    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 883.3k Views 166 Watching
    • BoxB
      A little inspiration for all the scifi modelers out there.
      A flexible hatch.
      https://i.imgur.com/YIYGvX9.gif
        rv1974
        IS animated calculation a mandatoty thing?.
        May we get a simple 'show end (balanced) result' button?
        It will also help to understand the influence of the settings. Currently it's close to impossible. Apropo it'd be fantastic to have an auto update mode (on end result) while tweaking those parameters
        • BoxB
          I know I'm doing things it's not really designed for but I like the simplicity of clothworks.
          • majidM
            majid
            Seems stunning and I have an eye on it, does it also have "preventing self collision" option?
            • FrederikF
              Frederik
              @majid said:
              ...does it also have "preventing self collision" option?
              Of course... ๐Ÿ˜„
              Cheers
              Kim Frederik
              • HornOxxH
                HornOxx
                @valerostudio said:
                ...Having a great time playing with it and V-Ray Fur...
                ๐Ÿ‘ ๐Ÿ‘ looks really fantastic - is this fur here is a V-Ray internal feature?
                @box said:
                A little inspiration for all the scifi modelers out there...
                ๐Ÿ‘ ๐Ÿ‘ not only for the scifis out there ๐Ÿ˜„ again magic - a great elastic simulation ๐Ÿ‘
                never trust a skinny cook
                • V
                  valerostudio
                  Yes, what you are seeing is V-Ray Fur.
                  • V
                    valerostudio
                    Is there a way to have pressure (or have a future feature) where you can have a pillow and drop it on to a sofa or bed? I have played with this in Max a little bit.
                      smashor
                      How can I make this kind of curtain?
                      https://www.ikea.com/gb/en/images/rooms/ikea-clean-green-and-clutter-free-__1364315962817-s4.jpg
                        Anton_S
                        Flat curtains are usually really damp and neglect changing their form.
                        You can control the shape by creating pins and moving some forward and some backward.
                        The properties should be:
                        • Shear Stiffness: 1.0
                        • Bend Stifnness: 0.01
                        • Damping: 1.0
                        • Self-collision: ON
                        When you finish simulating, you can set bending to 0.00, so the cloth rests completely.
                        After simulation, you can apply loop subdivision and Laplacian smootheninth to better the result, as shown on the green curtain in the image below.
                        Curtains5.skp
                          Anton_S
                          Nice video! Soft bodies are planned for V2.
                          • HieruH
                            Hieru
                            Although we'll have to wait for future releases to do this properly, it's still possible with the current version.
                            I just need to pull out my finger and find a screen capture method for recording my workflow.
                            www.davidhier.co.uk
                            • OxerO
                              Oxer
                              My first test with the plugin, it has a lot of possibilities.
                              • HornOxxH
                                HornOxx
                                Hieru and Oxer - your examples just above are so great !! ๐Ÿ‘ ๐Ÿ‘
                                how do you manage to generate these voluminous cloth shapes - whether as a pillow or a sack full of potatoes? what I mean is, which kind of cloth surface collides here onto or around which collider to get such a complex kind of result?
                                • OxerO
                                  Oxer
                                  A picture is worth more than 1000 words.
                                  • OxerO
                                    Oxer
                                    New test, ClothWorks+MSPhysics, I modeled the potatoes and they placed with MSPhysics.
                                    • pabloariasP
                                      pabloarias
                                      Hi Anton.
                                      Bought and testing. Simply AWESOME. It's just what I needed. Anton, you're amazing.
                                      Pablo Arias
                                      SketchUp trainer
                                      V-Ray licensed trainer
                                      • jo-keJ
                                        jo-ke
                                        still trying to make pillows.
                                        but I'm not getting on...
                                        Any ideas or tutorials?
                                        @ Oxer: how did you fix the frame?
                                        draping simple grids works fine. I've made a model of my curtain samples
                                        http://www.zz7.de
                                        • PixeroP
                                          Pixero
                                          @oxer said:
                                          The frame is a pin, select de frame > right click > Make Pin
                                          That's a great tip. ๐Ÿ‘
                                          • HornOxxH
                                            HornOxx
                                            โ“ ๐Ÿ˜ฎ โ“ please help me out of my hole - I try and try but don't get any idea what to do in which way to achieve such kind of shapes ๐Ÿ˜ณ
                                            • 11
                                            • 12
                                            • 13
                                            • 35
                                            • 36
                                            • 11 / 36
