    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 689.8k Views 99 Watching
    • L
      laurent002
      @laurent002 said in [Plugin] LordOfTheToolbars - v2.8a - 10 Nov 24:
      It's very sad, it is realy missing in sketchup to ne able to organise and use any tools as we wish, any tools or fonction. And the question of having so many plugin creators, sometine with no icons, or not all tools, is a great limitation. You can't créât to many short cuts, to make your flow more cohérent. Going to the menu, then using icon, and adding a short cut, is moving your mouse all over your screen, going from one side to the other. It give sketchup a look of a very old sofware, when other software have a much better ergonomi. What sketchup should be so plugin designers and users would be able to juste work without having to thinks how to adapt there work to sketchup, but how to ajuste sketchup to there work.
      • F
        FlorinAp
        After version 2.4a there is a very big compatibility issue with SU 2022 (and maybe also with previous SU versions.!), that makes SU barely usable - I've spent 6-8 hours trying to understand what the hell is wrong with my SU...
        Now maybe I would have to pair it with a LibFredo version..., but today I've spent my energy reserves.
        Sometimes (rarely) I use SU 2022, for compatibility with other plugins or for printing options that have disappeared starting with SU 2023.
        Anyway, a bug (any bug.!!) in LOTT affects the SU engine, so you have the choice to use it or throw it away completely.
        fredo6F 1 Reply Last reply
        • fredo6F
          fredo6 @FlorinAp
          @FlorinAp
          First thing would be to upgrade both LibFredo6 and LOTT to their latest published versions.
          Second, can you describe the 'bug' you have with SU2022?
          • F
            FlorinAp @fredo6
            @fredo6 They already were in the latest version (otherwise I wouldn't come here to write).
            There was no "one single" bug - SU and the entire OS were almost frozen, you had to wait for a few minutes before you had any access to SU and also to the OS (W 11)... for about 1-2 minutes, and then the same cycle... (flashing and freezing... and couldn't use no other app).
            Experience (a lot of it) and intuition finally drove me to LOTT - and I made no other changes in my PC other than downgrade LOTT (LibFredo seems to be fine at the second to last version) - It has been a few hours and everything is alright (I mean as much as it can it can be after W7).
            This kind of problem started on many levels with SU (and its plugins) only after W7, but unfortunately, we are not in the driver's seat... and we have to move forward, everything was flawless but starting with W10... many headaches for users and developers, concerning many other software.
            • F
              FlorinAp @FlorinAp
              @FlorinAp All these incompatibility issues between SU 2022 and W10-W11 have disappeared starting with SU 2023, and maybe at some point not everything can be compatible with everything... i understand that, but it is fair that at that point every developer should mention in its release notes where the compatibility ends.
              If it helps - your release notes are very helpful.!
              F fredo6F 2 Replies Last reply
              • F
                FlorinAp @FlorinAp
                @FlorinAp Sorry, i was a bit irritated after so many wasted hours, and I missed telling you something - everything was starting as soon as I would approach my mouse to any palette, if you wouldn't touch the palette... everything was fine.
                Although SU 2022 would load very late and very slowly because of the vignette, but after that you are not allowed to touch any pallette; but if I disbaled the LOTT completely, SU would also load very fine and fast.
                I hope it helps...!
                • fredo6F
                  fredo6 @FlorinAp
                  @FlorinAp
                  LOTT is compatible with SU2022. It even includes menu command.
                  74a63105-7aba-448a-b55b-b029826a1083-image.png c7c0cba5-07ae-48b2-8564-b79d2848e888-image.png
                  So what exactly is the problem.
                  Can you exit SU2022 with the Ruby console opened and relaunch SU2022. The Ruby console should open at startup and log potential errors.
                  • F
                    FlorinAp @fredo6
                    @fredo6 I don't know what is the problem, but even with 2.4a SU 2022 is not usable, with 2.4a it just doesn't freeze my os anymore, but SU 2022 it is still mostly unusable, the only way to make it usable is to disable LOTT completely.
                    Since I wrote that everything is alright I haven't used it, I just left it there, opened in background, to understand now that I cant use it... if I don't disable LOTT.
                    I will try what you suggested...!
                    • F
                      FlorinAp @FlorinAp
                      @FlorinAp Well man, below is the content from the ruby window, for me is an alien language, but maybe you can make sense of it...!
                      For me is not a big deal because now I use mostly SU 23 and 24 - it's just a sick incurable stubbornness to understand and fix everything I touch, so if it makes sense to you maybe you will be willing to share; I don't see nothing "Fredo" related, but it seems to be a conflict created by some Curic extensions....
                      "finished reading language file
                      tb_mode,single
                      tb_Settingout,true
                      tb_Draw,true
                      tb_Edit,true
                      tb_Array,true
                      tb_Wall,true
                      tb_Staircase,true
                      tb_Win,true
                      tb_Roof,true
                      tb_Site,true
                      tb_Structure,true
                      point_on_face,true
                      divide,true
                      align,true
                      perpendicular_line,true
                      fonplane,true
                      bestface,true
                      extrude1,true
                      extrude2,true
                      move_vertex,true
                      fillet,true
                      chamfer,true
                      extend,true
                      offset_edge,true
                      hline_faces,true
                      slopeedges,true
                      linear_array,true
                      rect_array,true
                      polar_array,true
                      path_array,true
                      wallsctrl,true
                      opening,true
                      hgroove,true
                      escalator,true
                      wframe,true
                      dframe,true
                      paneldivide,true
                      screen1,true
                      hlouvres,true
                      vlouvres,true
                      joists,true
                      roof1,true
                      hiproof,true
                      revsurf,true
                      mdeck,true
                      stairsctrl,true
                      profiles_on_plane,true
                      cutfill,true
                      siteb,true
                      fndctrl,true
                      columnctrl,true
                      contour,true
                      setlayer,true
                      mergelayer,true
                      framesel,true
                      scale,true
                      center1,true
                      ptsinfo,true
                      extrude3,true
                      profiles3d,true
                      extrude0,true
                      loading 1001bit pro menu >> true
                      c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_projections/dbur_projections.rbe:5: warning: already initialized constant Math::PROJEPSILON
                      c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_guidetools/dbur_guidetools.rbe:6: warning: previous definition of PROJEPSILON was here
                      true
                      Sketchup Version is = 17
                      88
                      "icon_thickness_mode.svg"
                      "c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_dio2/Resources/icon_thickness_mode.svg"
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/cmap/subtable.rb:13: warning: already initialized constant TTFunk::Table::Cmap::Subtable::ENCODING_MAPPINGS
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/cmap/subtable.rb:13: warning: previous definition of ENCODING_MAPPINGS was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:6: warning: already initialized constant TTFunk::Encoding::MacRoman::TO_UNICODE
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:6: warning: previous definition of TO_UNICODE was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:42: warning: already initialized constant TTFunk::Encoding::MacRoman::FROM_UNICODE
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:42: warning: previous definition of FROM_UNICODE was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:50: warning: already initialized constant TTFunk::Encoding::MacRoman::POSTSCRIPT_GLYPH_MAPPING
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:50: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:6: warning: already initialized constant TTFunk::Encoding::Windows1252::TO_UNICODE
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:6: warning: previous definition of TO_UNICODE was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:18: warning: already initialized constant TTFunk::Encoding::Windows1252::FROM_UNICODE
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:18: warning: previous definition of FROM_UNICODE was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:26: warning: already initialized constant TTFunk::Encoding::Windows1252::POSTSCRIPT_GLYPH_MAPPING
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:26: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:9: warning: already initialized constant TTFunk::Table::Glyf::Compound::ARG_1_AND_2_ARE_WORDS
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:9: warning: previous definition of ARG_1_AND_2_ARE_WORDS was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:10: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_SCALE
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:10: warning: previous definition of WE_HAVE_A_SCALE was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:11: warning: already initialized constant TTFunk::Table::Glyf::Compound::MORE_COMPONENTS
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:11: warning: previous definition of MORE_COMPONENTS was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:12: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_AN_X_AND_Y_SCALE
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:12: warning: previous definition of WE_HAVE_AN_X_AND_Y_SCALE was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:13: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_TWO_BY_TWO
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:13: warning: previous definition of WE_HAVE_A_TWO_BY_TWO was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:14: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_INSTRUCTIONS
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:14: warning: previous definition of WE_HAVE_INSTRUCTIONS was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:20: warning: already initialized constant TTFunk::Table::Glyf::Compound::Component
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:20: warning: previous definition of Component was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/hmtx.rb:22: warning: already initialized constant TTFunk::Table::Hmtx::HorizontalMetric
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/hmtx.rb:22: warning: previous definition of HorizontalMetric was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/post/format10.rb:5: warning: already initialized constant TTFunk::Table::Post::Format10::POSTSCRIPT_GLYPHS
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/post/format10.rb:5: warning: previous definition of POSTSCRIPT_GLYPHS was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/sbix.rb:11: warning: already initialized constant TTFunk::Table::Sbix::BitmapData
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/sbix.rb:11: warning: previous definition of BitmapData was here
                      c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_oi/loader.rbe:169: warning: already initialized constant CURIC::OI::PLUGIN
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi.rb:6: warning: previous definition of PLUGIN was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/cmap/subtable.rb:13: warning: already initialized constant TTFunk::Table::Cmap::Subtable::ENCODING_MAPPINGS
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/cmap/subtable.rb:13: warning: previous definition of ENCODING_MAPPINGS was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:6: warning: already initialized constant TTFunk::Encoding::MacRoman::TO_UNICODE
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:6: warning: previous definition of TO_UNICODE was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:42: warning: already initialized constant TTFunk::Encoding::MacRoman::FROM_UNICODE
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:42: warning: previous definition of FROM_UNICODE was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:50: warning: already initialized constant TTFunk::Encoding::MacRoman::POSTSCRIPT_GLYPH_MAPPING
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:50: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:6: warning: already initialized constant TTFunk::Encoding::Windows1252::TO_UNICODE
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:6: warning: previous definition of TO_UNICODE was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:18: warning: already initialized constant TTFunk::Encoding::Windows1252::FROM_UNICODE
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:18: warning: previous definition of FROM_UNICODE was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:26: warning: already initialized constant TTFunk::Encoding::Windows1252::POSTSCRIPT_GLYPH_MAPPING
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:26: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:9: warning: already initialized constant TTFunk::Table::Glyf::Compound::ARG_1_AND_2_ARE_WORDS
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:9: warning: previous definition of ARG_1_AND_2_ARE_WORDS was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:10: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_SCALE
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:10: warning: previous definition of WE_HAVE_A_SCALE was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:11: warning: already initialized constant TTFunk::Table::Glyf::Compound::MORE_COMPONENTS
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:11: warning: previous definition of MORE_COMPONENTS was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:12: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_AN_X_AND_Y_SCALE
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:12: warning: previous definition of WE_HAVE_AN_X_AND_Y_SCALE was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:13: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_TWO_BY_TWO
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:13: warning: previous definition of WE_HAVE_A_TWO_BY_TWO was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:14: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_INSTRUCTIONS
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:14: warning: previous definition of WE_HAVE_INSTRUCTIONS was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:20: warning: already initialized constant TTFunk::Table::Glyf::Compound::Component
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:20: warning: previous definition of Component was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/hmtx.rb:22: warning: already initialized constant TTFunk::Table::Hmtx::HorizontalMetric
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/hmtx.rb:22: warning: previous definition of HorizontalMetric was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/post/format10.rb:5: warning: already initialized constant TTFunk::Table::Post::Format10::POSTSCRIPT_GLYPHS
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/post/format10.rb:5: warning: previous definition of POSTSCRIPT_GLYPHS was here
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/sbix.rb:11: warning: already initialized constant TTFunk::Table::Sbix::BitmapData
                      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/sbix.rb:11: warning: previous definition of BitmapData was here
                      "RubyEncoder loader: C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_true_isolate/rgloader/rgloader27.mingw.x64.so"
                      c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_axis/utils.rbe:123: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                      c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_space/utils.rbe:374: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                      c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/projection/projection.rbs:23: warning: already initialized constant Math::PROJEPSILON
                      c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_projections/dbur_projections.rbe:5: warning: previous definition of PROJEPSILON was here
                      Tolerance default to 0.001
                      radius = xxx
                      segmentation = xxx
                      delete_corners = xxx
                      radius = xxx
                      segmentation = xxx
                      "Add help menu!"
                      "create new"
                      "created"
                      #Sketchup::Menu:0x000001d455838b98
                      (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
                      "Add help menu!"
                      "created"
                      "created"
                      (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open"
                      • N
                        nicolasberthier @fredo6
                        @fredo6
                        I exeprience the same problem in SU24 last updat.
                        Is there any way that the Menu search dialogue can be unblocked ? I would realy appreciate it to be available again on SU24.
                        Thanks !
                        • O
                          optimaforever
                          I have a problem with the MINDSIGHT STUDIOS plugins suddenly not appearing in my toolbars. I realized they also disappear from the Master Toolbar Manager.
                          The plugins are still loaded and accessible from their native toolbars.Capture d'écran 2024-11-25 145538.pngCapture d'écran 2024-11-25 150903.png
                          • fredo6F
                            NEW RELEASE: LordOfTheToolbars v2.9a - 13 Dec 24
                            Requirements
                            • LibFredo6: v14.7a or above
                            LordOfTheToolbars 2.9a is a maintenance release including:
                            • Fix related to an issue preventing VRay commands to execute.
                            Home Page of LordOfTheToolbars for information and Download.
                            Main post of this LordOfTheToolbars thread.
                            alexpacio2013A Y 3 Replies Last reply
                            • alexpacio2013A
                              alexpacio2013 @fredo6
                              @fredo6 It works great, congratulations for your speed and competence, thanks
                              • Y
                                yyxp1989 Newcomers @fredo6
                                Hello @fredo6 I have a problem that I can't solve. Could you help me? LordOfTheToolbars v2.9a It worked fine during the first run and I can add tools icon.
                                However, I couldn't use the Master Toolbar Manager after restarting SketchUp.I can't drag the icon. It doesn't work.
                                The problem remained the same even after reinstalling it.
                                SU Version: 2024.0.594-64bit
                                LibFredo6_v14.9a
                                • fredo6F
                                  fredo6 @yyxp1989
                                  @yyxp1989
                                  I cannot read what is in the black window
                                  Y 1 Reply Last reply
                                  • Y
                                    @fredo6 I switched back to SketchUp 2023, and everything works fine. Thank you for your work.
                                    The issue occurs in SU2024.0.594, which may be a compatibility problem. The Master Toolbar Manager window does not respond to operations.
                                    Click Show DEV Tools
                                    • alexpacio2013A
                                      @fredo6
                                      With the latest version of Lord of thr Toolbar the compatibility problem with vay 7 has been solved but now I find another problem, often when I open sketchup, it crashes, The crash happens just when it goes to open the menu bars created with Lord of the toolbar. I found that by disabling Lord of the Toolbar, Sketchup opens perfectly. I don't understand which one is due to incompatibility with other plugins or from something else. To open sketchup I have to disable Lord of the toolbar AND re-enable it when it is open, through the Sketchauction plugin manager.
                                        AISmebel
                                        Hello Fredo. Do you think it will be possible to return the "Menu" tool in the new SU 2025?
                                        • alexpacio2013A
                                          alexpacio2013
                                          I can no longer create new buttons with Lord of the Toolbar or even edit buttons already created. You can see from the video that it does not save changes made to any button. What can I do I have installed the latest versions anyway.
                                          Video ----
                                            AISmebel
                                            Hello. Can you tell me why, when I add a new script, I click save, but as a result, the script is not saved(((( Everything used to work well.
                                            Error: #<NoMethodError: undefined method `editor_changed' for #<F6_LordOfTheToolbars::PersoDialog:0x000002613cccc438>
                                            Did you mean?  editor_code_changed>
                                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:677:in `dialog_callback_execute'
                                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:608:in `dialog_callback'
                                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2479:in `call'
                                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2479:in `master_callback'
                                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2240:in `j_action'
                                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2199:in `j_callback'
                                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2185:in `block in j_dispatch'
                                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2177:in `each'
                                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2177:in `j_dispatch'
                                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1454:in `block in create_dialog'
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 27
                                            • 28
                                            • 21 / 28
