    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 295.0k Views 135 Watching
      I'm not bringing them. But they could be there.
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        You're not coming?
        • sfto1S Offline
          sfto1
          I like to place section planes at specific locations. So, when I learned that if I hold down CTRL before clicking to locate section plane, it will stick to the face it is near. Then I move the plane using the move tool relative to that face. Duh or D'oh, I don't know, but I like it.
          • E Offline
            Ecuadorian
            Hey, everyone! I just downloaded the book. Thank you for the good memories! ๐Ÿ˜ƒ
            -Miguel Lescano
            • GarethG Offline
              Gareth
              Great book....love it....!!
              Well done.
              • genki.ttG Offline
                genki.tt
                I found a small miss type on The D'oh! Book P61(ver.1.0) P63(ver.1.1)
                [20mm, 10mm, 30mm] absolute move -> <20mm, 10mm, 30mm> relative move
                By the way I could find Doh about Array Command, we can change operation 'x' to '/' with using 'x1' , or we can change '/' to 'x' with using '/1'.
                copy(move + 'alt') some object and type VCB
                <1000,,>
                x4
                10000
                x1
                /4
                20000
                /1
                <1000, 1000, 1000>
                x10
                .... we can continue 'x', '/', distance value, relative vertics, absolute vertics.
                'x1' or '/1' is important.
                Thank you for GREAT BOOK!!
                  Doh of the day! Surely trivial but never remarked! ๐Ÿ’š
                  Saving a file with objects who are not Components and Groups
                  New File
                  Import this file : it's converted in a Component! ๐Ÿ˜ฎ
                    New File
                    And if you create a component and save it using File>Save as... and then import it, it'll be double wrapped.
                      And Making a Component creates a new context menu on the Right Click Menu!
                      "Save As" (+ "Reload" + "Detach")
                      So more speed than the menu "File Save as" ! ๐Ÿ˜‰
                      • E Offline
                        Ecuadorian
                        I've just spent one hour asking myself why I could not copy-paste from an old SKP file to a new SKP file with a newly imported AutoCAD drawing. I run SketchUp's checkup, GPU-Z, Repaired SketchUp, reinstalled SketchUp... Nothing. Until I remembered these guys send me the AutoCAD drawings in milimeters instead of meters, but I imported it as meters... So the new drawing was gigantic and anything I copy-pasted from the old file was just too tiny to be seen.
                        -Miguel Lescano
                          Why not use the "Zoom Extended" in a new file ? ๐Ÿ˜ฎ ๐Ÿ˜„
                            rv1974
                            Today Penny has Dropped:
                            XnView is way better BP2 library explorer then a built-in one.
                            As well I use XnView as Component explorer for years now. Excellent with 2nd disply + drag'n'drop.
                              Sleipnir
                              New to this program, looking for a good extension for cabinet building and or wood working draw up.
                              Odin's Favorite Eight Legged Horse'
                                Super Doh of the day! Thanks Dave! ๐Ÿ‘
                                The arc Circle "Knife"! Make a Double Click at the end of the Arc Drawing! ๐Ÿค“
                                Excellent! ๐Ÿ˜Ž โ˜€
                                Never made the Double Click! (just simple click: as it was not writed on the bottom help line! ๐Ÿ˜ณ
                                And I surrely missed it on the manual! ๐Ÿ˜ณ
                                Animation by Dave
                                https://sketchucation.com/forums/download/file.php?id=148790&mode=view/rokbox.jpg
                                  You probably missed this, too. If you want to place the same radius on other corners, double click near them.
                                  Click on pic if it doesn't move.
                                    Very cool! โ˜€ ๐Ÿ‘
                                    I suppose I am not the only one! ๐Ÿ’š
                                      kaas
                                      I don't know if this is a new feature but I was pleasantly surprised to learn about it:
                                      In the 3dWarehouse, select a model, look at the statistics in the panel on the right, if you hover / click on a tag (materials/components) you can import just one of those elements instead of the whole model.
                                      Great feature if you just need 1 material of 1 element from a collection.
                                      • boofredlayB Offline
                                        boofredlay
                                        https://media.giphy.com/media/EldfH1VJdbrwY/giphy.gif
                                        • HornOxxH Offline
                                          HornOxx
                                          @pilou said:
                                          ...I suppose I am not the only one! ๐Ÿ’š
                                          ๐Ÿ˜„ ๐Ÿ˜„ I'm also a member of this unsuspecting club...
                                          never trust a skinny cook
                                            rv1974
                                            At last we have a fastest\easiest tool for ramps/stairs/roads!
                                            Check s4u Stair() in Plugin Store.
                                            Absolutely worth every penny.
                                            โ˜€
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 33 / 35
