    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.1m Views 79 Watching
    • BoxB
      A bit of SUbD Bling.
      from this
      we get this.
      • pbacotP
        Wow! would like to see detail on the necklace before and after and the links detail!
        • BoxB
          I'm in the Doc's waiting room at the moment. I'll knock something up when I get back home.
          • HornOxxH
            HornOxx
            ๐Ÿ‘ ๐Ÿ˜„ so cool again Box - how did you get the individual limbs so well strung up next to each other?
            never trust a skinny cook
            • BoxB
              That's what I meant with my last line about using your choice of Stringer. There are a few to choose from, from memory
              Component Stringer by Chris Fulmer
              Comp String by Sam D Mitch
              Path Copy by Smustard
              or in this case Copy Along Curve by Anton S.
              I rendered another after laying the links down flat to the body.
              • BoxB
                Here you go, Unfortunately I can't fully unSUbD it but you get the idea. Each link starts as just a square doughnut that has been twisted with vertex tools.
                Why describe when you can do.
                Like this,
                then distribute with your choice of stringer.
                • BoxB
                  SUbD is very helpful when basket weaving. A bit of clothworks thrown in for good measure.
                    I could use one of those chairs right now... ๐Ÿ˜„
                    • HornOxxH
                      HornOxx
                      ๐Ÿ˜„ end of may and already 32ยฐC - Iยดll take such a chair also ๐Ÿ˜„ Really excellent Box!
                      • BoxB
                        Something a little different. I'd call it Modern Retro with a nod to Spiderman.
                        It's got that late sixties early seventies molded plastic feel but perhaps made with updated materials and processes.
                        • cottyC
                          cotty
                          Very nice!
                          my SketchUp gallery
                          • BoxB
                            Here's a little silliness for those that wonder about making parts fit together or that everything has to be a soft curve.
                            The lid fits accurately although it is a separate component and the rubber/plastic seal around the electric cord has defined edges while still being part of the main component.
                            It is made up of only two parts, the main body including the power cord and the lid.
                            Although I must admit I haven't created the hinge section, nor have I done the plug as there are so many variations of them around the world. Not many here would be looking for an Australian plug.
                            I'll add the proxy if anyone wants to do the hinge and their own plug.
                            KettleProxy.skp
                            • boofredlayB
                              boofredlay
                              Great!
                              • BoxB
                                Thanks Cotty, Boo ๐Ÿ‘
                                Something to keep in mind, SUbD isn't just about organic modelling.
                                It's about low poly to high poly. But it can be easily used on medium poly to smooth everything nicely before rendering.
                                Here you see how something that is fairly blocky, but not low poly can be smoothed out with a quick bit of SUbD. Sometimes you want to render a whole model that is well constructed but not so overdone with segments that you get bogged down, but you'd like to do some close up of parts that may not be as smooth as you would want. Rather than having to redraw them with more segments just for the closeup, if well constructed to begin with, a quick subd to smooth is all you need.
                                Model
                                Before SUbD
                                After SUbD
                                  Enlighting! ๐Ÿ˜Ž
                                  • FrederikF
                                    Frederik
                                    ๐Ÿ‘ Good point...
                                    I know that a lot of other 3D modelling applications are utilizing this in a much wider extend...
                                    3dMax have the Turbo Smooth option...
                                    If users import such model into i.e. SU, they look really edgy...
                                    Cheers
                                    Kim Frederik
                                    • BoxB
                                      Yeah, might be able to fix some models, but I can imagine there might be problems with triangulation and SUbD.
                                      But throw in a few blades and some hex screws...
                                      • utilerU
                                        utiler
                                        That's extraordinary, Box!! ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ
                                        Just Curious...
                                        • BoxB
                                          Thanks Andrew but it's not that extraordinary really, just the magic of render software with a very simple model.
                                          • utilerU
                                            utiler
                                            smarty pants.... ๐Ÿ‘
                                            that fan looks a little more work though..?
                                            Just Curious...
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 83
                                            • 84
                                            • 59 / 84
