    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • BoxB Offline
      Is this what you mean?
      I didn't save the model so I reproduced it.
      Note the outer layer I have thickened with JPP, not shown in the original image.
      • BoxB Offline
        This one shows how if you SUbD before JPP you get the sharp edges in the original render rather than the soft ones in the second model.
        • HornOxxH Offline
          HornOxx
          Thanks, now I got it ๐Ÿ˜„ - I first assumed to see 2 shapes above. To see your competent handling with geometry is impressive allways ๐Ÿ‘ - for exampe that you started with a section plane to generate this first shape ...
          never trust a skinny cook
          • BoxB Offline
            No, you are right, there are two shapes, the red and the blue. The blue one fits around the red one.
            Here's the rest of it, hope that makes sense.
            • HornOxxH Offline
              HornOxx
              Yes ๐Ÿ˜„ - and I really enjoy this kind of geometry exercises ...
              • V Offline
                Vizan
                @cotty said:
                Hopefully the beginning of a looong and helpful topic...
                How did you render with a square grid without triangles? It doesnโ€™t work out for me((
                  Callegari_hr
                  In QuadFaceTools plugin there is Convert Triangulated Mesh to Quads, select two triangles of one quad and run that tool.
                  • cottyC Offline
                    cotty
                    You can use this tool with no visible hidden geometry for it.
                    my SketchUp gallery
                    • V Offline
                      Vizan
                      [attachment=4:3726vs77]<!-- ia4 -->quads.jpg<!-- ia4 -->[/attachment:3726vs77]
                      After the Subd plugin, my model looks like on a screenshot. But when rendering a polygon mesh in Vray, I see triangles. I noticed that if the dividing line of the square is hidden, then it is not visible on the visualization.
                      It would be great if the Subd plugin itself hid this dividing line, or there would be some sort of automatic way.
                      • BoxB Offline
                        This is more of a v-ray question, if V-ray doesn't have an option to render specific edges then you need to be a bit clever.
                        Render the shape then export the edges as a transparent background .png and combine the two.
                        Hera's a very simple example.
                        • V Offline
                          Vizan
                          Thanks! This is a good idea)))
                            I'll logged it as something to look into. I just need to make sure it doesn't have any other unintended side-effects.
                                bahri06
                                My first post here... still WIP Honda CB 175
                                Thanks to Pilou for all your tutorial on you tube channel
                                • cottyC Offline
                                  cotty
                                  great model and impressive first post...
                                  my SketchUp gallery
                                    Cool motor bike! ๐Ÿ˜Ž
                                    (Ps these above videos are not my own videos, alas! ๐Ÿ˜‰
                                    • HornOxxH Offline
                                      HornOxx
                                      ๐Ÿ‘ perfect! and a nice model idea ๐Ÿ˜„
                                      • V Offline
                                        Vizan
                                        Thank you for your attention to this!
                                        I noticed that the FredoCorner plugin does this automatically.
                                          Wow - that's an impressible detailed model! Very nice topology as well! ๐Ÿ‘ ๐Ÿ‘
                                          • panixiaP Offline
                                            panixia
                                            Dirt jumping bike trails.
                                            Sub-d concept
                                            3d printed version ๐Ÿ˜›
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 82
                                            • 83
                                            • 69 / 83
