    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.3m Views 79 Watching
    • HornOxxH
      HornOxx
      πŸ‘ πŸ‘ I want to subscribe to your BOX Gif Channel !!!! πŸ˜„ πŸ˜„
      Box, when you pull out all these selected squares with joint-push-pull, how do you succeed. that they taper like pyramids during this process at the same time?
      never trust a skinny cook
      • BoxB
        @hornoxx said:
        Box, they taper like pyramids during this process at the same time?
        On the toolbar that appears when you use JPP you have an option for taper.
        As to the other go to facebook.com/boxgifs and enjoy.
        • cottyC
          cotty
          And if you don't see these options, you have to search for the "more options..." button.
          my SketchUp gallery
          • HornOxxH
            HornOxx
            thank you guys πŸ˜„ and finally learned this vocabulary
            • BoxB
              Here's one I posted way back.
              If you had been following my FB Page you would have it sorted by now. πŸ˜„
              https://media.giphy.com/media/3o6Zt2b3OThZOpG4py/giphy.gif
              • cottyC
                cotty
                applied to a sphere...
                my SketchUp gallery
                • HornOxxH
                  HornOxx
                  wow Cotty !!!!!! - and I bet that "corncob hand grenade ball" you have sketched and so good rendered right now from the scratch - Thanks for this really really good example πŸ˜„
                  • BoxB
                    What can I say, I like hooks.
                    • cottyC
                      cotty
                      And the hooks are just hooked up? πŸ˜‰
                      my SketchUp gallery
                      • BoxB
                        There is actually a pin sticking out at the bottom that would slip into a drilled hole in the board, so yes, in a sense they are just hooked into place but won't swing from side to side.
                        • BoxB
                          Here's a couple of tables using an array of a single SUbD components.
                          I suspect the first table should only be used to serve Jelly, or Jello as you yanks call it.
                          The second would be far more stable.
                          I think I will have to build them just to see how well they work in the real world.
                          The first one as a proxy, the second can be created by flipping four components.
                            Reminds me of this guy from the Snorks cartoon...
                            https://ih0.redbubble.net/image.258227615.7489/flat,800x800,075,f.u1.jpg
                            • BoxB
                              You've spent too much time with the twins Rich.
                              • BoxB
                                A bit of SUbD Bling.
                                from this
                                we get this.
                                • pbacotP
                                  Wow! would like to see detail on the necklace before and after and the links detail!
                                  • BoxB
                                    I'm in the Doc's waiting room at the moment. I'll knock something up when I get back home.
                                    • HornOxxH
                                      HornOxx
                                      πŸ‘ πŸ˜„ so cool again Box - how did you get the individual limbs so well strung up next to each other?
                                      • BoxB
                                        That's what I meant with my last line about using your choice of Stringer. There are a few to choose from, from memory
                                        Component Stringer by Chris Fulmer
                                        Comp String by Sam D Mitch
                                        Path Copy by Smustard
                                        or in this case Copy Along Curve by Anton S.
                                        I rendered another after laying the links down flat to the body.
                                        • BoxB
                                          Here you go, Unfortunately I can't fully unSUbD it but you get the idea. Each link starts as just a square doughnut that has been twisted with vertex tools.
                                          Why describe when you can do.
                                          Like this,
                                          then distribute with your choice of stringer.
                                          • BoxB
                                            SUbD is very helpful when basket weaving. A bit of clothworks thrown in for good measure.
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 83
                                            • 84
                                            • 58 / 84
