    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    707 Posts 163 Posters 752.2k Views 163 Watching
    • BoxB Offline
      I know I'm doing things it's not really designed for but I like the simplicity of clothworks.
      • majidM Offline
        majid
        Seems stunning and I have an eye on it, does it also have "preventing self collision" option?
        • FrederikF Offline
          Frederik
          @majid said:
          ...does it also have "preventing self collision" option?
          Of course... ๐Ÿ˜„
          Cheers
          Kim Frederik
          • HornOxxH Offline
            HornOxx
            @valerostudio said:
            ...Having a great time playing with it and V-Ray Fur...
            ๐Ÿ‘ ๐Ÿ‘ looks really fantastic - is this fur here is a V-Ray internal feature?
            @box said:
            A little inspiration for all the scifi modelers out there...
            ๐Ÿ‘ ๐Ÿ‘ not only for the scifis out there ๐Ÿ˜„ again magic - a great elastic simulation ๐Ÿ‘
            never trust a skinny cook
            • V Offline
              valerostudio
              Yes, what you are seeing is V-Ray Fur.
              • V Offline
                valerostudio
                Is there a way to have pressure (or have a future feature) where you can have a pillow and drop it on to a sofa or bed? I have played with this in Max a little bit.
                  smashor
                  How can I make this kind of curtain?
                  https://www.ikea.com/gb/en/images/rooms/ikea-clean-green-and-clutter-free-__1364315962817-s4.jpg
                    Anton_S
                    Flat curtains are usually really damp and neglect changing their form.
                    You can control the shape by creating pins and moving some forward and some backward.
                    The properties should be:
                    • Shear Stiffness: 1.0
                    • Bend Stifnness: 0.01
                    • Damping: 1.0
                    • Self-collision: ON
                    When you finish simulating, you can set bending to 0.00, so the cloth rests completely.
                    After simulation, you can apply loop subdivision and Laplacian smootheninth to better the result, as shown on the green curtain in the image below.
                    Curtains5.skp
                      Anton_S
                      Nice video! Soft bodies are planned for V2.
                      • HieruH Offline
                        Hieru
                        Although we'll have to wait for future releases to do this properly, it's still possible with the current version.
                        I just need to pull out my finger and find a screen capture method for recording my workflow.
                        www.davidhier.co.uk
                        • OxerO Offline
                          Oxer
                          My first test with the plugin, it has a lot of possibilities.
                          • HornOxxH Offline
                            HornOxx
                            Hieru and Oxer - your examples just above are so great !! ๐Ÿ‘ ๐Ÿ‘
                            how do you manage to generate these voluminous cloth shapes - whether as a pillow or a sack full of potatoes? what I mean is, which kind of cloth surface collides here onto or around which collider to get such a complex kind of result?
                            • OxerO Offline
                              Oxer
                              A picture is worth more than 1000 words.
                              • OxerO Offline
                                Oxer
                                New test, ClothWorks+MSPhysics, I modeled the potatoes and they placed with MSPhysics.
                                • pabloariasP Offline
                                  pabloarias
                                  Hi Anton.
                                  Bought and testing. Simply AWESOME. It's just what I needed. Anton, you're amazing.
                                  Pablo Arias
                                  SketchUp trainer
                                  V-Ray licensed trainer
                                  • jo-keJ Offline
                                    jo-ke
                                    still trying to make pillows.
                                    but I'm not getting on...
                                    Any ideas or tutorials?
                                    @ Oxer: how did you fix the frame?
                                    draping simple grids works fine. I've made a model of my curtain samples
                                    http://www.zz7.de
                                    • PixeroP Offline
                                      Pixero
                                      @oxer said:
                                      The frame is a pin, select de frame > right click > Make Pin
                                      That's a great tip. ๐Ÿ‘
                                      • HornOxxH Offline
                                        HornOxx
                                        โ“ ๐Ÿ˜ฎ โ“ please help me out of my hole - I try and try but don't get any idea what to do in which way to achieve such kind of shapes ๐Ÿ˜ณ
                                        • OxerO Offline
                                          Oxer
                                          The frame is a pin, select the frame > right click > Make Pin
                                          • Bob JamesB Offline
                                            Bob James
                                            oxer
                                            Thank you for the pictures. Please forgive my dullness, but could you explain how to use each of the pictures? ๐Ÿ˜ณ
                                            • 11
                                            • 12
                                            • 13
                                            • 35
                                            • 36
                                            • 11 / 36
