    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.4k Views 171 Watching
    • HornOxxH
      HornOxx
      @valerostudio said:
      ...Having a great time playing with it and V-Ray Fur...
      ๐Ÿ‘ ๐Ÿ‘ looks really fantastic - is this fur here is a V-Ray internal feature?
      @box said:
      A little inspiration for all the scifi modelers out there...
      ๐Ÿ‘ ๐Ÿ‘ not only for the scifis out there ๐Ÿ˜„ again magic - a great elastic simulation ๐Ÿ‘
      never trust a skinny cook
      • V
        valerostudio
        Yes, what you are seeing is V-Ray Fur.
        • V
          valerostudio
          Is there a way to have pressure (or have a future feature) where you can have a pillow and drop it on to a sofa or bed? I have played with this in Max a little bit.
            smashor
            How can I make this kind of curtain?
            https://www.ikea.com/gb/en/images/rooms/ikea-clean-green-and-clutter-free-__1364315962817-s4.jpg
              Anton_S
              Flat curtains are usually really damp and neglect changing their form.
              You can control the shape by creating pins and moving some forward and some backward.
              The properties should be:
              • Shear Stiffness: 1.0
              • Bend Stifnness: 0.01
              • Damping: 1.0
              • Self-collision: ON
              When you finish simulating, you can set bending to 0.00, so the cloth rests completely.
              After simulation, you can apply loop subdivision and Laplacian smootheninth to better the result, as shown on the green curtain in the image below.
              Curtains5.skp
                Anton_S
                Nice video! Soft bodies are planned for V2.
                • HieruH
                  Hieru
                  Although we'll have to wait for future releases to do this properly, it's still possible with the current version.
                  I just need to pull out my finger and find a screen capture method for recording my workflow.
                  www.davidhier.co.uk
                  • OxerO
                    Oxer
                    My first test with the plugin, it has a lot of possibilities.
                    • HornOxxH
                      HornOxx
                      Hieru and Oxer - your examples just above are so great !! ๐Ÿ‘ ๐Ÿ‘
                      how do you manage to generate these voluminous cloth shapes - whether as a pillow or a sack full of potatoes? what I mean is, which kind of cloth surface collides here onto or around which collider to get such a complex kind of result?
                      • OxerO
                        Oxer
                        A picture is worth more than 1000 words.
                        • OxerO
                          Oxer
                          New test, ClothWorks+MSPhysics, I modeled the potatoes and they placed with MSPhysics.
                          • pabloariasP
                            pabloarias
                            Hi Anton.
                            Bought and testing. Simply AWESOME. It's just what I needed. Anton, you're amazing.
                            Pablo Arias
                            SketchUp trainer
                            V-Ray licensed trainer
                            • jo-keJ
                              jo-ke
                              still trying to make pillows.
                              but I'm not getting on...
                              Any ideas or tutorials?
                              @ Oxer: how did you fix the frame?
                              draping simple grids works fine. I've made a model of my curtain samples
                              http://www.zz7.de
                              • PixeroP
                                Pixero
                                @oxer said:
                                The frame is a pin, select de frame > right click > Make Pin
                                That's a great tip. ๐Ÿ‘
                                • HornOxxH
                                  HornOxx
                                  โ“ ๐Ÿ˜ฎ โ“ please help me out of my hole - I try and try but don't get any idea what to do in which way to achieve such kind of shapes ๐Ÿ˜ณ
                                  • OxerO
                                    Oxer
                                    The frame is a pin, select the frame > right click > Make Pin
                                    • Bob JamesB
                                      Bob James
                                      oxer
                                      Thank you for the pictures. Please forgive my dullness, but could you explain how to use each of the pictures? ๐Ÿ˜ณ
                                      • HieruH
                                        Hieru
                                        That's very smart...it will probably remove a step when I record my pillow workflow ๐Ÿ‘ .
                                        www.davidhier.co.uk
                                        • OxerO
                                          Oxer
                                            Jorgensen
                                            impressive work oxer!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 36
                                            • 37
                                            • 12 / 37
