    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.0m Views 79 Watching
    • cottyC Offline
      cotty
      Thank you, those are rendered with Indigo Renderer.
      my SketchUp gallery
      • tuna1957T Offline
        tuna1957
        A little late night messing about..... Made the little curved piece down front, follow me then Vertex tools to get the twist... Now what ???? Copy around and you get a kind of crazy flower shaped fruit bowl !
        • HornOxxH Offline
          HornOxx
          πŸ˜„ love this "messing" πŸ‘
          (btw "Messing" in German is the metal alloy brass πŸ˜„ πŸ˜„)
          never trust a skinny cook
          • tuna1957T Offline
            tuna1957
            @hornoxx said:
            πŸ™‚ love this "messing" πŸ‘
            Thanks HornOxx. Curious would "fooling about" translate better πŸ˜‰
            • O Offline
              optimaforever
              @thomthom said:
              Btw, do you have some quad that are not fully QuadFace quads? I see some unexpected uneven edges in the back there:
              [attachment=0:1mfg7n1x]<!-- ia0 -->2019-01-19_13h26_35.png<!-- ia0 -->[/attachment:1mfg7n1x]
              This is the same strange behaviour I got last year with some meshes. Dunno why, but it seems that some vertices react as a 1.0 crease when subdivided although they are 0 when checked with the crease tool.
              I usually delete the problematic edges and redraw the geometry from scratch when that happens.
              • tuna1957T Offline
                tuna1957
                More late night fooling about / practice. Seem obsessed with what I can make out of copies of one piece. Made the piece on the left, copy _ array twelve times. Exploded and regrouped. Cleaned up the internal bits with Solid Inspector. Decided to flare the top a little more, as always Vertex tools makes it easy. There you have another crazy vase.
                • HornOxxH Offline
                  HornOxx
                  @tuna1957 said:
                  ...Seem obsessed with what I can make out of copies of one piece...
                  πŸ˜† πŸ˜† be careful - there is such a high addiction factor πŸ˜† again a so nice (not fooling!) practice πŸ‘ !
                  (in the throat(?) above you end up with a triangle - I still do not really understand correctly whether triangles are no longer an obstacle in this kind of workflow, which they were at the beginning of SubD)
                  • BoxB Online
                    Next you'll start twisting them, then all is lost.
                    You'll have to start on the twelve steps and put your faith in a higher power...
                    • HornOxxH Offline
                      HornOxx
                      @box said:
                      Next you'll start twisting them...and put your faith in a higher power...
                      πŸ˜† πŸ˜† wunderbar !!
                      • tuna1957T Offline
                        tuna1957
                        Thanks Box , HornOxx.
                        HornOxx, you asked about triangles..... After I exploded the twelve pieces I erased and redrew the flat bottom inside and out so they were all quads. The pairs of triangles at the top just bellow the rim I could eliminate by " soft, smooth, no cast shadows" but I lost to much definition of the crease that way. Leaving them as triangles kept a better look to the vertical grooves. It seems you can cheat on the quads a little sometimes and still get a nice result.
                        • HornOxxH Offline
                          HornOxx
                          thanks for these Infos - yes, you are geting a better shape so πŸ‘
                          This Green-Blue look is this quadface tools live mesh analysis feature - I always forget about this good feature πŸ˜‰
                          • tuna1957T Offline
                            tuna1957
                            HornOxx, your correct the green, purple colors are from Quadface tools analyze function. I forget about it myself sometimes πŸ˜† .
                              @optimaforever said:
                              [attachment=0:gkjocs9z]<!-- ia0 -->2019-01-19_13h26_35.png<!-- ia0 -->[/attachment:gkjocs9z]
                              If you send me one of these models I can have a look into what is going on.
                              • tuna1957T Offline
                                tuna1957
                                Some more of my weird Vertex tools and SubD stuff. Twisted up the piece on the left, did some copy - array business. Add a few more bits and pieces and I ended up with a hanging lamp. SubD on the twisty bits and bottom trim ring the rest native SU.....
                                  Not by me! πŸ˜‰
                                  • BoxB Online
                                    A couple of sinks I knocked up as an example.
                                    Simple
                                    https://i.imgur.com/cVYgeHu.gif
                                    Somewhat more complex
                                    https://i.imgur.com/vgEyLkv.gif
                                      No thickness ? πŸ˜‰
                                      • HornOxxH Offline
                                        HornOxx
                                        @pilou said:
                                        No thickness ? πŸ˜‰
                                        πŸ˜„ πŸ˜„ I think thickness doesn't make sense where it's not to be seen. but did you notice that Box even models the water overflow correctly? 😲 πŸ˜„ πŸ‘
                                          Yes of course, it was for find a little default on these voluptuous design beauties! πŸ˜‰
                                          The cool thing about Subdivision modeling it's that is always a surprise before the final object! β˜€
                                          • HornOxxH Offline
                                            HornOxx
                                            Yes, each time 😎
                                            • 11
                                            • 12
                                            • 82
                                            • 83
                                            • 10 / 83
