    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.3m Views 79 Watching
    • HornOxxH
      HornOxx
      wow Cotty !!!!!! - and I bet that "corncob hand grenade ball" you have sketched and so good rendered right now from the scratch - Thanks for this really really good example πŸ˜„
      never trust a skinny cook
      • BoxB
        What can I say, I like hooks.
        • cottyC
          cotty
          And the hooks are just hooked up? πŸ˜‰
          my SketchUp gallery
          • BoxB
            There is actually a pin sticking out at the bottom that would slip into a drilled hole in the board, so yes, in a sense they are just hooked into place but won't swing from side to side.
            • BoxB
              Here's a couple of tables using an array of a single SUbD components.
              I suspect the first table should only be used to serve Jelly, or Jello as you yanks call it.
              The second would be far more stable.
              I think I will have to build them just to see how well they work in the real world.
              The first one as a proxy, the second can be created by flipping four components.
                Reminds me of this guy from the Snorks cartoon...
                https://ih0.redbubble.net/image.258227615.7489/flat,800x800,075,f.u1.jpg
                • BoxB
                  You've spent too much time with the twins Rich.
                  • BoxB
                    A bit of SUbD Bling.
                    from this
                    we get this.
                    • pbacotP
                      Wow! would like to see detail on the necklace before and after and the links detail!
                      • BoxB
                        I'm in the Doc's waiting room at the moment. I'll knock something up when I get back home.
                        • HornOxxH
                          HornOxx
                          πŸ‘ πŸ˜„ so cool again Box - how did you get the individual limbs so well strung up next to each other?
                          • BoxB
                            That's what I meant with my last line about using your choice of Stringer. There are a few to choose from, from memory
                            Component Stringer by Chris Fulmer
                            Comp String by Sam D Mitch
                            Path Copy by Smustard
                            or in this case Copy Along Curve by Anton S.
                            I rendered another after laying the links down flat to the body.
                            • BoxB
                              Here you go, Unfortunately I can't fully unSUbD it but you get the idea. Each link starts as just a square doughnut that has been twisted with vertex tools.
                              Why describe when you can do.
                              Like this,
                              then distribute with your choice of stringer.
                              • BoxB
                                SUbD is very helpful when basket weaving. A bit of clothworks thrown in for good measure.
                                  I could use one of those chairs right now... πŸ˜„
                                  • HornOxxH
                                    HornOxx
                                    πŸ˜„ end of may and already 32Β°C - IΒ΄ll take such a chair also πŸ˜„ Really excellent Box!
                                    • BoxB
                                      Something a little different. I'd call it Modern Retro with a nod to Spiderman.
                                      It's got that late sixties early seventies molded plastic feel but perhaps made with updated materials and processes.
                                      • cottyC
                                        cotty
                                        Very nice!
                                        my SketchUp gallery
                                        • BoxB
                                          Here's a little silliness for those that wonder about making parts fit together or that everything has to be a soft curve.
                                          The lid fits accurately although it is a separate component and the rubber/plastic seal around the electric cord has defined edges while still being part of the main component.
                                          It is made up of only two parts, the main body including the power cord and the lid.
                                          Although I must admit I haven't created the hinge section, nor have I done the plug as there are so many variations of them around the world. Not many here would be looking for an Australian plug.
                                          I'll add the proxy if anyone wants to do the hinge and their own plug.
                                          KettleProxy.skp
                                          • boofredlayB
                                            boofredlay
                                            Great!
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 83
                                            • 84
                                            • 59 / 84
