    [Plugin][$] ThruPaint - v2.9a - 21 Apr 26
    195 Posts 55 Posters 83.1k Views 55 Watching
    • fredo6F
      @gus r said:
      It works but only when my materials are under ...AppData\Roaming\SketchUp\SketchUp 2022\SketchUp and not under C:\ProgramData.
      This is where you should put your custom materials. However, you need to manually load them from the Sketchup Material Browser once.
      The ProgramData directory is only for the native Sketchup materials and can be overriden at Sketchup installation.
        @gullfo said:
        not sure where the IMAGE_RickOBrien folder is or how to change it
        It's an alternate icon set that you check on and restart SketchUp to activate. It is located here...
        ..\AppData\Roaming\SketchUp\SketchUp 2022\SketchUp\Plugins\Fredo6_ThruPaint
        • Gus RG
          Gus R
          Fredo,
          The top bar or title bar in the window shows up for a split second then collapses making it difficult or impossible to move the window. There's just a sliver showing up and you have to precisely click on that.
          www.instagram.com/gusrobatto/
          www.facebook.com/gusrobatto
          • fredo6F
            @gus r said:
            Fredo,
            In principle you can click within the background of the window (for instance right of the tabs) and drag the window.
              rv1974
              Fredo, is it possible to have ability to see custom material collections I alreadyhave in standard material browser? Thanks
              • fredo6F
                If you have directories with skm files (or subfolders containing skm files), you can integrate these materials to the browser, by defining
                • either create a top folder as the top directory where you have your custom collections. The directory will appear at the top of the Materials hierarchy. You will be prompted to give it a friendly name.
                • or put your custom materials and subfolder in the preferred Material Directory, which is C:\Users<username>\AppData\Roaming\SketchUp\SketchUp 2022\SketchUp\Material. These materials (and subfolders) will automatically load. I think it is the same for the native Sketchup Material Browser. The menu entry Open Preferred Material Directory open this directory.
                Click on the menu of the browser for the two options:
                • Gus RG
                  Gus R
                  Is it possible to get the UV without distortion on an object like this with Thrupaint? It's a pretty simple shape and I attached the skp file.
                  Thrupaint Test.skp
                  • fredo6F
                    A cube, although simple, cannot have all its faces painted in continuity. This is just a matter of geometry.
                    If you wish control on where to pu the seams, then you need a texture wrapping tool (like WrapR), or a manual approach.
                    Also, in the case of a cube, you may want to first paint the cube, and then use FredoCorner. This gives a better management of the zones of non-continuity.
                    Gus R - Thrupaint Test.skp
                    • Gus RG
                      Gus R
                      Thanks Fredo. UV mapping in Sketchup is difficult sometimes even for simple forms.
                      I have an issue where Thrupaint is invoked when I double click on Thea Render for Sketchup materials. It oddly happens on the second attempt to change the Thea material. If I close down Thrupaint I then can't change the Thea materials unless Thrupaint is turned on. The same thing happens with Sketchup materials after this happens. The paint bucket stops working. I can then only paint an object unless Thrupaint is turned on.
                      • Gus RG
                        Gus R
                        Continuing with the Thea Render materials problem the sequence goes like this:
                        1. Double click Thea material and apply material to object.
                        2. Double click again to change material and Thrupaint turns on.
                        3. Paint with Thea material using Thrupaint and it changes.
                        4. Then when I try to paint the object using the Paint Bucket tool it does not change.
                        5. After that I can only change the material through Thrupaint.
                        I can't change the material in a grouped object unless I use Thrupaint. This only happens in groups. I haven't tried a component yet. Either way I go back to the Thea materials and Thrupaint gets turned on at a second material change.
                        • fredo6F
                          This is due to a feature part of ThruPaint: when the native Bucket tool is active and you call it again (say typing B and then B) you start ThruPaint.
                          With ThruPaint v2.1b (just published), it is now an option, and the default is that it is not enabled.
                          Thanks to confirm this is now OK with Thea.
                          • fredo6F
                            NEW RELEASE: ThruPaint v2.1b - 07 Oct 22
                            ThruPaint 2.1b fixes an issue whereby ThruPaint would launch when you invoke the PaintBucket tool and the PaintBucket tool is already active. This is now an option, with default value false.
                            Home Page of ThruPaint for information and Download.
                            Main post of this thread.
                            • Gus RG
                              Gus R
                              Thanks for the update Fredo. It's all back to normal again. Perfect timing.
                                Error: #<NameError: uninitialized class variable @@time_unique in Traductor::ChromiumWdlg>
                                c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6chromiumwdlg.rbe:76:in unique_number' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1377:in create_dialog'
                                c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1442:in show' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6config.rbe:308:in visual_edition'
                                c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:434:in invoke_default_parameter_dialog' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:423:in block in populate_support_menu'
                                c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in `block in add_command'
                                Latest ThruPaint and LibFredo, restarted SketchUp...
                                Default settings fails with this error...
                                Running Paint face takes a while to load and produces the following error - although it seems to work [after a fashion]
                                c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:515:in paint_mode_change' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:393:in execute_direct'
                                c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:79:in action__mapping' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in call'
                                c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in launch_action' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in launch_action'
                                c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:69:in launch_action' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:145:in block in startup'
                                c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in command_invoke' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in block (2 levels) in build_config_commands'
                                • fredo6F
                                  TIG,
                                  What is error message for the second error (paint_mode_change) (It's not in your trace)
                                    The error's start is...
                                    c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1442:in show' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/thrupaintmaindialog.rbe:366:in dialog_invoke'
                                    c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:515:in `paint_mode_change'
                                    • fredo6F
                                      Did you migrate to LibFredo6 v13.4a?
                                        Yes, I have the latest version of LibFredo installed, and I have restarted SketchUp...
                                        • L
                                          I find it beyond belief that others such as Fredo can improve an aspect of Sketchup when trimble makes such feble attempts at "upgrades" without integrating such improvements that others offer ๐Ÿ˜ฎ ๐Ÿ˜• โ— ๐Ÿ˜
                                          • Gus RG
                                            Gus R
                                            How do I activate the manipulation gizmo? The scale, rotate, and translate tool I'm trying to learn a million different things on my end.
                                            • 1 / 10
