    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 911.4k Views 166 Watching
    • V
      valerostudio
      @hornoxx said:
      looks really fantastic - is this fur here is a V-Ray internal feature?
      Yes, what you are seeing is V-Ray Fur.
      • V
        valerostudio
        Is there a way to have pressure (or have a future feature) where you can have a pillow and drop it on to a sofa or bed? I have played with this in Max a little bit.
          smashor
          How can I make this kind of curtain?
          https://www.ikea.com/gb/en/images/rooms/ikea-clean-green-and-clutter-free-__1364315962817-s4.jpg
            Anton_S
            Flat curtains are usually really damp and neglect changing their form.
            You can control the shape by creating pins and moving some forward and some backward.
            The properties should be:
            • Shear Stiffness: 1.0
            • Bend Stifnness: 0.01
            • Damping: 1.0
            • Self-collision: ON
            When you finish simulating, you can set bending to 0.00, so the cloth rests completely.
            After simulation, you can apply loop subdivision and Laplacian smootheninth to better the result, as shown on the green curtain in the image below.
            Curtains5.skp
              Anton_S
              Nice video! Soft bodies are planned for V2.
              • HieruH
                Hieru
                Although we'll have to wait for future releases to do this properly, it's still possible with the current version.
                I just need to pull out my finger and find a screen capture method for recording my workflow.
                www.davidhier.co.uk
                • OxerO
                  Oxer
                  My first test with the plugin, it has a lot of possibilities.
                  • HornOxxH
                    HornOxx
                    Hieru and Oxer - your examples just above are so great !! ๐Ÿ‘ ๐Ÿ‘
                    how do you manage to generate these voluminous cloth shapes - whether as a pillow or a sack full of potatoes? what I mean is, which kind of cloth surface collides here onto or around which collider to get such a complex kind of result?
                    never trust a skinny cook
                    • OxerO
                      Oxer
                      A picture is worth more than 1000 words.
                      • OxerO
                        Oxer
                        New test, ClothWorks+MSPhysics, I modeled the potatoes and they placed with MSPhysics.
                        • pabloariasP
                          pabloarias
                          Hi Anton.
                          Bought and testing. Simply AWESOME. It's just what I needed. Anton, you're amazing.
                          Pablo Arias
                          SketchUp trainer
                          V-Ray licensed trainer
                          • jo-keJ
                            jo-ke
                            still trying to make pillows.
                            but I'm not getting on...
                            Any ideas or tutorials?
                            @ Oxer: how did you fix the frame?
                            draping simple grids works fine. I've made a model of my curtain samples
                            http://www.zz7.de
                            • PixeroP
                              Pixero
                              @oxer said:
                              The frame is a pin, select de frame > right click > Make Pin
                              That's a great tip. ๐Ÿ‘
                              • HornOxxH
                                HornOxx
                                โ“ ๐Ÿ˜ฎ โ“ please help me out of my hole - I try and try but don't get any idea what to do in which way to achieve such kind of shapes ๐Ÿ˜ณ
                                • OxerO
                                  Oxer
                                  The frame is a pin, select the frame > right click > Make Pin
                                  • Bob JamesB
                                    Bob James
                                    oxer
                                    Thank you for the pictures. Please forgive my dullness, but could you explain how to use each of the pictures? ๐Ÿ˜ณ
                                    • HieruH
                                      Hieru
                                      That's very smart...it will probably remove a step when I record my pillow workflow ๐Ÿ‘ .
                                      www.davidhier.co.uk
                                      • OxerO
                                        Oxer
                                          Jorgensen
                                          impressive work oxer!
                                          • Bob JamesB
                                            Bob James
                                            Thank you, oxer
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 35
                                            • 36
                                            • 12 / 36
