    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 689.8k Views 99 Watching
    • alexpacio2013A
      alexpacio2013 @fredo6
      @fredo6 It works great, congratulations for your speed and competence, thanks
      • Y
        yyxp1989 Newcomers @fredo6
        Hello @fredo6 I have a problem that I can't solve. Could you help me? LordOfTheToolbars v2.9a It worked fine during the first run and I can add tools icon.
        However, I couldn't use the Master Toolbar Manager after restarting SketchUp.I can't drag the icon. It doesn't work.
        The problem remained the same even after reinstalling it.
        SU Version: 2024.0.594-64bit
        LibFredo6_v14.9a
        fredo6F 1 Reply Last reply
        • fredo6F
          fredo6 @yyxp1989
          @yyxp1989
          I cannot read what is in the black window
          Y 1 Reply Last reply
          • Y
            @fredo6 I switched back to SketchUp 2023, and everything works fine. Thank you for your work.
            The issue occurs in SU2024.0.594, which may be a compatibility problem. The Master Toolbar Manager window does not respond to operations.
            Click Show DEV Tools
            • alexpacio2013A
              @fredo6
              With the latest version of Lord of thr Toolbar the compatibility problem with vay 7 has been solved but now I find another problem, often when I open sketchup, it crashes, The crash happens just when it goes to open the menu bars created with Lord of the toolbar. I found that by disabling Lord of the Toolbar, Sketchup opens perfectly. I don't understand which one is due to incompatibility with other plugins or from something else. To open sketchup I have to disable Lord of the toolbar AND re-enable it when it is open, through the Sketchauction plugin manager.
                AISmebel
                Hello Fredo. Do you think it will be possible to return the "Menu" tool in the new SU 2025?
                • alexpacio2013A
                  alexpacio2013
                  I can no longer create new buttons with Lord of the Toolbar or even edit buttons already created. You can see from the video that it does not save changes made to any button. What can I do I have installed the latest versions anyway.
                  Video ----
                    AISmebel
                    Hello. Can you tell me why, when I add a new script, I click save, but as a result, the script is not saved(((( Everything used to work well.
                    Error: #<NoMethodError: undefined method `editor_changed' for #<F6_LordOfTheToolbars::PersoDialog:0x000002613cccc438>
                    Did you mean?  editor_code_changed>
                    c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:677:in `dialog_callback_execute'
                    c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:608:in `dialog_callback'
                    c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2479:in `call'
                    c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2479:in `master_callback'
                    c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2240:in `j_action'
                    c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2199:in `j_callback'
                    c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2185:in `block in j_dispatch'
                    c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2177:in `each'
                    c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2177:in `j_dispatch'
                    c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1454:in `block in create_dialog'
                    • fredo6F
                      fredo6 @AISmebel
                      @AISmebel
                      This is a bug. I will publish a new version. Thanks for signaling.
                      • fredo6F
                        NEW RELEASE: LordOfTheToolbars v2.9c - 20 Dec 24
                        Requirements
                        • LibFredo6: v14.7a or above
                        LordOfTheToolbars 2.9c is a maintenance release including:
                        • Fix related to an issue preventing VRay commands to execute (Mac)
                        • Fix preventing to save personal scripts
                        Home Page of LordOfTheToolbars for information and Download.
                        Main post of this LordOfTheToolbars thread.
                        • H
                          haymaker @fredo6
                          @fredo6
                          I just upgraded to SU2024
                          My personal icons I made in 2022 are greyed out. when i try to make a new one there is no list available in the command menu, same as larent002.
                          Is this going to be fixed?
                          Do you have a work around?
                          I am missing 6 buttons that I need all the time.
                          • O
                            olopolo
                            Hello,
                            I can't enlarge the “Master toolbar manager” window to reach the “custom toolbars” line.
                            The window remains at this size and the scroll bar doesn't just go to the end.
                            By however, you can see this line in the “print toolbars” window.
                            Thank you in advance for your help and with apologies for this message translated from French
                            • H
                              haymaker
                              Hi Fedo.
                              I have created some keyboard shortcuts to open custom made LOTT pallets. The problem is when I create a new tag or tag folder and one of the shortcut keys is pressed it activates the shortcut and the pallet opens making it impossible to create the tag. It doesn't happen if the shortcut letter is assigned to a native SU command only if it is controlling a LOTT pallet. After trying various things like adding an Alt before the letter now none of the LOTT shortcut keys are working, shortcuts created using SU native UI still work fine. My problems started a few weeks back when I updated to 2024 from 2022. Running Fredo 15.0 and LOTT 2.9c. Please could you offer some assistance as I cant find a work around. Thank you.
                              • fredo6F
                                Shortcuts for LOTT commands should have a modifier.
                                Because there have been changes in the UI framework of Sketchup in SU2023 and SU2024 (versus SU2022), many things are done differently now.
                                • H
                                  haymaker
                                  This post is deleted!
                                  • H
                                    haymaker
                                    OK. I was using shift as a modifier key in the past but if you want to add a capital letter when creating a tag title it would activate the palette.
                                    I can use Ctrl instead, but the problem is compounded by the fact that I use a space mouse key with macro to open LOTT pallets and LOTT no longer seems to recognise the output (it used to) from the space mouse. The problem would appear to be at your end. Example - if I map ctrl A to a native SU shortcut the space mouse executes the command fine but if I map ctrl A to a LOTT pallet when I press the space mouse key I just get a red + flash up momentarily. Thanks
                                      Ramzix
                                      Hi there, humble question, is there a way to possibly get an older version of LOTT? Like 2.7c
                                        Mike Backman
                                        @fredo6
                                        I'm have a tough time getting answerer regarding you products. Forgive me I'm new to using a public forum for customer service . I don't know how to message fredo directly please help.
                                        I have tried several times to figure out why I cannot get LOTT to vignette to show up on my external monitor. (using SU 24 on windows laptop. and LG second monitor. ) In order to use LOTT on my big external monitor I need to make the 2nd screen my "main screen" with in the display settings. This allows the LOTt vignettes to travel off the laptops screen and into my work space of SU. this makes a ton of problems with other programs and my desktop is a mess when I'm working only on my laptop.
                                        fredo6F F 2 Replies Last reply
                                        • fredo6F
                                          fredo6 @Mike Backman
                                          @Mike-Backman
                                          There is no control of the API over monitors, not even an access to information.
                                          So, it might not work with LOTT, but I can't do anything about it.
                                          • F
                                            FlorinAp @Mike Backman
                                            @Mike-Backman This happens with other few programs (but mostly with Sketchup and Sketchup extensions) when you have set different DPi (other than the native one for each monitor) for one or more monitors.
                                            Sometimes, windows by default sets arbitrary DPi different than the native one of your monitor.
                                            You just have to check and manually choose the default DPi.
                                            M 1 Reply Last reply
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 27
                                            • 28
                                            • 21 / 28
