    [Plugin][$] ThruPaint - v2.9a - 21 Apr 26
    193 Posts 55 Posters 71.1k Views 55 Watching
    • fredo6F Offline
      NEW RELEASE: ThruPaint v2.1b - 07 Oct 22
      ThruPaint 2.1b fixes an issue whereby ThruPaint would launch when you invoke the PaintBucket tool and the PaintBucket tool is already active. This is now an option, with default value false.
      Home Page of ThruPaint for information and Download.
      Main post of this thread.
      • Gus RG Offline
        Gus R
        Thanks for the update Fredo. It's all back to normal again. Perfect timing.
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
          Error: #<NameError: uninitialized class variable @@time_unique in Traductor::ChromiumWdlg>
          c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6chromiumwdlg.rbe:76:in unique_number' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1377:in create_dialog'
          c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1442:in show' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6config.rbe:308:in visual_edition'
          c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:434:in invoke_default_parameter_dialog' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:423:in block in populate_support_menu'
          c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in `block in add_command'
          Latest ThruPaint and LibFredo, restarted SketchUp...
          Default settings fails with this error...
          Running Paint face takes a while to load and produces the following error - although it seems to work [after a fashion]
          c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:515:in paint_mode_change' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:393:in execute_direct'
          c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:79:in action__mapping' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in call'
          c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in launch_action' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in launch_action'
          c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:69:in launch_action' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:145:in block in startup'
          c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in command_invoke' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in block (2 levels) in build_config_commands'
          • fredo6F Offline
            TIG,
            What is error message for the second error (paint_mode_change) (It's not in your trace)
              The error's start is...
              c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1442:in show' c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/thrupaintmaindialog.rbe:366:in dialog_invoke'
              c:/users/tig/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:515:in `paint_mode_change'
              • fredo6F Offline
                Did you migrate to LibFredo6 v13.4a?
                  Yes, I have the latest version of LibFredo installed, and I have restarted SketchUp...
                    I find it beyond belief that others such as Fredo can improve an aspect of Sketchup when trimble makes such feble attempts at "upgrades" without integrating such improvements that others offer 😮 😕 ❗ 😠
                    • Gus RG Offline
                      Gus R
                      How do I activate the manipulation gizmo? The scale, rotate, and translate tool I'm trying to learn a million different things on my end.
                      • Gus RG Offline
                        Gus R
                        Edit: never mind, I got it to work same as always.
                        OK, I'm still having a hard time with this.
                          Press Enter or Left click...
                          https://i.imgur.com/PPwnWXv.png
                          ...on a surface with a material...
                          https://i.imgur.com/akFRjiN.png
                          • Gus RG Offline
                            Gus R
                            Rich,
                            Thanks! I went back and tried again after I posted this and it came back.
                            I'll paint with Thrupaint and then when I left click it just keeps repainting. Seems like hitting "enter" works great. Don't know what's happening on my end. And now the left click is working easily again. 😲
                            Anyway, I found this useful video from SketchupEssentials: "ALL of Fredo6's SketchUp Extensions EXPLAINED!"
                              rv1974
                              1. Its impossible to sample (alt click) material outsidethe context when using Thrupaint inside a component. Could it be fixed?
                              2. Are there plans to add material editing like size, transparensy, HSL etc insideTrupaint?
                                Unfortunately without it the standard Paint tool can't be abandoned.
                              • alexpacio2013A Offline
                                alexpacio2013
                                I can't install True Paint on my computer, why? I attach errors and list of installed Fredo6 plugins.
                                  markcavey
                                  Not sure why i'm now getting this error
                                    Martuszka001
                                    Hi! I have a problem with the new version of ThruPaint. It doesn't work.
                                    I updated LibFredo6 to v13.4a, Sketchucation ExtensionStore to v4.2.9 and still shows me that "the version of ThruPaint v2.1b has expired. Please upgrade to the latest version."
                                    Whan can I do with that?
                                    • N Offline
                                      NadinA2022
                                      I can`t start the plagin from today 31.10.2022. It asks to upgrade? but its up to date.
                                      Whats the problem may be and How fix it. Thanks.
                                      • fredo6F Offline
                                        NEW RELEASE: ThruPaint v2.2a - 31 Oct 22
                                        ThruPaint 2.2a is for extension of validity.
                                          Grey24601
                                          Hi Fredo,
                                          I love this tool and couldn't work without it. However, it takes a very long time to load the materials. Is there a way to speed it up or revert back to the old way using the Sketchup selected material?
                                            jsinmichael
                                            This is a great tool. Thank you. Any chance of being able to pick colors from the default "Materials" color wheel or incorporate one of your own? Will the color picker only select color from the canvas?
                                            J
                                            • 2 / 10
