    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    558 Posts 101 Posters 689.7k Views 99 Watching
    • F
      FlorinAp @FlorinAp
      @FlorinAp Well man, below is the content from the ruby window, for me is an alien language, but maybe you can make sense of it...!
      For me is not a big deal because now I use mostly SU 23 and 24 - it's just a sick incurable stubbornness to understand and fix everything I touch, so if it makes sense to you maybe you will be willing to share; I don't see nothing "Fredo" related, but it seems to be a conflict created by some Curic extensions....
      "finished reading language file
      tb_mode,single
      tb_Settingout,true
      tb_Draw,true
      tb_Edit,true
      tb_Array,true
      tb_Wall,true
      tb_Staircase,true
      tb_Win,true
      tb_Roof,true
      tb_Site,true
      tb_Structure,true
      point_on_face,true
      divide,true
      align,true
      perpendicular_line,true
      fonplane,true
      bestface,true
      extrude1,true
      extrude2,true
      move_vertex,true
      fillet,true
      chamfer,true
      extend,true
      offset_edge,true
      hline_faces,true
      slopeedges,true
      linear_array,true
      rect_array,true
      polar_array,true
      path_array,true
      wallsctrl,true
      opening,true
      hgroove,true
      escalator,true
      wframe,true
      dframe,true
      paneldivide,true
      screen1,true
      hlouvres,true
      vlouvres,true
      joists,true
      roof1,true
      hiproof,true
      revsurf,true
      mdeck,true
      stairsctrl,true
      profiles_on_plane,true
      cutfill,true
      siteb,true
      fndctrl,true
      columnctrl,true
      contour,true
      setlayer,true
      mergelayer,true
      framesel,true
      scale,true
      center1,true
      ptsinfo,true
      extrude3,true
      profiles3d,true
      extrude0,true
      loading 1001bit pro menu >> true
      c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_projections/dbur_projections.rbe:5: warning: already initialized constant Math::PROJEPSILON
      c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_guidetools/dbur_guidetools.rbe:6: warning: previous definition of PROJEPSILON was here
      true
      Sketchup Version is = 17
      88
      "icon_thickness_mode.svg"
      "c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_dio2/Resources/icon_thickness_mode.svg"
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/cmap/subtable.rb:13: warning: already initialized constant TTFunk::Table::Cmap::Subtable::ENCODING_MAPPINGS
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/cmap/subtable.rb:13: warning: previous definition of ENCODING_MAPPINGS was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:6: warning: already initialized constant TTFunk::Encoding::MacRoman::TO_UNICODE
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:6: warning: previous definition of TO_UNICODE was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:42: warning: already initialized constant TTFunk::Encoding::MacRoman::FROM_UNICODE
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:42: warning: previous definition of FROM_UNICODE was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:50: warning: already initialized constant TTFunk::Encoding::MacRoman::POSTSCRIPT_GLYPH_MAPPING
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/mac_roman.rb:50: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:6: warning: already initialized constant TTFunk::Encoding::Windows1252::TO_UNICODE
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:6: warning: previous definition of TO_UNICODE was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:18: warning: already initialized constant TTFunk::Encoding::Windows1252::FROM_UNICODE
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:18: warning: previous definition of FROM_UNICODE was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:26: warning: already initialized constant TTFunk::Encoding::Windows1252::POSTSCRIPT_GLYPH_MAPPING
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/encoding/windows_1252.rb:26: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:9: warning: already initialized constant TTFunk::Table::Glyf::Compound::ARG_1_AND_2_ARE_WORDS
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:9: warning: previous definition of ARG_1_AND_2_ARE_WORDS was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:10: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_SCALE
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:10: warning: previous definition of WE_HAVE_A_SCALE was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:11: warning: already initialized constant TTFunk::Table::Glyf::Compound::MORE_COMPONENTS
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:11: warning: previous definition of MORE_COMPONENTS was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:12: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_AN_X_AND_Y_SCALE
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:12: warning: previous definition of WE_HAVE_AN_X_AND_Y_SCALE was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:13: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_TWO_BY_TWO
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:13: warning: previous definition of WE_HAVE_A_TWO_BY_TWO was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:14: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_INSTRUCTIONS
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:14: warning: previous definition of WE_HAVE_INSTRUCTIONS was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:20: warning: already initialized constant TTFunk::Table::Glyf::Compound::Component
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/glyf/compound.rb:20: warning: previous definition of Component was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/hmtx.rb:22: warning: already initialized constant TTFunk::Table::Hmtx::HorizontalMetric
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/hmtx.rb:22: warning: previous definition of HorizontalMetric was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/post/format10.rb:5: warning: already initialized constant TTFunk::Table::Post::Format10::POSTSCRIPT_GLYPHS
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/post/format10.rb:5: warning: previous definition of POSTSCRIPT_GLYPHS was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/sbix.rb:11: warning: already initialized constant TTFunk::Table::Sbix::BitmapData
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_dio2/Lib/ttfunk/table/sbix.rb:11: warning: previous definition of BitmapData was here
      c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_oi/loader.rbe:169: warning: already initialized constant CURIC::OI::PLUGIN
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi.rb:6: warning: previous definition of PLUGIN was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/cmap/subtable.rb:13: warning: already initialized constant TTFunk::Table::Cmap::Subtable::ENCODING_MAPPINGS
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/cmap/subtable.rb:13: warning: previous definition of ENCODING_MAPPINGS was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:6: warning: already initialized constant TTFunk::Encoding::MacRoman::TO_UNICODE
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:6: warning: previous definition of TO_UNICODE was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:42: warning: already initialized constant TTFunk::Encoding::MacRoman::FROM_UNICODE
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:42: warning: previous definition of FROM_UNICODE was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/mac_roman.rb:50: warning: already initialized constant TTFunk::Encoding::MacRoman::POSTSCRIPT_GLYPH_MAPPING
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/mac_roman.rb:50: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:6: warning: already initialized constant TTFunk::Encoding::Windows1252::TO_UNICODE
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:6: warning: previous definition of TO_UNICODE was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:18: warning: already initialized constant TTFunk::Encoding::Windows1252::FROM_UNICODE
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:18: warning: previous definition of FROM_UNICODE was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/encoding/windows_1252.rb:26: warning: already initialized constant TTFunk::Encoding::Windows1252::POSTSCRIPT_GLYPH_MAPPING
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/encoding/windows_1252.rb:26: warning: previous definition of POSTSCRIPT_GLYPH_MAPPING was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:9: warning: already initialized constant TTFunk::Table::Glyf::Compound::ARG_1_AND_2_ARE_WORDS
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:9: warning: previous definition of ARG_1_AND_2_ARE_WORDS was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:10: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_SCALE
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:10: warning: previous definition of WE_HAVE_A_SCALE was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:11: warning: already initialized constant TTFunk::Table::Glyf::Compound::MORE_COMPONENTS
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:11: warning: previous definition of MORE_COMPONENTS was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:12: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_AN_X_AND_Y_SCALE
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:12: warning: previous definition of WE_HAVE_AN_X_AND_Y_SCALE was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:13: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_A_TWO_BY_TWO
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:13: warning: previous definition of WE_HAVE_A_TWO_BY_TWO was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:14: warning: already initialized constant TTFunk::Table::Glyf::Compound::WE_HAVE_INSTRUCTIONS
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:14: warning: previous definition of WE_HAVE_INSTRUCTIONS was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/glyf/compound.rb:20: warning: already initialized constant TTFunk::Table::Glyf::Compound::Component
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/glyf/compound.rb:20: warning: previous definition of Component was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/hmtx.rb:22: warning: already initialized constant TTFunk::Table::Hmtx::HorizontalMetric
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/hmtx.rb:22: warning: previous definition of HorizontalMetric was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/post/format10.rb:5: warning: already initialized constant TTFunk::Table::Post::Format10::POSTSCRIPT_GLYPHS
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/post/format10.rb:5: warning: previous definition of POSTSCRIPT_GLYPHS was here
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_stretch/Lib/ttfunk/table/sbix.rb:11: warning: already initialized constant TTFunk::Table::Sbix::BitmapData
      C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_oi/Lib/ttfunk/table/sbix.rb:11: warning: previous definition of BitmapData was here
      "RubyEncoder loader: C:/Users/Florin Apostoiu/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/curic_true_isolate/rgloader/rgloader27.mingw.x64.so"
      c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_axis/utils.rbe:123: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
      c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_space/utils.rbe:374: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
      c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/projection/projection.rbs:23: warning: already initialized constant Math::PROJEPSILON
      c:/users/florin apostoiu/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/dbur_projections/dbur_projections.rbe:5: warning: previous definition of PROJEPSILON was here
      Tolerance default to 0.001
      radius = xxx
      segmentation = xxx
      delete_corners = xxx
      radius = xxx
      segmentation = xxx
      "Add help menu!"
      "create new"
      "created"
      #Sketchup::Menu:0x000001d455838b98
      (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
      "Add help menu!"
      "created"
      "created"
      (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open"
      • N
        nicolasberthier @fredo6
        @fredo6
        I exeprience the same problem in SU24 last updat.
        Is there any way that the Menu search dialogue can be unblocked ? I would realy appreciate it to be available again on SU24.
        Thanks !
        • O
          optimaforever
          I have a problem with the MINDSIGHT STUDIOS plugins suddenly not appearing in my toolbars. I realized they also disappear from the Master Toolbar Manager.
          The plugins are still loaded and accessible from their native toolbars.Capture d'écran 2024-11-25 145538.pngCapture d'écran 2024-11-25 150903.png
          • fredo6F
            NEW RELEASE: LordOfTheToolbars v2.9a - 13 Dec 24
            Requirements
            • LibFredo6: v14.7a or above
            LordOfTheToolbars 2.9a is a maintenance release including:
            • Fix related to an issue preventing VRay commands to execute.
            Home Page of LordOfTheToolbars for information and Download.
            Main post of this LordOfTheToolbars thread.
            alexpacio2013A Y 3 Replies Last reply
            • alexpacio2013A
              alexpacio2013 @fredo6
              @fredo6 It works great, congratulations for your speed and competence, thanks
              • Y
                yyxp1989 Newcomers @fredo6
                Hello @fredo6 I have a problem that I can't solve. Could you help me? LordOfTheToolbars v2.9a It worked fine during the first run and I can add tools icon.
                However, I couldn't use the Master Toolbar Manager after restarting SketchUp.I can't drag the icon. It doesn't work.
                The problem remained the same even after reinstalling it.
                SU Version: 2024.0.594-64bit
                LibFredo6_v14.9a
                fredo6F 1 Reply Last reply
                • fredo6F
                  fredo6 @yyxp1989
                  @yyxp1989
                  I cannot read what is in the black window
                  Y 1 Reply Last reply
                  • Y
                    @fredo6 I switched back to SketchUp 2023, and everything works fine. Thank you for your work.
                    The issue occurs in SU2024.0.594, which may be a compatibility problem. The Master Toolbar Manager window does not respond to operations.
                    Click Show DEV Tools
                    • alexpacio2013A
                      @fredo6
                      With the latest version of Lord of thr Toolbar the compatibility problem with vay 7 has been solved but now I find another problem, often when I open sketchup, it crashes, The crash happens just when it goes to open the menu bars created with Lord of the toolbar. I found that by disabling Lord of the Toolbar, Sketchup opens perfectly. I don't understand which one is due to incompatibility with other plugins or from something else. To open sketchup I have to disable Lord of the toolbar AND re-enable it when it is open, through the Sketchauction plugin manager.
                        AISmebel
                        Hello Fredo. Do you think it will be possible to return the "Menu" tool in the new SU 2025?
                        • alexpacio2013A
                          alexpacio2013
                          I can no longer create new buttons with Lord of the Toolbar or even edit buttons already created. You can see from the video that it does not save changes made to any button. What can I do I have installed the latest versions anyway.
                          Video ----
                            AISmebel
                            Hello. Can you tell me why, when I add a new script, I click save, but as a result, the script is not saved(((( Everything used to work well.
                            Error: #<NoMethodError: undefined method `editor_changed' for #<F6_LordOfTheToolbars::PersoDialog:0x000002613cccc438>
                            Did you mean?  editor_code_changed>
                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:677:in `dialog_callback_execute'
                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarspersodialog.rbe:608:in `dialog_callback'
                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2479:in `call'
                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2479:in `master_callback'
                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2240:in `j_action'
                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2199:in `j_callback'
                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2185:in `block in j_dispatch'
                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2177:in `each'
                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2177:in `j_dispatch'
                            c:/users/pc/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1454:in `block in create_dialog'
                            • fredo6F
                              fredo6 @AISmebel
                              @AISmebel
                              This is a bug. I will publish a new version. Thanks for signaling.
                              • fredo6F
                                NEW RELEASE: LordOfTheToolbars v2.9c - 20 Dec 24
                                Requirements
                                LordOfTheToolbars 2.9c is a maintenance release including:
                                • Fix related to an issue preventing VRay commands to execute (Mac)
                                • Fix preventing to save personal scripts
                                • H
                                  haymaker @fredo6
                                  @fredo6
                                  I just upgraded to SU2024
                                  My personal icons I made in 2022 are greyed out. when i try to make a new one there is no list available in the command menu, same as larent002.
                                  Is this going to be fixed?
                                  Do you have a work around?
                                  I am missing 6 buttons that I need all the time.
                                  • O
                                    olopolo
                                    Hello,
                                    I can't enlarge the “Master toolbar manager” window to reach the “custom toolbars” line.
                                    The window remains at this size and the scroll bar doesn't just go to the end.
                                    By however, you can see this line in the “print toolbars” window.
                                    Thank you in advance for your help and with apologies for this message translated from French
                                    • H
                                      haymaker
                                      Hi Fedo.
                                      I have created some keyboard shortcuts to open custom made LOTT pallets. The problem is when I create a new tag or tag folder and one of the shortcut keys is pressed it activates the shortcut and the pallet opens making it impossible to create the tag. It doesn't happen if the shortcut letter is assigned to a native SU command only if it is controlling a LOTT pallet. After trying various things like adding an Alt before the letter now none of the LOTT shortcut keys are working, shortcuts created using SU native UI still work fine. My problems started a few weeks back when I updated to 2024 from 2022. Running Fredo 15.0 and LOTT 2.9c. Please could you offer some assistance as I cant find a work around. Thank you.
                                      • fredo6F
                                        Shortcuts for LOTT commands should have a modifier.
                                        Because there have been changes in the UI framework of Sketchup in SU2023 and SU2024 (versus SU2022), many things are done differently now.
                                        • H
                                          haymaker
                                          This post is deleted!
                                          • H
                                            haymaker
                                            OK. I was using shift as a modifier key in the past but if you want to add a capital letter when creating a tag title it would activate the palette.
                                            I can use Ctrl instead, but the problem is compounded by the fact that I use a space mouse key with macro to open LOTT pallets and LOTT no longer seems to recognise the output (it used to) from the space mouse. The problem would appear to be at your end. Example - if I map ctrl A to a native SU shortcut the space mouse executes the command fine but if I map ctrl A to a LOTT pallet when I press the space mouse key I just get a red + flash up momentarily. Thanks
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 27
                                            • 28
                                            • 21 / 28
