    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    707 Posts 163 Posters 739.5k Views 163 Watching
    • HornOxxH Offline
      HornOxx
      Hieru and Oxer - your examples just above are so great !! ๐Ÿ‘ ๐Ÿ‘
      how do you manage to generate these voluminous cloth shapes - whether as a pillow or a sack full of potatoes? what I mean is, which kind of cloth surface collides here onto or around which collider to get such a complex kind of result?
      never trust a skinny cook
      • OxerO Offline
        Oxer
        A picture is worth more than 1000 words.
        • OxerO Offline
          Oxer
          New test, ClothWorks+MSPhysics, I modeled the potatoes and they placed with MSPhysics.
          • pabloariasP Offline
            pabloarias
            Hi Anton.
            Bought and testing. Simply AWESOME. It's just what I needed. Anton, you're amazing.
            Pablo Arias
            SketchUp trainer
            V-Ray licensed trainer
            • jo-keJ Offline
              jo-ke
              still trying to make pillows.
              but I'm not getting on...
              Any ideas or tutorials?
              @ Oxer: how did you fix the frame?
              draping simple grids works fine. I've made a model of my curtain samples
              http://www.zz7.de
              • PixeroP Offline
                Pixero
                @oxer said:
                The frame is a pin, select de frame > right click > Make Pin
                That's a great tip. ๐Ÿ‘
                • HornOxxH Offline
                  HornOxx
                  โ“ ๐Ÿ˜ฎ โ“ please help me out of my hole - I try and try but don't get any idea what to do in which way to achieve such kind of shapes ๐Ÿ˜ณ
                  • OxerO Offline
                    Oxer
                    The frame is a pin, select the frame > right click > Make Pin
                    • Bob JamesB Offline
                      Bob James
                      oxer
                      Thank you for the pictures. Please forgive my dullness, but could you explain how to use each of the pictures? ๐Ÿ˜ณ
                      • HieruH Offline
                        Hieru
                        That's very smart...it will probably remove a step when I record my pillow workflow ๐Ÿ‘ .
                        www.davidhier.co.uk
                        • OxerO Offline
                          Oxer
                            Jorgensen
                            impressive work oxer!
                              Bob James
                              Thank you, oxer
                              • OxerO Offline
                                Oxer
                                You're welcome!
                                • FrederikF Offline
                                  Frederik
                                  Learning something new everyday... ๐Ÿ˜„
                                  However, why can't I get this right...?
                                  Canvas-bag.skp
                                  Cheers
                                  Kim Frederik
                                  • OxerO Offline
                                    Oxer
                                    Care Frederik!! "The curiosity killed the cat" ๐Ÿ˜† ๐Ÿ˜†
                                    • OxerO Offline
                                      Oxer
                                      The possibilities are endless, you can use ClothWorks to create a lot of different organic objects, more examples at the end of the day or tomorrow.
                                      • HornOxxH Offline
                                        HornOxx
                                        thank you Oxer for your second sketch ๐Ÿ‘
                                        I continue to fail at the simplest things ๐Ÿ˜ณ How do I make cloth and Pin sticking together?
                                        test 01.skp
                                        • FrederikF Offline
                                          Frederik
                                          But seriously...
                                          When I converge the cloth+frame with the balls (collider), the cloth doesn't bend as I would expect... ๐Ÿ˜ž
                                          I press the ClothWorks play button, click the frame (pin) and drag the red arrow towards the balls, but the cloth just remain stiff and doesn't fold around the balls...
                                          I don't get the result HornOxx is showing in his animation... ๐Ÿ’š
                                          I assume that's caused by the cloth isn't "inside" the frame...?!?
                                          Cheers
                                          Kim Frederik
                                          • OxerO Offline
                                            Oxer
                                            HornOxx & Frederik, the trick is to create the frame with 3 elements because if the frame is an unique object ClothWorks creates a box for the pin and this makes that the cloth does not move. See the image.
                                            REMEMBER: The cloth should enter a little in the frame.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 35
                                            • 36
                                            • 12 / 36
