    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 911.4k Views 166 Watching
      Anton_S
      @smashor said:
      How can I make this kind of curtain?
      Flat curtains are usually really damp and neglect changing their form.
      You can control the shape by creating pins and moving some forward and some backward.
      The properties should be:
      • Shear Stiffness: 1.0
      • Bend Stifnness: 0.01
      • Damping: 1.0
      • Self-collision: ON
      When you finish simulating, you can set bending to 0.00, so the cloth rests completely.
      After simulation, you can apply loop subdivision and Laplacian smootheninth to better the result, as shown on the green curtain in the image below.
      Curtains5.skp
        Anton_S
        @valerostudio said:
        Is there a way to have pressure (or have a future feature) where you can have a pillow and drop it on to a sofa or bed? I have played with this in Max a little bit.
        Nice video! Soft bodies are planned for V2.
        • HieruH
          Hieru
          Although we'll have to wait for future releases to do this properly, it's still possible with the current version.
          I just need to pull out my finger and find a screen capture method for recording my workflow.
          www.davidhier.co.uk
          • OxerO
            Oxer
            My first test with the plugin, it has a lot of possibilities.
            • HornOxxH
              HornOxx
              Hieru and Oxer - your examples just above are so great !! ๐Ÿ‘ ๐Ÿ‘
              how do you manage to generate these voluminous cloth shapes - whether as a pillow or a sack full of potatoes? what I mean is, which kind of cloth surface collides here onto or around which collider to get such a complex kind of result?
              never trust a skinny cook
              • OxerO
                Oxer
                A picture is worth more than 1000 words.
                • OxerO
                  Oxer
                  New test, ClothWorks+MSPhysics, I modeled the potatoes and they placed with MSPhysics.
                  • pabloariasP
                    pabloarias
                    Hi Anton.
                    Bought and testing. Simply AWESOME. It's just what I needed. Anton, you're amazing.
                    Pablo Arias
                    SketchUp trainer
                    V-Ray licensed trainer
                    • jo-keJ
                      jo-ke
                      still trying to make pillows.
                      but I'm not getting on...
                      Any ideas or tutorials?
                      @ Oxer: how did you fix the frame?
                      draping simple grids works fine. I've made a model of my curtain samples
                      http://www.zz7.de
                      • PixeroP
                        Pixero
                        @oxer said:
                        The frame is a pin, select de frame > right click > Make Pin
                        That's a great tip. ๐Ÿ‘
                        • HornOxxH
                          HornOxx
                          โ“ ๐Ÿ˜ฎ โ“ please help me out of my hole - I try and try but don't get any idea what to do in which way to achieve such kind of shapes ๐Ÿ˜ณ
                          • OxerO
                            Oxer
                            The frame is a pin, select the frame > right click > Make Pin
                            • Bob JamesB
                              Bob James
                              oxer
                              Thank you for the pictures. Please forgive my dullness, but could you explain how to use each of the pictures? ๐Ÿ˜ณ
                              • HieruH
                                Hieru
                                That's very smart...it will probably remove a step when I record my pillow workflow ๐Ÿ‘ .
                                www.davidhier.co.uk
                                • OxerO
                                  Oxer
                                    Jorgensen
                                    impressive work oxer!
                                    • Bob JamesB
                                      Bob James
                                      Thank you, oxer
                                      • OxerO
                                        Oxer
                                        You're welcome!
                                        • FrederikF
                                          Frederik
                                          Learning something new everyday... ๐Ÿ˜„
                                          However, why can't I get this right...?
                                          Canvas-bag.skp
                                          Cheers
                                          Kim Frederik
                                          • OxerO
                                            Oxer
                                            Care Frederik!! "The curiosity killed the cat" ๐Ÿ˜† ๐Ÿ˜†
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 35
                                            • 36
                                            • 12 / 36
