    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
    • BoxB
      So all the plugins are?
      I have to be sure you know.
      • cottyC
        cotty
        QFT, VertexTools, JPP and TIG.splitdonut?
        my SketchUp gallery
        • BoxB
          Excellent, now can you show me how?
          • BoxB
            Only joking, I've hijacked the thread enough already.
            Problem is I posted the same question on my FB page so I'll be giving it away here. I've got my eye on you facebook lurkers.
            • HornOxxH
              HornOxx
              πŸ‘ πŸ‘ I want to subscribe to your BOX Gif Channel !!!! πŸ˜„ πŸ˜„
              Box, when you pull out all these selected squares with joint-push-pull, how do you succeed. that they taper like pyramids during this process at the same time?
              never trust a skinny cook
              • BoxB
                @hornoxx said:
                Box, they taper like pyramids during this process at the same time?
                On the toolbar that appears when you use JPP you have an option for taper.
                As to the other go to facebook.com/boxgifs and enjoy.
                • cottyC
                  cotty
                  And if you don't see these options, you have to search for the "more options..." button.
                  my SketchUp gallery
                  • HornOxxH
                    HornOxx
                    thank you guys πŸ˜„ and finally learned this vocabulary
                    • BoxB
                      Here's one I posted way back.
                      If you had been following my FB Page you would have it sorted by now. πŸ˜„
                      https://media.giphy.com/media/3o6Zt2b3OThZOpG4py/giphy.gif
                      • cottyC
                        cotty
                        applied to a sphere...
                        my SketchUp gallery
                        • HornOxxH
                          HornOxx
                          wow Cotty !!!!!! - and I bet that "corncob hand grenade ball" you have sketched and so good rendered right now from the scratch - Thanks for this really really good example πŸ˜„
                          • BoxB
                            What can I say, I like hooks.
                            • cottyC
                              cotty
                              And the hooks are just hooked up? πŸ˜‰
                              my SketchUp gallery
                              • BoxB
                                There is actually a pin sticking out at the bottom that would slip into a drilled hole in the board, so yes, in a sense they are just hooked into place but won't swing from side to side.
                                • BoxB
                                  Here's a couple of tables using an array of a single SUbD components.
                                  I suspect the first table should only be used to serve Jelly, or Jello as you yanks call it.
                                  The second would be far more stable.
                                  I think I will have to build them just to see how well they work in the real world.
                                  The first one as a proxy, the second can be created by flipping four components.
                                    Reminds me of this guy from the Snorks cartoon...
                                    https://ih0.redbubble.net/image.258227615.7489/flat,800x800,075,f.u1.jpg
                                    • BoxB
                                      You've spent too much time with the twins Rich.
                                      • BoxB
                                        A bit of SUbD Bling.
                                        from this
                                        we get this.
                                        • pbacotP
                                          Wow! would like to see detail on the necklace before and after and the links detail!
                                          • BoxB
                                            I'm in the Doc's waiting room at the moment. I'll knock something up when I get back home.
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 83
                                            • 84
                                            • 58 / 84
