    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.3m Views 79 Watching
    • V
      Vizan
      @cotty said:
      You can use this tool with no visible hidden geometry for it.
      [attachment=4:3726vs77]<!-- ia4 -->quads.jpg<!-- ia4 -->[/attachment:3726vs77]
      After the Subd plugin, my model looks like on a screenshot. But when rendering a polygon mesh in Vray, I see triangles. I noticed that if the dividing line of the square is hidden, then it is not visible on the visualization.
      It would be great if the Subd plugin itself hid this dividing line, or there would be some sort of automatic way.
      • BoxB
        This is more of a v-ray question, if V-ray doesn't have an option to render specific edges then you need to be a bit clever.
        Render the shape then export the edges as a transparent background .png and combine the two.
        Hera's a very simple example.
        • V
          Vizan
          Thanks! This is a good idea)))
            I'll logged it as something to look into. I just need to make sure it doesn't have any other unintended side-effects.
              • B
                bahri06
                My first post here... still WIP Honda CB 175
                Thanks to Pilou for all your tutorial on you tube channel
                • cottyC
                  cotty
                  great model and impressive first post...
                  my SketchUp gallery
                    Cool motor bike! ๐Ÿ˜Ž
                    (Ps these above videos are not my own videos, alas! ๐Ÿ˜‰
                    • HornOxxH
                      HornOxx
                      ๐Ÿ‘ perfect! and a nice model idea ๐Ÿ˜„
                      never trust a skinny cook
                      • V
                        Vizan
                        Thank you for your attention to this!
                        I noticed that the FredoCorner plugin does this automatically.
                          Wow - that's an impressible detailed model! Very nice topology as well! ๐Ÿ‘ ๐Ÿ‘
                          • panixiaP
                            panixia
                            Dirt jumping bike trails.
                            Sub-d concept
                            3d printed version ๐Ÿ˜›
                            • panixiaP
                              panixia
                              Please no, or at least make this as an option one can toggle on/off, because in general hidden geometry is BAD. ๐Ÿ˜
                              IMHO it would be a more clean workflow to do all the modeling avoiding hidden geometry and only at the last stage, when finalizing geometry for rendering, select all the smoothed edges (select all geometery and then run "selection toys -> select only -> soft edges") and turn them invisible.
                              Fredo corner plugin has an option for this in "rounding parameters->borders->inner edges" and you can toggle.
                              I think that's a good approach, because it can be adapted for different workflows.
                              • V
                                Vizan
                                I found a solution to this problem
                                https://www.youtube.com/watch?v=eBCDTTtv2Hc
                                  The solution is making the edges not only soft+smooth, but also hidden?
                                    rspierenburg
                                    That and using a Vray Toon Material that renders the subd'ed edges.
                                    • V
                                      Vizan
                                      Yes, here I showed how this can be done with the additional selection_edge and Curic Deep Select plugins https://www.youtube.com/watch?v=eBCDTTtv2Hc
                                      • panixiaP
                                        panixia
                                        As I said you cand do that using "selection toys" as well.
                                          This feels like a V-Ray bug to me. I'd expect soft edges also to not be rendered along with hidden edges.
                                          • V
                                            Vizan
                                            Unfortunately it is, but it is not critical for me. Of course I wanted this feature to work correctly.
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 83
                                            • 84
                                            • 68 / 84
