    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 656.3k Views 155 Watching
      Rich O Brien Moderator @wharfedale1976
      @wharfedale1976
      Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
      W 2 Replies Last reply Reply Quote 0
      • W Offline
        wharfedale1976 @Rich O Brien
        @Rich-O-Brien
        Fredo6 Plugins Information on 2024-03-23 23:29:13 +0300
        • Platform: x64-mswin64_140 - Ruby: 2.7.7
        • Sketchup: 23.1.340
        • LibFredo6: v14.2a
        • LibFredo6 Binary loaded
        • Sketchucation ExtensionStore: 4.3.1
        • SCFLicense: v6.1a - 72
        • Fredo6 Plugins
          Curviloft v1.9b
          Curvizard v2.4b
          FredoPortrait v2.8a
          FredoScale v3.5a
          FredoSketch v1.3a
          FredoSpline v2.5a
          FredoTools v4.4a
          JointPushPull v4.7a
          MoveAlignMe v1.2a
          RoundCorner v3.3a
          ToolsOnSurface v2.5a
          TopoShaper v2.6a
          VisuHole v1.4b
          Signature File: 2024-01-27 16:19:01 +0300
          Curviloft: 2024-01-27 16:19:12 +0300
          Curvizard: 2024-01-27 16:20:12 +0300
          FredoScale: 2024-01-27 16:20:42 +0300
          FredoSpline: 2024-01-27 16:21:06 +0300
          ToolsOnSurface: 2024-01-27 16:21:51 +0300
          TopoShaper: 2024-01-27 16:22:07 +0300
          VisuHole: 2024-01-27 16:22:18 +0300
          "Add help menu!"
          "create new"
          (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open
        "created"
        • W Offline
          @Rich-O-Brien
          I deleted the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file located in the \SCF Licenses folder. And when I reinstalled the licenses of the two plugins that gave the license error, the problem was solved.
          Thank you
          • TIGT Online
            TIG Moderator @wharfedale1976
            @wharfedale1976
            Do you have the latest versions downloaded and installed for those Extensions, LibFredo6 and the latest SketchUcation Tools [for the licensing] ?
            Please post the errors that you got.
            If it says to delete the Signature file have you done that ??
            Have you then tried re-validating the licenses etc ?
              wharfedale1976 said in [Plugin][$] JointPushPull Interactive - v4.4e - 02 Jun 19:
              @TIG I believe he rectified the issue by deleting the signature as prompted.
              • fredo6F Offline
                NEW RELEASE: JointPushPull Interactive v4.8a - 30 Mar 24
                JointPushPull Interactive 4.8a is a major release including:
                • adjustments for future compatibility
                IMPORTANT: JointPushPull 4.8a requires LibFredo6 14.3 or above
                See plugin home page of JointPushPull for Download of JointPushPull.
                Main Post of the JointPushPull thread on this forum
                  Dandelliones
                  hellow!!! i have the same problem, i reinstalled the sketchup in my pc and i cant RELEASE SEATS of the jointpushpull too
                  TIGT D Rich O BrienR 3 Replies Last reply Reply Quote 0
                  • TIGT Online
                    TIG Moderator @Dandelliones
                    @Dandelliones
                    Have you installed the latest versions of the SketchUcation toolset [v4.4.0], LibFredo and the Fredo extension itself ?
                    These have been updated for the latest SketchUp version etc...
                    Have you restarted SketchUp afterwards ?
                    Have you then tried managing your licenses yourself with the menu item
                    Extensions/SketchUcation/SCFLicense: My Licenses at SketchUcation...
                      g.petinati @fredo6
                      @fredo6 Hi Fredo.
                      I purchased a license of Joint Push Pull Interactive and installed it, but I can't make it work.
                      I even tried to replicate the videos, but to no avail.
                      I select the faces via JPP, but when I move the mouse away from the model, to access the toolbar, all faces are unselected. Also, the icon to apply the changes never turns green...
                      Any idea of what I may be doing wrong?
                      By the way, all your plugins are awesome.
                        Dandelliones @Dandelliones
                        @Dandelliones Yes, i do... but in my licenses managing it does not let me release the seats
                        TIGT 1 Reply Last reply Reply Quote 0
                        • TIGT Online
                          @Dandelliones
                          OK I'll try to get someone else to resolve this...
                          @Rich-O-Brien
                            Rich O Brien Moderator @Dandelliones
                            @Dandelliones Device ID SQ.... which you activated on 01/04/24 must be using an old version of Sketchucation Tools. Please upgrade to newest version
                            Sketchucation Tools | SketchUcation
                            (sketchucation.com)
                            Once you update and restart SketchUp go to Tools > Fredo Collection > JPP > License and click the Seats button.
                            Then visit https://sketchucation.com/webshop/my-licences.php and the release checkbox will be available
                            H 1 Reply Last reply Reply Quote 0
                              Medness
                              This post is deleted!
                                Medness
                                  Medness
                                  Hi, I have purchased licenses of JointPushPull, Curviloft and TopoShaper. When I install these plugins, the activation of Curviloft and TopoShaper goes fine, but JointPushPull gets an error:
                                  When I check my SketchUcation v4.4.0 licenses:
                                  I don't even have it listed
                                    Rich O Brien Moderator @Medness
                                    @Medness You have multiple account and purchased JPP on another account.
                                    Login to that account and release seats
                                    M 1 Reply Last reply Reply Quote 0
                                      Medness @Rich O Brien
                                      @Rich-O-Brien said in [Plugin][$] JointPushPull Interactive - v4.8a - 30 Mar 24:
                                      I registered all plugins to the same email address. Where can I see for which account I got the JPP plugin? Can the accounts be merged?
                                      Rich O BrienR fredo6F 2 Replies Last reply Reply Quote 0
                                        @Medness Asking where to email license files is not the same as logging into a separate account and puchasing.
                                        I can purchase licenses and ask to send them any email address for convenience. But the license files have to be associated to a user account.
                                        In your instance you have multiple accounts so login to Medness1000 and you'll see JPP there
                                        Merging is not possible.
                                        • fredo6F Offline
                                          fredo6 @Medness
                                          @Medness
                                          Actually, the name part of the email address was registered in full lowercase for JointPushPull (versus first letter capitalized for TopoShaper and Curviloft).
                                          I guess the system should be case insensitive to email adress...
                                          • H Offline
                                            hoverteamph Newcomers @Rich O Brien
                                            @Rich-O-Brien 80eb2409-c9b4-4185-b624-937287b0b518-image.png I have also same issue but the problem is the seats that doesnt have check box for releasing are PC is already been dispose. Is there a way where we can force to release this seats? There's a lot on my licensing that are like this please help. Thank you .
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 30 / 31
