    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.3m Views 79 Watching
    • V
      Vizan
      @box said:
      This is more of a v-ray question, if V-ray doesn't have an option to render specific edges then you need to be a bit clever.
      Render the shape then export the edges as a transparent background .png and combine the two.
      Hera's a very simple example.
      Thanks! This is a good idea)))
        @vizan said:
        It would be great if the Subd plugin itself hid this dividing line, or there would be some sort of automatic way.
        I'll logged it as something to look into. I just need to make sure it doesn't have any other unintended side-effects.
          • B
            bahri06
            My first post here... still WIP Honda CB 175
            Thanks to Pilou for all your tutorial on you tube channel
            • cottyC
              cotty
              great model and impressive first post...
              my SketchUp gallery
                Cool motor bike! 😎
                (Ps these above videos are not my own videos, alas! 😉
                • HornOxxH
                  HornOxx
                  👍 perfect! and a nice model idea 😄
                  never trust a skinny cook
                  • V
                    Vizan
                    Thank you for your attention to this!
                    I noticed that the FredoCorner plugin does this automatically.
                      Wow - that's an impressible detailed model! Very nice topology as well! 👍 👍
                      • panixiaP
                        panixia
                        Dirt jumping bike trails.
                        Sub-d concept
                        3d printed version 😛
                        • panixiaP
                          panixia
                          Please no, or at least make this as an option one can toggle on/off, because in general hidden geometry is BAD. 😐
                          IMHO it would be a more clean workflow to do all the modeling avoiding hidden geometry and only at the last stage, when finalizing geometry for rendering, select all the smoothed edges (select all geometery and then run "selection toys -> select only -> soft edges") and turn them invisible.
                          Fredo corner plugin has an option for this in "rounding parameters->borders->inner edges" and you can toggle.
                          I think that's a good approach, because it can be adapted for different workflows.
                          • V
                            Vizan
                            I found a solution to this problem
                            https://www.youtube.com/watch?v=eBCDTTtv2Hc
                              The solution is making the edges not only soft+smooth, but also hidden?
                                rspierenburg
                                That and using a Vray Toon Material that renders the subd'ed edges.
                                • V
                                  Vizan
                                  Yes, here I showed how this can be done with the additional selection_edge and Curic Deep Select plugins https://www.youtube.com/watch?v=eBCDTTtv2Hc
                                  • panixiaP
                                    panixia
                                    As I said you cand do that using "selection toys" as well.
                                      This feels like a V-Ray bug to me. I'd expect soft edges also to not be rendered along with hidden edges.
                                      • V
                                        Vizan
                                        Unfortunately it is, but it is not critical for me. Of course I wanted this feature to work correctly.
                                        • V
                                          Vizan
                                          Here are my examples of using the SubD tool, in part or in full;)
                                          • panixiaP
                                            panixia
                                            Nice furniture models. 👍
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 83
                                            • 84
                                            • 68 / 84
