    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 883.4k Views 166 Watching
    • OxerO
      Oxer
      A picture is worth more than 1000 words.
      • OxerO
        Oxer
        New test, ClothWorks+MSPhysics, I modeled the potatoes and they placed with MSPhysics.
        • pabloariasP
          pabloarias
          Hi Anton.
          Bought and testing. Simply AWESOME. It's just what I needed. Anton, you're amazing.
          Pablo Arias
          SketchUp trainer
          V-Ray licensed trainer
          • jo-keJ
            jo-ke
            still trying to make pillows.
            but I'm not getting on...
            Any ideas or tutorials?
            @ Oxer: how did you fix the frame?
            draping simple grids works fine. I've made a model of my curtain samples
            http://www.zz7.de
            • PixeroP
              Pixero
              @oxer said:
              The frame is a pin, select de frame > right click > Make Pin
              That's a great tip. ๐Ÿ‘
              • HornOxxH
                HornOxx
                โ“ ๐Ÿ˜ฎ โ“ please help me out of my hole - I try and try but don't get any idea what to do in which way to achieve such kind of shapes ๐Ÿ˜ณ
                never trust a skinny cook
                • OxerO
                  Oxer
                  The frame is a pin, select the frame > right click > Make Pin
                  • Bob JamesB
                    Bob James
                    oxer
                    Thank you for the pictures. Please forgive my dullness, but could you explain how to use each of the pictures? ๐Ÿ˜ณ
                    • HieruH
                      Hieru
                      That's very smart...it will probably remove a step when I record my pillow workflow ๐Ÿ‘ .
                      www.davidhier.co.uk
                      • OxerO
                        Oxer
                          Jorgensen
                          impressive work oxer!
                          • Bob JamesB
                            Bob James
                            Thank you, oxer
                            • OxerO
                              Oxer
                              You're welcome!
                              • FrederikF
                                Frederik
                                Learning something new everyday... ๐Ÿ˜„
                                However, why can't I get this right...?
                                Canvas-bag.skp
                                Cheers
                                Kim Frederik
                                • OxerO
                                  Oxer
                                  Care Frederik!! "The curiosity killed the cat" ๐Ÿ˜† ๐Ÿ˜†
                                  • OxerO
                                    Oxer
                                    The possibilities are endless, you can use ClothWorks to create a lot of different organic objects, more examples at the end of the day or tomorrow.
                                    • HornOxxH
                                      HornOxx
                                      thank you Oxer for your second sketch ๐Ÿ‘
                                      I continue to fail at the simplest things ๐Ÿ˜ณ How do I make cloth and Pin sticking together?
                                      test 01.skp
                                      • FrederikF
                                        Frederik
                                        But seriously...
                                        When I converge the cloth+frame with the balls (collider), the cloth doesn't bend as I would expect... ๐Ÿ˜ž
                                        I press the ClothWorks play button, click the frame (pin) and drag the red arrow towards the balls, but the cloth just remain stiff and doesn't fold around the balls...
                                        I don't get the result HornOxx is showing in his animation... ๐Ÿ’š
                                        I assume that's caused by the cloth isn't "inside" the frame...?!?
                                        Cheers
                                        Kim Frederik
                                        • OxerO
                                          Oxer
                                          HornOxx & Frederik, the trick is to create the frame with 3 elements because if the frame is an unique object ClothWorks creates a box for the pin and this makes that the cloth does not move. See the image.
                                          REMEMBER: The cloth should enter a little in the frame.
                                          • FrederikF
                                            Frederik
                                            But like I wrote...
                                            I don't have the issue HornOxx is experiencing...
                                            The frame and the cloth moves correct when I click the play button, click the frame and move the frame and cloth by dragging the red arrow that emerge, when I click the frame...
                                            Cheers
                                            Kim Frederik
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 35
                                            • 36
                                            • 12 / 36
