    Organic water tap
    renderpluginsextensions
    21 Posts 9 Posters 13.2k Views 9 Watching
    • Epix3DE Offline
      Epix3D
      Trying to model a Damixa water tap in SketchUp using Fredos Curviloft. Not satisfied with the results.
      Maybe I could use SubD for this but I have no experience. How can I divide this model using SubD?
      Can anybody show me the steps how to do it?
      Find attached the SU model. I saved it from 2021>2019
      [img]Damixa.jpg[/img]
      Damixa2019.skp
      • HornOxxH Offline
        HornOxx
        Hi - here's a fast and dirty first try, starting with a 12-sided polygon - half of it as a component, the other half mirrored then... hope this helps to start with!? πŸ˜‰
        Since your model is probably already too heavily polygonized by the used curviloft approach, I fear that it is too complex to use this for a SubD approach then. But despite everything, your approach is good! πŸ‘
        skp2017
        never trust a skinny cook
          Builder54
          If you want to use SubD then the key is to work with Quads. As mentioned, curviloft will create a complex mesh. You can unsmooth that mesh with Quadface Tools. Both cylinders were created with Curviloft. The right one I used unsmooth option in quadface tools. I used Vertex Tools to pull out the spout.
          "Don't be afraid of working hard. There are No shortcuts to mastering something."
          Robh Ruppel
          • alvisA Offline
            alvis
            When modeling organic forms, your enemy has a large number of polygons. Then it's easy to lose control of the simulation. I tried to show something how I do it. Not completely perfect because I was in a hurry, a little wrong topology. Basic tools: Move, Scale, VertexTool, SubD. By the way, the photo is from a bad angle.
              Builder54
              The day I can produce this "in a hurry" I'll be a happy man Alvis! πŸ˜„
              Robh Ruppel
              • ntxdaveN Offline
                ntxdave
                Well done and good tutorial Alvis. πŸ‘
                • BoxB Offline
                  People are scared of quads and SUbD when in it's basic form it is just a matter of moving a few edges around.
                  I'm not suggesting this is anywhere near a complete shape, but it gives you an idea of what is possible with very little.
                    Builder54
                    Profound in its simplicity Box. 😲 Love the Section option to remove inside faces.
                    Robh Ruppel
                      Loving these various solutions to creating a water tap! πŸ‘ πŸ‘
                      • panixiaP Offline
                        panixia
                        Here's my entry. As Alvin said, photo reference is bad.
                        I just quickly eyballed this, focusing mainly on the proper topology.
                        I believe the shape can be perfected a bit, but the topology itself should be basically something like this.
                        (I did it solid just for the sake of fun) πŸ˜„
                        • panixiaP Offline
                          panixia
                          This is the base mesh, if you want to play with.
                          Sub-D_Faucet_LITE.skp
                          • alvisA Offline
                            alvis
                            i'm saying that there are people who do it better than me. i can see where my mistake was, but i was on the right track. πŸ‘ πŸ‘ πŸ‘
                            • panixiaP Offline
                              panixia
                              Thank you man, I really appreciate it from you.
                              You were one of them I really looked at as "teacher" in the past years, when I was at the beginning.
                              Your clever modeling has always been a source of inspiration for me.
                              I believe in this case, you did it right with the vertex count (8 is the way here), but you had to rotate everything 45Β° and then the topology naturally follow along.
                              I did the exact same mistake on first try, then realized I had to rotate stuff and having the base octagon facing flat forward.
                              • pbacotP Offline
                                Cool work guys
                                • panixiaP Offline
                                  panixia
                                  Played with it another bit in the afternoon.
                                  I think it has decent overall shape and improved topology in the top handle.
                                  Also fixed bad naming and pivot orientation, scaled it properly and saved it in skp 2017 version.
                                  Attached here the improved model. πŸ‘
                                  Sub-D_DamixaWaterTap.skp
                                  • alvisA Offline
                                    alvis
                                    Bravo πŸ‘
                                      Builder54
                                      How is the perfectly round faucet mouth done? It looks like you both added a circle to the mesh.
                                      Robh Ruppel
                                      • panixiaP Offline
                                        panixia
                                        Yes, you can basically add some 8-sided circle and then loft/bridge with existing topology.
                                        You should also try to use way less segments for the top rounded part and avoid those nasty star poles (those vertices where 6 edges are connected).
                                          Builder54
                                          Thanks for providing your model. It took me a long time to figure out even with your model loaded to pull the spout from the stem. I learned a lot here.
                                          Your model is on the right
                                          Robh Ruppel
                                          • panixiaP Offline
                                            panixia
                                            Glad that it helped πŸ˜„
