    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 542.9k Views 135 Watching
    • sfto1S Offline
      sfto1
      I like to place section planes at specific locations. So, when I learned that if I hold down CTRL before clicking to locate section plane, it will stick to the face it is near. Then I move the plane using the move tool relative to that face. Duh or D'oh, I don't know, but I like it.
      • E Offline
        Ecuadorian
        Hey, everyone! I just downloaded the book. Thank you for the good memories! ๐Ÿ˜ƒ
        -Miguel Lescano
        • GarethG Offline
          Gareth
          Great book....love it....!!
          Well done.
          • genki.ttG Offline
            genki.tt
            I found a small miss type on The D'oh! Book P61(ver.1.0) P63(ver.1.1)
            [20mm, 10mm, 30mm] absolute move -> <20mm, 10mm, 30mm> relative move
            By the way I could find Doh about Array Command, we can change operation 'x' to '/' with using 'x1' , or we can change '/' to 'x' with using '/1'.
            copy(move + 'alt') some object and type VCB
            <1000,,>
            x4
            10000
            x1
            /4
            20000
            /1
            <1000, 1000, 1000>
            x10
            .... we can continue 'x', '/', distance value, relative vertics, absolute vertics.
            'x1' or '/1' is important.
            Thank you for GREAT BOOK!!
              Doh of the day! Surely trivial but never remarked! ๐Ÿ’š
              Saving a file with objects who are not Components and Groups
              New File
              Import this file : it's converted in a Component! ๐Ÿ˜ฎ
                New File
                And if you create a component and save it using File>Save as... and then import it, it'll be double wrapped.
                  And Making a Component creates a new context menu on the Right Click Menu!
                  "Save As" (+ "Reload" + "Detach")
                  So more speed than the menu "File Save as" ! ๐Ÿ˜‰
                  • E Offline
                    Ecuadorian
                    I've just spent one hour asking myself why I could not copy-paste from an old SKP file to a new SKP file with a newly imported AutoCAD drawing. I run SketchUp's checkup, GPU-Z, Repaired SketchUp, reinstalled SketchUp... Nothing. Until I remembered these guys send me the AutoCAD drawings in milimeters instead of meters, but I imported it as meters... So the new drawing was gigantic and anything I copy-pasted from the old file was just too tiny to be seen.
                    -Miguel Lescano
                      Why not use the "Zoom Extended" in a new file ? ๐Ÿ˜ฎ ๐Ÿ˜„
                        rv1974
                        Today Penny has Dropped:
                        XnView is way better BP2 library explorer then a built-in one.
                        As well I use XnView as Component explorer for years now. Excellent with 2nd disply + drag'n'drop.
                          Sleipnir
                          New to this program, looking for a good extension for cabinet building and or wood working draw up.
                          Odin's Favorite Eight Legged Horse'
                            Super Doh of the day! Thanks Dave! ๐Ÿ‘
                            The arc Circle "Knife"! Make a Double Click at the end of the Arc Drawing! ๐Ÿค“
                            Excellent! ๐Ÿ˜Ž โ˜€
                            Never made the Double Click! (just simple click: as it was not writed on the bottom help line! ๐Ÿ˜ณ
                            And I surrely missed it on the manual! ๐Ÿ˜ณ
                            Animation by Dave
                            https://sketchucation.com/forums/download/file.php?id=148790&mode=view/rokbox.jpg
                              You probably missed this, too. If you want to place the same radius on other corners, double click near them.
                              Click on pic if it doesn't move.
                                Very cool! โ˜€ ๐Ÿ‘
                                I suppose I am not the only one! ๐Ÿ’š
                                  kaas
                                  I don't know if this is a new feature but I was pleasantly surprised to learn about it:
                                  In the 3dWarehouse, select a model, look at the statistics in the panel on the right, if you hover / click on a tag (materials/components) you can import just one of those elements instead of the whole model.
                                  Great feature if you just need 1 material of 1 element from a collection.
                                  • boofredlayB Offline
                                    boofredlay
                                    https://media.giphy.com/media/EldfH1VJdbrwY/giphy.gif
                                    • HornOxxH Offline
                                      HornOxx
                                      @pilou said:
                                      ...I suppose I am not the only one! ๐Ÿ’š
                                      ๐Ÿ˜„ ๐Ÿ˜„ I'm also a member of this unsuspecting club...
                                      never trust a skinny cook
                                        rv1974
                                        At last we have a fastest\easiest tool for ramps/stairs/roads!
                                        Check s4u Stair() in Plugin Store.
                                        Absolutely worth every penny.
                                        โ˜€
                                          Thank you, thank you, thank you!
                                          • david_hD Offline
                                            david_h
                                            I know I should know this (being a top sketchukator and all--- ๐Ÿ’š Yeah, I am having a hard time containing my laughter too. . .)but as I said. .I know I should know this but I don't:
                                            as I go between scenes with sections how can I toggle between them and keep the section plane window off so I dont have to manually turn them off each time? I have always found the scene menu in SU very confusing and conveluted and I can't seem to get this to work as I want. Help please? Thanks.
                                            David_H
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 33 / 35
