    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.1m Views 79 Watching
    • HornOxxH
      HornOxx
      Yes ๐Ÿ˜„ - and I really enjoy this kind of geometry exercises ...
      never trust a skinny cook
      • V
        Vizan
        @cotty said:
        Hopefully the beginning of a looong and helpful topic...
        How did you render with a square grid without triangles? It doesnโ€™t work out for me((
        • C
          Callegari_hr
          In QuadFaceTools plugin there is Convert Triangulated Mesh to Quads, select two triangles of one quad and run that tool.
          • cottyC
            cotty
            You can use this tool with no visible hidden geometry for it.
            my SketchUp gallery
            • V
              Vizan
              [attachment=4:3726vs77]<!-- ia4 -->quads.jpg<!-- ia4 -->[/attachment:3726vs77]
              After the Subd plugin, my model looks like on a screenshot. But when rendering a polygon mesh in Vray, I see triangles. I noticed that if the dividing line of the square is hidden, then it is not visible on the visualization.
              It would be great if the Subd plugin itself hid this dividing line, or there would be some sort of automatic way.
              • BoxB
                This is more of a v-ray question, if V-ray doesn't have an option to render specific edges then you need to be a bit clever.
                Render the shape then export the edges as a transparent background .png and combine the two.
                Hera's a very simple example.
                • V
                  Vizan
                  Thanks! This is a good idea)))
                    I'll logged it as something to look into. I just need to make sure it doesn't have any other unintended side-effects.
                      • B
                        bahri06
                        My first post here... still WIP Honda CB 175
                        Thanks to Pilou for all your tutorial on you tube channel
                        • cottyC
                          cotty
                          great model and impressive first post...
                          my SketchUp gallery
                            Cool motor bike! ๐Ÿ˜Ž
                            (Ps these above videos are not my own videos, alas! ๐Ÿ˜‰
                            • HornOxxH
                              HornOxx
                              ๐Ÿ‘ perfect! and a nice model idea ๐Ÿ˜„
                              • V
                                Vizan
                                Thank you for your attention to this!
                                I noticed that the FredoCorner plugin does this automatically.
                                  Wow - that's an impressible detailed model! Very nice topology as well! ๐Ÿ‘ ๐Ÿ‘
                                  • panixiaP
                                    panixia
                                    Dirt jumping bike trails.
                                    Sub-d concept
                                    3d printed version ๐Ÿ˜›
                                    • panixiaP
                                      panixia
                                      Please no, or at least make this as an option one can toggle on/off, because in general hidden geometry is BAD. ๐Ÿ˜
                                      IMHO it would be a more clean workflow to do all the modeling avoiding hidden geometry and only at the last stage, when finalizing geometry for rendering, select all the smoothed edges (select all geometery and then run "selection toys -> select only -> soft edges") and turn them invisible.
                                      Fredo corner plugin has an option for this in "rounding parameters->borders->inner edges" and you can toggle.
                                      I think that's a good approach, because it can be adapted for different workflows.
                                      • V
                                        Vizan
                                        I found a solution to this problem
                                        https://www.youtube.com/watch?v=eBCDTTtv2Hc
                                          The solution is making the edges not only soft+smooth, but also hidden?
                                            rspierenburg
                                            That and using a Vray Toon Material that renders the subd'ed edges.
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 83
                                            • 84
                                            • 68 / 84
