    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 689.8k Views 99 Watching
    • fredo6F
      fredo6 @FlorinAp
      @FlorinAp
      LOTT is compatible with SU2022. It even includes menu command.
      74a63105-7aba-448a-b55b-b029826a1083-image.png c7c0cba5-07ae-48b2-8564-b79d2848e888-image.png
      So what exactly is the problem.
      Can you exit SU2022 with the Ruby console opened and relaunch SU2022. The Ruby console should open at startup and log potential errors.
      F 1 Reply Last reply
      • F
        FlorinAp @fredo6
        @fredo6 I don't know what is the problem, but even with 2.4a SU 2022 is not usable, with 2.4a it just doesn't freeze my os anymore, but SU 2022 it is still mostly unusable, the only way to make it usable is to disable LOTT completely.
        Since I wrote that everything is alright I haven't used it, I just left it there, opened in background, to understand now that I cant use it... if I don't disable LOTT.
        I will try what you suggested...!
        • F
          FlorinAp @FlorinAp
          @FlorinAp Well man, below is the content from the ruby window, for me is an alien language, but maybe you can make sense of it...!
          For me is not a big deal because now I use mostly SU 23 and 24 - it's just a sick incurable stubbornness to understand and fix everything I touch, so if it makes sense to you maybe you will be willing to share; I don't see nothing "Fredo" related, but it seems to be a conflict created by some Curic extensions....
          "finished reading language file
          tb_mode,single
          tb_Settingout,true
          tb_Draw,true
          tb_Edit,true
          tb_Array,true
          tb_Wall,true
          tb_Staircase,true
          tb_Win,true
          tb_Roof,true
          tb_Site,true
          tb_Structure,true
          point_on_face,true
          divide,true
          align,true
          perpendicular_line,true
          fonplane,true
          bestface,true
          extrude1,true
          extrude2,true
          move_vertex,true
          fillet,true
          chamfer,true
          extend,true
          offset_edge,true
          hline_faces,true
          slopeedges,true
          linear_array,true
          rect_array,true
          polar_array,true
          path_array,true
          wallsctrl,true
          opening,true
          hgroove,true
          escalator,true
          wframe,true
          dframe,true
          paneldivide,true
          screen1,true
          hlouvres,true
          vlouvres,true
          joists,true
          roof1,true
          hiproof,true
          revsurf,true
          mdeck,true
          stairsctrl,true
          profiles_on_plane,true
          cutfill,true
          siteb,true
          fndctrl,true
          columnctrl,true
          contour,true
          setlayer,true
          mergelayer,true
          framesel,true
          scale,true
          center1,true
          ptsinfo,true
          extrude3,true
          profiles3d,true
          extrude0,true
          loading 1001bit pro menu >> true
          c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_projections/dbur_projections.rbe:5: warning: already initialized constant Math::PROJEPSILON
          c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_guidetools/dbur_guidetools.rbe:6: warning: previous definition of PROJEPSILON was here
          true
          Sketchup Version is = 17
          88
          "icon_thickness_mode.svg"
          "c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_dio2/Resources/icon_thickness_mode.svg"
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/cmap/subtable.rb:13: warning: already initialized constant TTFunk::Table::Cmap::Subtable::ENCODING_MAPPINGS
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/cmap/subtable.rb:13: warning: previous definition of ENCODING_MAPPINGS was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:6: warning: already initialized constant TTFunk::Encoding::MacRoman::TO_UNICODE
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:6: warning: previous definition of TO_UNICODE was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:42: warning: already initialized constant TTFunk::Encoding::MacRoman::FROM_UNICODE
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:42: warning: previous definition of FROM_UNICODE was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:50: warning: already initialized constant TTFunk::Encoding::MacRoman::POSTSCRIPT_GLYPH_MAPPING
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:50: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:6: warning: already initialized constant TTFunk::Encoding::Windows1252::TO_UNICODE
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:6: warning: previous definition of TO_UNICODE was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:18: warning: already initialized constant TTFunk::Encoding::Windows1252::FROM_UNICODE
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:18: warning: previous definition of FROM_UNICODE was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:26: warning: already initialized constant TTFunk::Encoding::Windows1252::POSTSCRIPT_GLYPH_MAPPING
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:26: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:9: warning: already initialized constant TTFunk::Table::Glyf::Compound::ARG_1_AND_2_ARE_WORDS
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:9: warning: previous definition of ARG_1_AND_2_ARE_WORDS was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:10: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_SCALE
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:10: warning: previous definition of WE_HAVE_A_SCALE was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:11: warning: already initialized constant TTFunk::Table::Glyf::Compound::MORE_COMPONENTS
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:11: warning: previous definition of MORE_COMPONENTS was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:12: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_AN_X_AND_Y_SCALE
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:12: warning: previous definition of WE_HAVE_AN_X_AND_Y_SCALE was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:13: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_TWO_BY_TWO
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:13: warning: previous definition of WE_HAVE_A_TWO_BY_TWO was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:14: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_INSTRUCTIONS
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:14: warning: previous definition of WE_HAVE_INSTRUCTIONS was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:20: warning: already initialized constant TTFunk::Table::Glyf::Compound::Component
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:20: warning: previous definition of Component was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/hmtx.rb:22: warning: already initialized constant TTFunk::Table::Hmtx::HorizontalMetric
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/hmtx.rb:22: warning: previous definition of HorizontalMetric was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/post/format10.rb:5: warning: already initialized constant TTFunk::Table::Post::Format10::POSTSCRIPT_GLYPHS
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/post/format10.rb:5: warning: previous definition of POSTSCRIPT_GLYPHS was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/sbix.rb:11: warning: already initialized constant TTFunk::Table::Sbix::BitmapData
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/sbix.rb:11: warning: previous definition of BitmapData was here
          c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_oi/loader.rbe:169: warning: already initialized constant CURIC::OI::PLUGIN
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi.rb:6: warning: previous definition of PLUGIN was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/cmap/subtable.rb:13: warning: already initialized constant TTFunk::Table::Cmap::Subtable::ENCODING_MAPPINGS
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/cmap/subtable.rb:13: warning: previous definition of ENCODING_MAPPINGS was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:6: warning: already initialized constant TTFunk::Encoding::MacRoman::TO_UNICODE
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:6: warning: previous definition of TO_UNICODE was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:42: warning: already initialized constant TTFunk::Encoding::MacRoman::FROM_UNICODE
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:42: warning: previous definition of FROM_UNICODE was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:50: warning: already initialized constant TTFunk::Encoding::MacRoman::POSTSCRIPT_GLYPH_MAPPING
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:50: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:6: warning: already initialized constant TTFunk::Encoding::Windows1252::TO_UNICODE
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:6: warning: previous definition of TO_UNICODE was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:18: warning: already initialized constant TTFunk::Encoding::Windows1252::FROM_UNICODE
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:18: warning: previous definition of FROM_UNICODE was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:26: warning: already initialized constant TTFunk::Encoding::Windows1252::POSTSCRIPT_GLYPH_MAPPING
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:26: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:9: warning: already initialized constant TTFunk::Table::Glyf::Compound::ARG_1_AND_2_ARE_WORDS
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:9: warning: previous definition of ARG_1_AND_2_ARE_WORDS was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:10: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_SCALE
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:10: warning: previous definition of WE_HAVE_A_SCALE was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:11: warning: already initialized constant TTFunk::Table::Glyf::Compound::MORE_COMPONENTS
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:11: warning: previous definition of MORE_COMPONENTS was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:12: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_AN_X_AND_Y_SCALE
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:12: warning: previous definition of WE_HAVE_AN_X_AND_Y_SCALE was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:13: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_TWO_BY_TWO
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:13: warning: previous definition of WE_HAVE_A_TWO_BY_TWO was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:14: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_INSTRUCTIONS
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:14: warning: previous definition of WE_HAVE_INSTRUCTIONS was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:20: warning: already initialized constant TTFunk::Table::Glyf::Compound::Component
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:20: warning: previous definition of Component was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/hmtx.rb:22: warning: already initialized constant TTFunk::Table::Hmtx::HorizontalMetric
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/hmtx.rb:22: warning: previous definition of HorizontalMetric was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/post/format10.rb:5: warning: already initialized constant TTFunk::Table::Post::Format10::POSTSCRIPT_GLYPHS
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/post/format10.rb:5: warning: previous definition of POSTSCRIPT_GLYPHS was here
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/sbix.rb:11: warning: already initialized constant TTFunk::Table::Sbix::BitmapData
          C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/sbix.rb:11: warning: previous definition of BitmapData was here
          "RubyEncoder loader: C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_true_isolate/rgloader/rgloader27.mingw.x64.so"
          c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_axis/utils.rbe:123: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
          c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_space/utils.rbe:374: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
          c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/projection/projection.rbs:23: warning: already initialized constant Math::PROJEPSILON
          c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_projections/dbur_projections.rbe:5: warning: previous definition of PROJEPSILON was here
          Tolerance default to 0.001
          radius = xxx
          segmentation = xxx
          delete_corners = xxx
          radius = xxx
          segmentation = xxx
          "Add help menu!"
          "create new"
          "created"
          #Sketchup::Menu:0x000001d455838b98
          (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
          "Add help menu!"
          "created"
          "created"
          (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open"
          • N
            nicolasberthier @fredo6
            @fredo6
            I exeprience the same problem in SU24 last updat.
            Is there any way that the Menu search dialogue can be unblocked ? I would realy appreciate it to be available again on SU24.
            Thanks !
            • O
              optimaforever
              I have a problem with the MINDSIGHT STUDIOS plugins suddenly not appearing in my toolbars. I realized they also disappear from the Master Toolbar Manager.
              The plugins are still loaded and accessible from their native toolbars.Capture d'écran 2024-11-25 145538.pngCapture d'écran 2024-11-25 150903.png
              • fredo6F
                NEW RELEASE: LordOfTheToolbars v2.9a - 13 Dec 24
                Requirements
                • LibFredo6: v14.7a or above
                LordOfTheToolbars 2.9a is a maintenance release including:
                • Fix related to an issue preventing VRay commands to execute.
                Home Page of LordOfTheToolbars for information and Download.
                Main post of this LordOfTheToolbars thread.
                alexpacio2013A Y 3 Replies Last reply
                • alexpacio2013A
                  alexpacio2013 @fredo6
                  @fredo6 It works great, congratulations for your speed and competence, thanks
                  • Y
                    yyxp1989 Newcomers @fredo6
                    Hello @fredo6 I have a problem that I can't solve. Could you help me? LordOfTheToolbars v2.9a It worked fine during the first run and I can add tools icon.
                    However, I couldn't use the Master Toolbar Manager after restarting SketchUp.I can't drag the icon. It doesn't work.
                    The problem remained the same even after reinstalling it.
                    SU Version: 2024.0.594-64bit
                    LibFredo6_v14.9a
                    fredo6F 1 Reply Last reply
                    • fredo6F
                      fredo6 @yyxp1989
                      @yyxp1989
                      I cannot read what is in the black window
                      Y 1 Reply Last reply
                      • Y
                        @fredo6 I switched back to SketchUp 2023, and everything works fine. Thank you for your work.
                        The issue occurs in SU2024.0.594, which may be a compatibility problem. The Master Toolbar Manager window does not respond to operations.
                        Click Show DEV Tools
                        • alexpacio2013A
                          @fredo6
                          With the latest version of Lord of thr Toolbar the compatibility problem with vay 7 has been solved but now I find another problem, often when I open sketchup, it crashes, The crash happens just when it goes to open the menu bars created with Lord of the toolbar. I found that by disabling Lord of the Toolbar, Sketchup opens perfectly. I don't understand which one is due to incompatibility with other plugins or from something else. To open sketchup I have to disable Lord of the toolbar AND re-enable it when it is open, through the Sketchauction plugin manager.
                            AISmebel
                            Hello Fredo. Do you think it will be possible to return the "Menu" tool in the new SU 2025?
                            • alexpacio2013A
                              alexpacio2013
                              I can no longer create new buttons with Lord of the Toolbar or even edit buttons already created. You can see from the video that it does not save changes made to any button. What can I do I have installed the latest versions anyway.
                              Video ----
                                AISmebel
                                Hello. Can you tell me why, when I add a new script, I click save, but as a result, the script is not saved(((( Everything used to work well.
                                Error: #<NoMethodError: undefined method `editor_changed' for #<F6_LordOfTheToolbars::PersoDialog:0x000002613cccc438>
                                Did you mean?  editor_code_changed>
                                c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:677:in `dialog_callback_execute'
                                c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:608:in `dialog_callback'
                                c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2479:in `call'
                                c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2479:in `master_callback'
                                c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2240:in `j_action'
                                c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2199:in `j_callback'
                                c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2185:in `block in j_dispatch'
                                c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2177:in `each'
                                c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2177:in `j_dispatch'
                                c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1454:in `block in create_dialog'
                                • fredo6F
                                  fredo6 @AISmebel
                                  @AISmebel
                                  This is a bug. I will publish a new version. Thanks for signaling.
                                  • fredo6F
                                    NEW RELEASE: LordOfTheToolbars v2.9c - 20 Dec 24
                                    Requirements
                                    LordOfTheToolbars 2.9c is a maintenance release including:
                                    • Fix related to an issue preventing VRay commands to execute (Mac)
                                    • Fix preventing to save personal scripts
                                    • H
                                      haymaker @fredo6
                                      @fredo6
                                      I just upgraded to SU2024
                                      My personal icons I made in 2022 are greyed out. when i try to make a new one there is no list available in the command menu, same as larent002.
                                      Is this going to be fixed?
                                      Do you have a work around?
                                      I am missing 6 buttons that I need all the time.
                                      • O
                                        olopolo
                                        Hello,
                                        I can't enlarge the “Master toolbar manager” window to reach the “custom toolbars” line.
                                        The window remains at this size and the scroll bar doesn't just go to the end.
                                        By however, you can see this line in the “print toolbars” window.
                                        Thank you in advance for your help and with apologies for this message translated from French
                                        • H
                                          haymaker
                                          Hi Fedo.
                                          I have created some keyboard shortcuts to open custom made LOTT pallets. The problem is when I create a new tag or tag folder and one of the shortcut keys is pressed it activates the shortcut and the pallet opens making it impossible to create the tag. It doesn't happen if the shortcut letter is assigned to a native SU command only if it is controlling a LOTT pallet. After trying various things like adding an Alt before the letter now none of the LOTT shortcut keys are working, shortcuts created using SU native UI still work fine. My problems started a few weeks back when I updated to 2024 from 2022. Running Fredo 15.0 and LOTT 2.9c. Please could you offer some assistance as I cant find a work around. Thank you.
                                          • fredo6F
                                            Shortcuts for LOTT commands should have a modifier.
                                            Because there have been changes in the UI framework of Sketchup in SU2023 and SU2024 (versus SU2022), many things are done differently now.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 27
                                            • 28
                                            • 21 / 28
