    Organic water tap
    renderpluginsextensions
    21 Posts 9 Posters 14.3k Views 9 Watching
    • ntxdaveN Offline
      ntxdave
      Well done and good tutorial Alvis. πŸ‘
      Press F1...thank me later
      • BoxB Offline
        People are scared of quads and SUbD when in it's basic form it is just a matter of moving a few edges around.
        I'm not suggesting this is anywhere near a complete shape, but it gives you an idea of what is possible with very little.
          Builder54
          Profound in its simplicity Box. 😲 Love the Section option to remove inside faces.
          "Don't be afraid of working hard. There are No shortcuts to mastering something."
          Robh Ruppel
            Loving these various solutions to creating a water tap! πŸ‘ πŸ‘
            • panixiaP Offline
              panixia
              Here's my entry. As Alvin said, photo reference is bad.
              I just quickly eyballed this, focusing mainly on the proper topology.
              I believe the shape can be perfected a bit, but the topology itself should be basically something like this.
              (I did it solid just for the sake of fun) πŸ˜„
              • panixiaP Offline
                panixia
                This is the base mesh, if you want to play with.
                Sub-D_Faucet_LITE.skp
                • alvisA Offline
                  alvis
                  i'm saying that there are people who do it better than me. i can see where my mistake was, but i was on the right track. πŸ‘ πŸ‘ πŸ‘
                  • panixiaP Offline
                    panixia
                    Thank you man, I really appreciate it from you.
                    You were one of them I really looked at as "teacher" in the past years, when I was at the beginning.
                    Your clever modeling has always been a source of inspiration for me.
                    I believe in this case, you did it right with the vertex count (8 is the way here), but you had to rotate everything 45Β° and then the topology naturally follow along.
                    I did the exact same mistake on first try, then realized I had to rotate stuff and having the base octagon facing flat forward.
                    • pbacotP Offline
                      Cool work guys
                      • panixiaP Offline
                        panixia
                        Played with it another bit in the afternoon.
                        I think it has decent overall shape and improved topology in the top handle.
                        Also fixed bad naming and pivot orientation, scaled it properly and saved it in skp 2017 version.
                        Attached here the improved model. πŸ‘
                        Sub-D_DamixaWaterTap.skp
                        • alvisA Offline
                          alvis
                          Bravo πŸ‘
                            Builder54
                            How is the perfectly round faucet mouth done? It looks like you both added a circle to the mesh.
                            Robh Ruppel
                            • panixiaP Offline
                              panixia
                              Yes, you can basically add some 8-sided circle and then loft/bridge with existing topology.
                              You should also try to use way less segments for the top rounded part and avoid those nasty star poles (those vertices where 6 edges are connected).
                                Builder54
                                Thanks for providing your model. It took me a long time to figure out even with your model loaded to pull the spout from the stem. I learned a lot here.
                                Your model is on the right
                                Robh Ruppel
                                • panixiaP Offline
                                  panixia
                                  Glad that it helped πŸ˜„
                                  • Epix3DE Offline
                                    Epix3D
                                    WoW! Some really great results here! Unfortunately I could not get a reference photo straight on from sideview but it seems you got great results from "eyeballing".
                                    I learned alot from this and will use your tutorials to improve Sub divide modelling.
                                    Thank you all for your effort ; )
