    [Plugin] LordOfTheToolbars - v2.9c - 20 Dec 24
    471 Posts 89 Posters 340.5k Views 88 Watching
    • N Offline
      nicolasberthier @fredo6
      @fredo6
      I exeprience the same problem in SU24 last updat.
      Is there any way that the Menu search dialogue can be unblocked ? I would realy appreciate it to be available again on SU24.
      Thanks !
      • O Offline
        optimaforever
        I have a problem with the MINDSIGHT STUDIOS plugins suddenly not appearing in my toolbars. I realized they also disappear from the Master Toolbar Manager.
        The plugins are still loaded and accessible from their native toolbars.Capture d'écran 2024-11-25 145538.pngCapture d'écran 2024-11-25 150903.png
        • fredo6F Offline
          NEW RELEASE: LordOfTheToolbars v2.9a - 13 Dec 24
          Requirements
          • LibFredo6: v14.7a or above
          LordOfTheToolbars 2.9a is a maintenance release including:
          • Fix related to an issue preventing VRay commands to execute.
          Home Page of LordOfTheToolbars for information and Download.
          Main post of this LordOfTheToolbars thread.
          alexpacio2013A Y 3 Replies Last reply Reply Quote 0
          • alexpacio2013A Offline
            alexpacio2013 @fredo6
            @fredo6 It works great, congratulations for your speed and competence, thanks
            • Y Offline
              yyxp1989 Newcomers @fredo6
              Hello @fredo6 I have a problem that I can't solve. Could you help me? LordOfTheToolbars v2.9a It worked fine during the first run and I can add tools icon.
              However, I couldn't use the Master Toolbar Manager after restarting SketchUp.I can't drag the icon. It doesn't work.
              The problem remained the same even after reinstalling it.
              SU Version: 2024.0.594-64bit
              LibFredo6_v14.9a
              fredo6F 1 Reply Last reply Reply Quote 0
              • fredo6F Offline
                fredo6 @yyxp1989
                @yyxp1989
                I cannot read what is in the black window
                Y 1 Reply Last reply Reply Quote 0
                • Y Offline
                  @fredo6 I switched back to SketchUp 2023, and everything works fine. Thank you for your work.
                  The issue occurs in SU2024.0.594, which may be a compatibility problem. The Master Toolbar Manager window does not respond to operations.
                  Click Show DEV Tools
                    @fredo6
                    With the latest version of Lord of thr Toolbar the compatibility problem with vay 7 has been solved but now I find another problem, often when I open sketchup, it crashes, The crash happens just when it goes to open the menu bars created with Lord of the toolbar. I found that by disabling Lord of the Toolbar, Sketchup opens perfectly. I don't understand which one is due to incompatibility with other plugins or from something else. To open sketchup I have to disable Lord of the toolbar AND re-enable it when it is open, through the Sketchauction plugin manager.
                      AISmebel
                      Hello Fredo. Do you think it will be possible to return the "Menu" tool in the new SU 2025?
                        alexpacio2013
                        I can no longer create new buttons with Lord of the Toolbar or even edit buttons already created. You can see from the video that it does not save changes made to any button. What can I do I have installed the latest versions anyway.
                        Video ----
                          AISmebel
                          Hello. Can you tell me why, when I add a new script, I click save, but as a result, the script is not saved(((( Everything used to work well.
                          Error: #<NoMethodError: undefined method `editor_changed' for #<F6_LordOfTheToolbars::PersoDialog:0x000002613cccc438>
                          Did you mean?  editor_code_changed>
                          c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:677:in `dialog_callback_execute'
                          c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:608:in `dialog_callback'
                          c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2479:in `call'
                          c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2479:in `master_callback'
                          c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2240:in `j_action'
                          c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2199:in `j_callback'
                          c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2185:in `block in j_dispatch'
                          c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2177:in `each'
                          c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2177:in `j_dispatch'
                          c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1454:in `block in create_dialog'
                          • fredo6F Offline
                            fredo6 @AISmebel
                            @AISmebel
                            This is a bug. I will publish a new version. Thanks for signaling.
                            • fredo6F Offline
                              NEW RELEASE: LordOfTheToolbars v2.9c - 20 Dec 24
                              Requirements
                              LordOfTheToolbars 2.9c is a maintenance release including:
                              • Fix related to an issue preventing VRay commands to execute (Mac)
                              • Fix preventing to save personal scripts
                              • H Offline
                                haymaker @fredo6
                                @fredo6
                                I just upgraded to SU2024
                                My personal icons I made in 2022 are greyed out. when i try to make a new one there is no list available in the command menu, same as larent002.
                                Is this going to be fixed?
                                Do you have a work around?
                                I am missing 6 buttons that I need all the time.
                                • O Offline
                                  olopolo
                                  Hello,
                                  I can't enlarge the “Master toolbar manager” window to reach the “custom toolbars” line.
                                  The window remains at this size and the scroll bar doesn't just go to the end.
                                  By however, you can see this line in the “print toolbars” window.
                                  Thank you in advance for your help and with apologies for this message translated from French
                                  • H Offline
                                    haymaker
                                    Hi Fedo.
                                    I have created some keyboard shortcuts to open custom made LOTT pallets. The problem is when I create a new tag or tag folder and one of the shortcut keys is pressed it activates the shortcut and the pallet opens making it impossible to create the tag. It doesn't happen if the shortcut letter is assigned to a native SU command only if it is controlling a LOTT pallet. After trying various things like adding an Alt before the letter now none of the LOTT shortcut keys are working, shortcuts created using SU native UI still work fine. My problems started a few weeks back when I updated to 2024 from 2022. Running Fredo 15.0 and LOTT 2.9c. Please could you offer some assistance as I cant find a work around. Thank you.
                                    • fredo6F Offline
                                      Shortcuts for LOTT commands should have a modifier.
                                      Because there have been changes in the UI framework of Sketchup in SU2023 and SU2024 (versus SU2022), many things are done differently now.
                                      • H Offline
                                        haymaker
                                        This post is deleted!
                                        • H Offline
                                          haymaker
                                          OK. I was using shift as a modifier key in the past but if you want to add a capital letter when creating a tag title it would activate the palette.
                                          I can use Ctrl instead, but the problem is compounded by the fact that I use a space mouse key with macro to open LOTT pallets and LOTT no longer seems to recognise the output (it used to) from the space mouse. The problem would appear to be at your end. Example - if I map ctrl A to a native SU shortcut the space mouse executes the command fine but if I map ctrl A to a LOTT pallet when I press the space mouse key I just get a red + flash up momentarily. Thanks
                                            Ramzix
                                            Hi there, humble question, is there a way to possibly get an older version of LOTT? Like 2.7c
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 21 / 24
