be resolved for now.
                    It was causede by sketchup floating license.
                    Once I checked out the sketchup floating license when validate Fredo6 license, even if I restart sketchup, the plugin worked correctly as the same PC.
                    So, Please release all my seats from all computers so I can start the process from scratch.
                      GĂĄbor
                      Have you tried to release your seats at https://sketchucation.com/webshop/my-licences.php ? If you used the latest SketchUcation Tools for activation, you should be able to release them there.
                        Digdaman
                        Thank you for your reply.
                        But, there were only current releasable licenses.
                        I want to release a seat that cannot be released beccause it was recognizede as a different PC due to a problem when sketchup restarted.
                        releasable
                        not releasable
                        • fredo6F Offline
                          @digdaman
                          Could you indicate which seats (or HWID) would wish to release.
                          I noticed that you validated licenses on 3 different computers on 14-15 November for RoundCorner and JointPushPull.
                            banyj
                            Hello,
                            can I ask you (fredo6), if you could release license seats? I donÂŽt know why, but there are seats, which I canÂŽt release. License seats, whitch I use are HW ID: SJ1663681747.0A, other block me free spot to actifvate on another PC. I use latest versions of sketchucation and libfredo6.
                            Thanks for your help!
                            • fredo6F Offline
                              I did release all seats, except those assigned to HWID = SJ1663681747.0A
                                Digdaman
                                @fredo6 said:
                                @digdaman
                                [attachment=0:2bm3spg0]<!-- ia0 -->digdaman licenses.png<!-- ia0 -->[/attachment:2bm3spg0]
                                I want to release these licenses
                                RoundCorner
                                Seat ID: 64651; HW ID: FF1668415971.0P; Date of activation: 14/11/2022
                                Seat ID: 64825; HW ID: GR1668487000.0A; Date of activation: 15/11/2022
                                Seat ID: 64835; HW ID: RJ1668487704.0Y; Date of activation: 15/11/2022
                                JointPushPull
                                Seat ID: 64780; HW ID: FF1668415971.0P; Date of activation: 15/11/2022
                                Seat ID: 64829; HW ID: GR1668487000.0A; Date of activation: 15/11/2022
                                Seat ID: 64859; HW ID: IK1668491714.0Y; Date of activation: 15/11/2022
                                These licenses became dysfunctional and notrelease when skecthup restarted.
                                • fredo6F Offline
                                  @Digdaman
                                  Done
                                  • Z Offline
                                    ZoOZ85 Newcomers
                                    Bonjour,
                                    Je viens d'acheter la licence pour les différentes extensions de Frédo6 mais aucun plugin ne fonctionnent. J'ai vu qu'il y avait des soucis en ce moment avec les validations de licence mais pour ma part celle-ci s'est installer et validé correctement.
                                    Je prĂ©cise que la derniĂšre version du jeu d’outils SketchUcation et de LibFredo sont elles aussi bien installĂ©s. Je prĂ©cise aussi que je suis sur la version d'essai de SketchUp pro 2022, mais j'ai le mĂȘme problĂšme sur SketchUp pro 2018.
                                    Je tourne sous Windows 11 si jamais !
                                    Quelqu'un aurait-il des problĂšmes similaires ??
                                    Merci pour votre aide !
                                      Bonjour,
                                      Hello,
                                      I just bought the license for the different Frédo6 extensions but no plugins work. I saw that there were problems at the moment with the license validations but for my part it was installed and validated correctly.
                                      I would point out that the latest version of the SketchUcation toolset and LibFredo are also installed. I also specify that I am on the trial version of SketchUp pro 2022, but I have the same problem on SketchUp pro 2018.
                                      I'm running Windows 11 if ever!
                                      Anyone having similar problems??
                                      Thanks for your help !
                                      Hopefully Fredo/GĂĄbor will respond...
                                      Espérons que Fredo/Gåbor répondra...
                                      • fredo6F Offline
                                        Pouvez-vous préciser ce qui ne fonctionne pas.
                                        Avant de lancer un plugin, pouvez-vous ouvrir la console Ruby pour d'éventuels messages d'erreur.
                                        Merci.
                                        • Z Offline
                                          ZoOZ85 Newcomers
                                          Les plugins que j'utilise sont : Fredospline, Fredocorner et Curvilof.
                                          Voila une capture de la console ruby une fois ouverte puis aprÚs avoir cliqué sur l'un des trois outils.
                                          Et voici le message d'erreur lors de l'installation d'un plugin
                                          Sinon lorsque je souhaite utiliser l'un de ces trois outils, en cliquant simplement sur l'un d'eux rien ne se passe.
                                          Dites-moi si vous avez besoin de plus de détail
                                          Merci d'avance pour votre aide
                                            I'm sure Fredo will reply more authoritatively, but meanwhile...
                                            The problem with the LIBFREDO6_DATA_Dir folder error, suggests that it [and its enclosed files] do not have proper permissions to read/write.
                                            This usually results from you not having previously installed SketchUp properly...
                                            To try and reverse this do the following...
                                            Close SketchUp.
                                            Find its installer exe file - usually in your Downloads folder.
                                            Select its icon, right-click > context-menu > 'Run as administrator'...
                                            In the resultant dialog choose 'Repair'...
                                            This should fix most of the permission issues with the installation, whilst leaving your Plugins folder unaffected.
                                            Unfortunately some folders/files saved outside of the main SketchUp paths might not get fixed when you do this.
                                            So to resolve the issue with C:\Users\levas\AppData\Local\LIBFREDO6_DATA_Dir, find that folder and delete it.
                                            It is hidden by default so you might need to reset some preferences to see it...
                                            When SketchUp restarts the problem folder and files should now be recreated with good permissions...
                                            *Je suis sûr que Fredo répondra avec plus d'autorité, mais en attendant...
                                            Le problÚme avec l'erreur de dossier LIBFREDO6_DATA_Dir, suggÚre qu'il [et ses fichiers joints] n'ont pas les autorisations appropriées pour lire/écrire.
                                            Cela résulte généralement du fait que vous n'avez pas installé correctement SketchUp auparavant...
                                            Pour essayer d'inverser cela, procédez comme suit...
                                            Fermez SketchUp.
                                            Trouvez son fichier exe d'installation - généralement dans votre dossier Téléchargements.
                                            Sélectionnez son icÎne, clic droit > menu contextuel > 'Exécuter en tant qu'administrateur'...
                                            Dans la boßte de dialogue résultante, choisissez "Réparer"...
                                            Cela devrait résoudre la plupart des problÚmes d'autorisation liés à l'installation, tout en laissant votre dossier Plugins inchangé.
                                            Malheureusement, certains dossiers/fichiers enregistrĂ©s en dehors des chemins principaux de SketchUp peuvent ne pas ĂȘtre corrigĂ©s lorsque vous procĂ©dez ainsi.
                                            Donc, pour résoudre le problÚme avec C:\Users\levas\AppData\Local\LIBFREDO6_DATA_Dir, recherchez ce dossier et supprimez-le.
                                            Il est masquĂ© par dĂ©faut, vous devrez donc peut-ĂȘtre rĂ©initialiser certaines prĂ©fĂ©rences pour le voir...
                                            Lorsque SketchUp redĂ©marre, le dossier problĂ©matique et les fichiers doivent maintenant ĂȘtre recréés avec de bonnes autorisations...*
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 109
                                            • 110
                                            • 67 / 110
