    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 656.4k Views 155 Watching
      rv1974
      1.copy surface to buffer
      2.execute JPP
      3. paste in place
      4. delete
      • fredo6F Offline
        I don't understand. The grouping in Group PushPull 2D Faces is individual by face, which is not supported by JPP.
        So this is two different features.
        • designerbursaD Offline
          designerbursa
          It would have been nice if there was an option of giving the thickness similar to the Autocad Exturude command! .. Yes, it is a waste of time but we can easily remove the remaining surfaces. πŸ˜„ Achievements in your studies Fredo6
          "Group PushPull 2DFaces" will not need this plugin! .. thanks Fredo6
            designerbursa
            I am sorry for my English πŸ˜„
              reza1813
              Dear Fredo,
              Hello, I kindly reach you to mention a problem in the Joint Push Pull plugin.
              When I model organic shape or complex surface(Almost curve form or tensile structure) Pushing of the surface is not moving well and also I have tried to copy of surface and then use Curviloft to close it but it also doesn't work properly. What should I do exactly in this Situation? Thanks in advance.
              Joint Push Pull
              Sincerely
              Hamidreza
              • fredo6F Offline
                Could you post the model with the Tensile surface, so that I can try to investigate the problem with JPP.
                Also, can you use the Extrude tool in JPP (X marked) instead.
                  reza1813
                  Dear Fredo,
                  Thanks a lot. It works when I use the Extrude tool in JPP (X marked). Thanks in advance.
                  • CadFatherC Offline
                    CadFather
                    Hi Fredo, i noticed that JPP will treat group copies as instances - i think it would be great to bypass this and have it treat groups as separate. perhaps something for the next update cycle...
                    • fredo6F Offline
                      Definitely. This happens for freshly copied groups, that behave as components until you edit them. I need to correct this as I did in FredoCorner. Just some work!
                        CadFather
                        fantastic! : )
                          Leon aa
                          Hi, first of all I really like this plugin and I have been using it for some time now. Somehow the face selection via surface stopped working for me. The plugin only selects by face if I set it to surface.
                          • fredo6F Offline
                            Weird... May be you could
                            • open the Ruby console before launching JPP to check if there are errors
                            • post your model, or show a short video of the problem
                              Leon aa
                              I opened the Ruby console and then started the plugin, but there was no text in the console, so I think there's no problem there.
                              I don't think that there's a problem with my model. I tried it on different models and it wasn't working either.
                              Maybe there is a problem with LibFredo? I updated it last week and I haven't noticed any problem before. I tried reinstalling LibFredo and JPP, but it didn't fix anything.
                              Here is how it looks in SketchUp, no error message, just not working as intended:
                              https://lh3.googleusercontent.com/NYDBJXLT7sezAN-zo_IWJP4Acbj1OvDfYPJvVighSo7VZrWpVmUxxoeWVA990Dxz8BI-6V330jSpyn6ypOa98Ujt99LBn8Y9rk_L97MnKP60EQEeJEheowtRaqAukt8UFB6SAZ4xxJS8NBj_zAQZCcyT3Xo7gL9wa5FCGfd7Xc84DC6Bf6U0Si2rEBsl2QuwGAo_64YTmEvYjTE_q5QEMuRUrPFCPfJQH0u6vpgR9VuXjKDGKhZ7p2RELTMbT5pDB6EWPkdTs9TjZojeYQLyOLNlzNQiQv_T8a5Ije2KSUVas20TLmR0ONbOddARvr0GTu4ahaEkzqQW0vJzds3Jj6TwHpEwtmK77mWOJ1LtSEgi6-PVkWKGE7vDJ_vb2b3F7ig6o3WSAYYK994rumkb_sYyUnmQuP27MJ7osJiqfe2F-bM86idQ_EyYoPdMkYAORvNl1MIuART3NueFMFl8Th8HPh8Ks7vFv-mDh1XCF2PkEe5Um1DEXA8EtPCEN92ptFvv74acnZydPcK3shIGSN-KXZ1YEnn-TvzS7ubzbvPzx0D7hTaOwY3hzvtBa4-tnqUK3w2JQtxkWuEqRVnPGGTs80kpCDuImAy1gxJ_cgvl7V5HFq0v7PMVOTiDTWap9cKHspvmr4W7VsYxJ_4QOmaJZ_12LCjx68g8dAodSWiApzAsCQhOnn58Va5Guy2jNZZHSttnLAKJlAvXn2QYkjC_=w1563-h839-no
                              • fredo6F Offline
                                In Sketchup, surface is defined by a set of faces whose common edges are soft (so not smooth).
                                Can you check in your model.
                                Also, what happens when you turn off "Hidden Geometry" ?
                                • E Offline
                                  Einstein
                                  Round Push Pull with minimum number of rounding segments = 1, that would be nice πŸ˜„ (Now it's 2)
                                    rv1974
                                    Fredo, would it be possible to add 'afterward selection department' to JPP?
                                    Say 3 check boxes that rule which category will stay selected: initial faces, offset faces, or connecting faces.
                                    • fredo6F Offline
                                      I am not sure I understand. The selection scope option is kept across JPP sessions and even Sketchup sessions.
                                        rv1974
                                        Say you have state 0, then run JPP and immediately after execution (on exit) you'd have (wishful thinking) 3 states.
                                        The goal is ability to group selection and assign diffrent material or make some geniuos manipulations (independently).
                                        • fredo6F Offline
                                          OK. I get what you want to get.
                                          Doable indeed, but this is another option in a GUI which some consider already 'bloated'!!
                                          Currently, JPP keeps the selection on the faces which have been selected.
                                            rv1974
                                            @fredo6 said:
                                            ...Currently, JPP keeps the selection on the faces which have been selected.
                                            OK. Could you please change this setting it to the offsetones? It would solve all my request without UI bloating. You see, I can Cnrl+C initial faces before JPP execution, and then just paste original faces after JPP is done. This simple hack restores original selection.
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 27 / 31
