    [Plugin][$] ThruPaint - v2.9a - 21 Apr 26
    195 Posts 55 Posters 90.1k Views 55 Watching
    • fredo6F
      A cube, although simple, cannot have all its faces painted in continuity. This is just a matter of geometry.
      If you wish control on where to pu the seams, then you need a texture wrapping tool (like WrapR), or a manual approach.
      Also, in the case of a cube, you may want to first paint the cube, and then use FredoCorner. This gives a better management of the zones of non-continuity.
      Gus R - Thrupaint Test.skp
      • Gus RG
        Gus R
        Thanks Fredo. UV mapping in Sketchup is difficult sometimes even for simple forms.
        I have an issue where Thrupaint is invoked when I double click on Thea Render for Sketchup materials. It oddly happens on the second attempt to change the Thea material. If I close down Thrupaint I then can't change the Thea materials unless Thrupaint is turned on. The same thing happens with Sketchup materials after this happens. The paint bucket stops working. I can then only paint an object unless Thrupaint is turned on.
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
        • Gus RG
          Gus R
          Continuing with the Thea Render materials problem the sequence goes like this:
          1. Double click Thea material and apply material to object.
          2. Double click again to change material and Thrupaint turns on.
          3. Paint with Thea material using Thrupaint and it changes.
          4. Then when I try to paint the object using the Paint Bucket tool it does not change.
          5. After that I can only change the material through Thrupaint.
          I can't change the material in a grouped object unless I use Thrupaint. This only happens in groups. I haven't tried a component yet. Either way I go back to the Thea materials and Thrupaint gets turned on at a second material change.
          • fredo6F
            This is due to a feature part of ThruPaint: when the native Bucket tool is active and you call it again (say typing B and then B) you start ThruPaint.
            With ThruPaint v2.1b (just published), it is now an option, and the default is that it is not enabled.
            Thanks to confirm this is now OK with Thea.
            • fredo6F
              NEW RELEASE: ThruPaint v2.1b - 07 Oct 22
              ThruPaint 2.1b fixes an issue whereby ThruPaint would launch when you invoke the PaintBucket tool and the PaintBucket tool is already active. This is now an option, with default value false.
              Home Page of ThruPaint for information and Download.
              Main post of this thread.
              • Gus RG
                Gus R
                Thanks for the update Fredo. It's all back to normal again. Perfect timing.
                  Error: #<NameError: uninitialized class variable @@time_unique in Traductor::ChromiumWdlg>
                  c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6chromiumwdlg.rbe:76:in unique_number' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1377:in create_dialog'
                  c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1442:in show' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6config.rbe:308:in visual_edition'
                  c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:434:in invoke_default_parameter_dialog' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:423:in block in populate_support_menu'
                  c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in `block in add_command'
                  Latest ThruPaint and LibFredo, restarted SketchUp...
                  Default settings fails with this error...
                  Running Paint face takes a while to load and produces the following error - although it seems to work [after a fashion]
                  c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:515:in paint_mode_change' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:393:in execute_direct'
                  c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:79:in action__mapping' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in call'
                  c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in launch_action' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in launch_action'
                  c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:69:in launch_action' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:145:in block in startup'
                  c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in command_invoke' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in block (2 levels) in build_config_commands'
                  • fredo6F
                    TIG,
                    What is error message for the second error (paint_mode_change) (It's not in your trace)
                      The error's start is...
                      c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1442:in show' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/thrupaintmaindialog.rbe:366:in dialog_invoke'
                      c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:515:in `paint_mode_change'
                      • fredo6F
                        Did you migrate to LibFredo6 v13.4a?
                          Yes, I have the latest version of LibFredo installed, and I have restarted SketchUp...
                          • L
                            I find it beyond belief that others such as Fredo can improve an aspect of Sketchup when trimble makes such feble attempts at "upgrades" without integrating such improvements that others offer ๐Ÿ˜ฎ ๐Ÿ˜• โ— ๐Ÿ˜
                            • Gus RG
                              Gus R
                              How do I activate the manipulation gizmo? The scale, rotate, and translate tool I'm trying to learn a million different things on my end.
                              • Gus RG
                                Gus R
                                Edit: never mind, I got it to work same as always.
                                OK, I'm still having a hard time with this.
                                  Press Enter or Left click...
                                  https://i.imgur.com/PPwnWXv.png
                                  ...on a surface with a material...
                                  https://i.imgur.com/akFRjiN.png
                                  • Gus RG
                                    Gus R
                                    Rich,
                                    Thanks! I went back and tried again after I posted this and it came back.
                                    I'll paint with Thrupaint and then when I left click it just keeps repainting. Seems like hitting "enter" works great. Don't know what's happening on my end. And now the left click is working easily again. ๐Ÿ˜ฒ
                                    Anyway, I found this useful video from SketchupEssentials: "ALL of Fredo6's SketchUp Extensions EXPLAINED!"
                                      rv1974
                                      1. Its impossible to sample (alt click) material outsidethe context when using Thrupaint inside a component. Could it be fixed?
                                      2. Are there plans to add material editing like size, transparensy, HSL etc insideTrupaint?
                                        Unfortunately without it the standard Paint tool can't be abandoned.
                                      • alexpacio2013A
                                        alexpacio2013
                                        I can't install True Paint on my computer, why? I attach errors and list of installed Fredo6 plugins.
                                          markcavey
                                          Not sure why i'm now getting this error
                                            Martuszka001
                                            Hi! I have a problem with the new version of ThruPaint. It doesn't work.
                                            I updated LibFredo6 to v13.4a, Sketchucation ExtensionStore to v4.2.9 and still shows me that "the version of ThruPaint v2.1b has expired. Please upgrade to the latest version."
                                            Whan can I do with that?
                                            • 2 / 10
