    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 911.4k Views 166 Watching
    • HornOxxH
      HornOxx
      โ“ ๐Ÿ˜ฎ โ“ please help me out of my hole - I try and try but don't get any idea what to do in which way to achieve such kind of shapes ๐Ÿ˜ณ
      never trust a skinny cook
      • OxerO
        Oxer
        The frame is a pin, select the frame > right click > Make Pin
        • Bob JamesB
          Bob James
          oxer
          Thank you for the pictures. Please forgive my dullness, but could you explain how to use each of the pictures? ๐Ÿ˜ณ
          • HieruH
            Hieru
            That's very smart...it will probably remove a step when I record my pillow workflow ๐Ÿ‘ .
            www.davidhier.co.uk
            • OxerO
              Oxer
                Jorgensen
                impressive work oxer!
                • Bob JamesB
                  Bob James
                  Thank you, oxer
                  • OxerO
                    Oxer
                    You're welcome!
                    • FrederikF
                      Frederik
                      Learning something new everyday... ๐Ÿ˜„
                      However, why can't I get this right...?
                      Canvas-bag.skp
                      Cheers
                      Kim Frederik
                      • OxerO
                        Oxer
                        Care Frederik!! "The curiosity killed the cat" ๐Ÿ˜† ๐Ÿ˜†
                        • OxerO
                          Oxer
                          The possibilities are endless, you can use ClothWorks to create a lot of different organic objects, more examples at the end of the day or tomorrow.
                          • HornOxxH
                            HornOxx
                            thank you Oxer for your second sketch ๐Ÿ‘
                            I continue to fail at the simplest things ๐Ÿ˜ณ How do I make cloth and Pin sticking together?
                            test 01.skp
                            • FrederikF
                              Frederik
                              But seriously...
                              When I converge the cloth+frame with the balls (collider), the cloth doesn't bend as I would expect... ๐Ÿ˜ž
                              I press the ClothWorks play button, click the frame (pin) and drag the red arrow towards the balls, but the cloth just remain stiff and doesn't fold around the balls...
                              I don't get the result HornOxx is showing in his animation... ๐Ÿ’š
                              I assume that's caused by the cloth isn't "inside" the frame...?!?
                              Cheers
                              Kim Frederik
                              • OxerO
                                Oxer
                                HornOxx & Frederik, the trick is to create the frame with 3 elements because if the frame is an unique object ClothWorks creates a box for the pin and this makes that the cloth does not move. See the image.
                                REMEMBER: The cloth should enter a little in the frame.
                                • FrederikF
                                  Frederik
                                  But like I wrote...
                                  I don't have the issue HornOxx is experiencing...
                                  The frame and the cloth moves correct when I click the play button, click the frame and move the frame and cloth by dragging the red arrow that emerge, when I click the frame...
                                  Cheers
                                  Kim Frederik
                                  • OxerO
                                    Oxer
                                    REMEMBER: Create the frame with 3 slats to do the cloth moves. See the image of my previous entry.
                                    • FrederikF
                                      Frederik
                                      Ok... I've made the frame with 3 slats...
                                      At first I couldn't make it work - because I had grouped them...
                                      One IMPORTANT info is missing...
                                      You need to move the frame-pins one by one...
                                      It can't be done by moving all three in one go... ๐Ÿค“
                                      Cheers
                                      Kim Frederik
                                      • OxerO
                                        Oxer
                                        Select the 6 slats and converge with shift or ctrl key while you move them, that is the trick
                                        • FrederikF
                                          Frederik
                                          Got it... ๐Ÿ‘
                                          Hold down the shift-key when clicking the pins and then converge...! ๐Ÿ˜„
                                          This gives me a ton of new options and ideas... ๐Ÿ˜„
                                          Thanks, Oxer...! ๐Ÿ‘
                                          Cheers
                                          Kim Frederik
                                          • PixeroP
                                            Pixero
                                            For a non native english speaker. Could you explain what converge is?
                                            Googling it didnt help. ๐Ÿ˜•
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 35
                                            • 36
                                            • 12 / 36
