    βŒ› Sale Ending | 30% Off Profile Builder 4 ends 30th September
    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 969.9k Views 79 Watching
    • HornOxxH Offline
      HornOxx
      thank you guys πŸ˜„ and finally learned this vocabulary
      never trust a skinny cook
      • BoxB Offline
        Here's one I posted way back.
        If you had been following my FB Page you would have it sorted by now. πŸ˜„
        https://media.giphy.com/media/3o6Zt2b3OThZOpG4py/giphy.gif
        • cottyC Offline
          cotty
          applied to a sphere...
          my SketchUp gallery
          • HornOxxH Offline
            HornOxx
            wow Cotty !!!!!! - and I bet that "corncob hand grenade ball" you have sketched and so good rendered right now from the scratch - Thanks for this really really good example πŸ˜„
            • BoxB Offline
              What can I say, I like hooks.
              • cottyC Offline
                cotty
                And the hooks are just hooked up? πŸ˜‰
                my SketchUp gallery
                • BoxB Offline
                  There is actually a pin sticking out at the bottom that would slip into a drilled hole in the board, so yes, in a sense they are just hooked into place but won't swing from side to side.
                  • BoxB Offline
                    Here's a couple of tables using an array of a single SUbD components.
                    I suspect the first table should only be used to serve Jelly, or Jello as you yanks call it.
                    The second would be far more stable.
                    I think I will have to build them just to see how well they work in the real world.
                    The first one as a proxy, the second can be created by flipping four components.
                      Reminds me of this guy from the Snorks cartoon...
                      https://ih0.redbubble.net/image.258227615.7489/flat,800x800,075,f.u1.jpg
                      • BoxB Offline
                        You've spent too much time with the twins Rich.
                        • BoxB Offline
                          A bit of SUbD Bling.
                          from this
                          we get this.
                          • pbacotP Offline
                            Wow! would like to see detail on the necklace before and after and the links detail!
                            • BoxB Offline
                              I'm in the Doc's waiting room at the moment. I'll knock something up when I get back home.
                              • HornOxxH Offline
                                HornOxx
                                πŸ‘ πŸ˜„ so cool again Box - how did you get the individual limbs so well strung up next to each other?
                                • BoxB Offline
                                  That's what I meant with my last line about using your choice of Stringer. There are a few to choose from, from memory
                                  Component Stringer by Chris Fulmer
                                  Comp String by Sam D Mitch
                                  Path Copy by Smustard
                                  or in this case Copy Along Curve by Anton S.
                                  I rendered another after laying the links down flat to the body.
                                  • BoxB Offline
                                    Here you go, Unfortunately I can't fully unSUbD it but you get the idea. Each link starts as just a square doughnut that has been twisted with vertex tools.
                                    Why describe when you can do.
                                    Like this,
                                    then distribute with your choice of stringer.
                                    • BoxB Offline
                                      SUbD is very helpful when basket weaving. A bit of clothworks thrown in for good measure.
                                        I could use one of those chairs right now... πŸ˜„
                                        • HornOxxH Offline
                                          HornOxx
                                          πŸ˜„ end of may and already 32Β°C - IΒ΄ll take such a chair also πŸ˜„ Really excellent Box!
                                          • BoxB Offline
                                            Something a little different. I'd call it Modern Retro with a nod to Spiderman.
                                            It's got that late sixties early seventies molded plastic feel but perhaps made with updated materials and processes.
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 82
                                            • 83
                                            • 65 / 83
